Question about Health & Beauty
Springs fell out
My wife has a WDF 3500 Remington Shaver. She dropped it and two very small springs fell out. I got the head back on but I cannot figure out where the springs go. They are about 9/16" long and about 1/16" round. Can you help
  • mccaul Sep 30, 2008
    I took my shaver apart to clean. Removed the head latch not realizing there was probably a spring inside. Head will not stay latched while shaving
I did get it fixed. I kept looking at it and studying it and I finally figured out that the small, gold head is where they had to go. I pushed on it and it finally fell out. I saw two small holes that looked like they were the same size as the springs. I put them in and when I put the piece back in the razor, the spring lined up with 2 small pegs on the inside. I snapped the head in place and the gold bars then moved up and down with a little resistence. I turned the shaver on and it worked just fine.
Posted on Sep 12, 2008
1969 Remington ladies electric razor model Cl how to use it
Women's Shaver Parts' Parts and Accessories ' Remington ...
www.remingtonproducts.com/.../womens/shaverpart...
Remington ProductsRemington women's hair removal replacement parts. Electric shaver parts, wet dry shaver blades, shaver heads and cutters, shaver cords, ... I have a Remington Smooth & Solky Plus Wet/Dry Rechargable Shaver (Model: WDF-5000) and am ...
Women's Electric Shavers - Remington Products
www.remingtonproducts.com/womens/.../wetdrysha...
Remington ProductsRemington Women's Hair Removal Wet Dry Shavers ... Wet/Dry Shavers. Smooth and Silky 4 Blade System Rechargeable Shaver With Almond Oil; $39.99.
Jan 07, 2016 | Remington Health & Beauty
Is my remington razor model wdf-3500 a wet and dry
The WDF-3500 can be used wet (with foam lather or soap) or dry when not plugged in. Turn it off when you put it under running water (when cleaning it for example). Do not have it near water when plugged into the charger.
Remington has the manuals for many of its products here: http://www.remingtonproducts.com/ConsumerService/UseCareManuals.aspx . Use the drop-down menus to get to your specific product. The direct link to the manual for the WDF-3500 in English is http://www.remingtonproducts.com/~/media/Files/Manuals/Shavers%20Womens%20Shavers/Remington%20Womens%20Shavers/English/WDF3500.ashx . (This is a PDF; you will need Adobe Reader or a similar product to view or print the manual.)
I hope this helps.
Sep 08, 2014 | Health & Beauty
I have a Remington 360 rotary shaver - model no. R7130. One of the small springs inside one of the rotating cutting heads is missing. Am I able to purchase a spring to fit please?
These springs are not available from Remington for replacement. Your best bet is to go to your local hardware store where they should have a variety of springs available
Sep 01, 2011 | Remington Health & Beauty
How do i know if the shaver is fully charged?
Model WDF-3600 has no indicator to tell you when it is fully charged. After the suggested initial charge of 24 hours, future recharges take about 8 hours. See user manual at the link below
http://www.remingtonproducts.com/~/media/Files/Manuals/Shavers%20Womens%20Shavers/Smooth%20Silky%20Shavers/English/WDF-3600.ashx
May 17, 2011 | Remington WDF-3600 Electric Shaver
How do I replace the battery in my Remington WDF 6000 shaver?
You can have the battery replaced but this needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Dec 28, 2010 | Remington WDF-6000 Electric Shaver
How to replace battery on remington wdf 6000 ladies shaver
You can have the battery replaced This needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
Nov 26, 2010 | Remington WDF-6000 Electric Shaver
Replace Battery in Remington wdf 3500
It is more likely that the problem is the switch. It is poorly designed and tends to remain stuck partly in the on position, so when you try to charge it, the charger is supplying low power to the motor (not enough to run the motor) and over heats the charger. You can tell this by a dull charge light on the shaver. This can be fixed by dismantling it, cleaning the switch contacts and lubricating with an electrical contact lubricant. I just did this on my girlfriends and it's gone from dead to working perfectly. Do not use this in the shower, it is not made for this even if the manual says so.
Jun 20, 2009 | Remington Smooth and Silky WDF-3500 Hair...
I need to replace batteries in Remington wdf 3500
Have just opened the same model -
First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
Dec 22, 2008 | Remington Smooth and Silky WDF-3500 Hair...
Health & Beauty Logo
215 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
