Question about Sony KV-32S35 32" TV
Nothing but snow from tuner and no sound - Sony KV-32S35 32" TV
  • Steve Wachniak Mar 28, 2006
    Video and sound input from VCR work fine
    I would appreciate any information to help in this problem
    President:
  • 3,130 Answers
You hooked up to cable??? Is your bill paid and cable came in turneed it off? sounds like you have a tuner problem ..
Posted on Mar 28, 2006
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Durabrand 13' DU1301 TV problem: I can barely see the picture or hear anything because of intermittant snow. Sometimes the picture will roll as if we are back in the 70s. When I turned the tv on its...
Hello
The fault you describes is due to low signal strength. If tuner of the said TV is faulty, this type of snow interference will occur too. Just check for good firm connection to its antenna terminal. If it is Ok, check the continuity of the cable used with antenna. Check the orientation of yagi antenna if used outside. If all are OK, and nothing help you, just replace its tuner with same type and number. Tuner is a small metal box type component can be seen soldered directly to the main printed circuit board inside. Usullay, its one terminal will come out as antenna IN of the TV, to which you connects the external antenna or cable. You must have a concept of soldering and desoldering to replace it, and must have a knoledge in electronics too. OK.
Jul 29, 2011 | Durabrand DU1301 TV
Horizontal lines/"snow"
it sounds as iff it the arial connections ?? are the problem check the connections you may need new cable? use 75 ohms cable
Apr 23, 2009 | RCA 20F610TD TruFlat TV/DVD
Channel Reception
It sounds like a defective tuner or a IF module as well. It may also be a defective capacitor(s) or cold solder joints inside the tuner circuitry. I woud suggest to use a VCR or a TV convertor connected to an Audio/video input to change channels instead of fixing it.
Good Luck.
Jan 21, 2008 | Sony KV-27V42 27" TV
Sanyo tv # DS35580
you need a new tuner
Dec 04, 2007 | Televison & Video
No more picture and sound
Tv was showing perfect picture now it's snow solution 1 please check antena wire & its socket. 2 check for dust where wire is connected. 3 loose contact or print break near tuner. 4 tuner defective.
Sep 15, 2007 | Sanyo DS27930 27" TV
No picture or sound
If you see only snow and the words "NO SIGNAL" are displayed, and you know that you have the set hooked up to a good signal and the TV is set to the right channel, it means that your tuner has stopped working and needs to be replaced. First, though, make sure your signal is good. A good way to test this is to hook the TV to a good VCR, put in a good pre-recorded tape and hit play. Tune the TV to channel 3 (or 4) and if it is still all snow, have the tuner replaced by a qualified tech.
Sep 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
All I get is snow.
Sounds like a tuner problem on the main board, you can take the back off and make sure that the tuners are plugged in good, alot of problems with tuners are the grounds get cold solder
Nov 07, 2006 | Samsung SP-P4251 42 in. Plasma EDTV
Sony KV-32S35 32" TV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
