Question about Maytag Dryers
My Maytag Performa PYE3200AYW has stopped working and I'm trying to figure out how to get a look inside to determine what the problem is
5 Suggested Answers
  • 868 Answers
SOURCE: dryer stopped working
Yes it maybe a fuse problem .But first you want to make sure the door switch is working.
Posted on May 21, 2008
SOURCE: maytag performa dryer assistance
Hello, My name is Juan. I will need help to find the problem with some suggestions. My dryer won't start at all, even when I open the door the light bulb inside the drum did not turn on. I check the power source it is ok. Please help with alternatives for a solution. Maytag electric dryer Mod # PYET344AYW
Juan J.
Posted on Jun 17, 2008
  • 706 Answers
SOURCE: Maytag Performa dryer venting
You are always better off using steel on these kinds of conversions and do not worry about how hot it gets,..Aluminum will get hot too. Steel is more rigid and less likely to dimple in while installing or hooking up the external vent system... Hope this helps..
Posted on Sep 01, 2008
SOURCE: maytag pye3200ayw will not start, jump out the
You cannot simply jump out the thermal fuse ---simply take apart your dryer --wash out the entire Dryer --motor heating element, ducts, all of it with a garden hose to remove all lint---do not attempt to do anything else until you allow it to completely dry out, this will not hurt any of it as long as you allow it to dry although you should then relubricate the motor and bearings. once you do this you should replace the thermal fuse --which is located below the heating element when you take it out. I have found that the thermal fuse kit (part #La-1053) works very nicely for this as you actually get two fuses (which you could save one for a spare) it costs 22.95 from Cheapappliance with a shipping cost of $5.95. Trust me this should cure your Problem-- I have fixed hundreds of these and they all seem to suffer from this same Problem which comes from the excess build-up of link which causes it to overheat and BLOw the fuse.. This is why it is very important to CLEAN it out -----otherwise it will blow the fuse out again in a no time..
HOPE this HELPS>>>
Posted on Aug 10, 2009
Maytag dryer model number PYE3200AYW stopped working and no light comes on when door is open
check the door switch:
Oct 30, 2010 | Maytag PYE2300AY Electric Dryer
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
My Maytag Performa Dishwasher is leaking when doing the dishes...
Sounds like your fill valve is stuck in the filling position...see if you you have water standing in it a couple hrs after a drain cycle. if it does then the valve needs to be replaced or you can take it apart carefully,(there is a sping that might fly out and get lost) and clean it. Mine had some small trash in it from the city water line.. The left side has an over flow hole is where your water is coming from..
Nov 12, 2009 | Maytag Performa PAV2200
Maytag performa dryer suddenly stopped working, as if no power. i replaced both fuses and it worked. ran for about 15 mins and stopped again. any suggestions?
did it blow the fuses a second time.try this .put your dryer on a cycle that wont call for heat and turn it on.if the heat strips are not on and it still blows a fuse it is the motor.if the heat strips are on and it blows a fuse the heat strips are the trouble.
Nov 05, 2009 | Maytag Performa PAV2200
My PYE3200AYW runs but will not heat. Changing
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer2.gif. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 08, 2009 | Maytag PYE2300AY Electric Dryer
Thermal Fuse PYE3200AYW Maytag Elec Dryer
Aug 19, 2009 | Maytag PYE2300AY Electric Dryer
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
Sep 01, 2008 | Dryers
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryers Logo
169 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
