Question about Toshiba 32AF41 32" TV
Red lines across screen
My Toshiba 32AF41 television shuts off by itself. Before shutting off red horizontal lines appear then the entire screen turns red before shutting off. I have to unplug the television and plug back in in order to turn the television back on. Any suggestions? Thank you. Laurie
  • Anonymous Nov 22, 2007
    I have the same problem, where TV gets diagonal red lines, shuts off. And Red light blinks on the TV. If I unplug the TV turns on again. Noticed if TV is running for awhile is not happen, only when I first turn the TV on
  • cottonrotton Aug 13, 2008
    my tv is about 8 years old and sometimes the pictures snaps out and becomes green lines acrossed the screen .. sometimes a good smack on the side will snap the picture back.. the red light blinks while the green line is present
    President:
  • 3,130 Answers
It sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting. I have seen intermittant shorts in crt before.
Posted on Mar 28, 2006
SOURCE:
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
Thin red line, green line and yellow line going across the screen
the problem is vertical collapse,i am not so sure you can trouble shoot this on your own but you can send the board to eithor pts electronics or tristate module for repair
to get a price get the number off the sticker--left hand board(looking from the back) it will start CTC195---- write down entire number before you call them
Sep 02, 2009 | RCA P52926 52" Rear Projection Television
Red screen and lines, then TV shuts off automatically
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Jun 19, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Red red wavy lines across the TV screen
I did not fix the problem, but you have the model number wrong, it is KP-46WT510
I do need some help.
Nov 23, 2008 | Sony KP-43HT20 43" Rear Projection...
Toshiba 32AF43 problems
bright red with lines left to right? would be shorted crt. shutting off would be normal due to high beam current.
Nov 09, 2008 | Toshiba 32AF43 32" TV
RED SCREEN
hell yeah,
the biggest mistake I did with this tv.all tubes need to be replaced and it burns a hole in ur pocket.no guarantee on tubes,sony aware of the problem but didnot recall these defective sets.
good luck.
nanz
Oct 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Shuts down
it is due to problem in red cideo section. solution 1 supply to red video output& output itself 2 crt base loose 3 connector loose 4 red video sigal line from chroma ic to red cathode of crt. 2 red
Nov 13, 2006 | RCA 27V520T 27" TV
wow this set has several problems that cause almost the same symtoms. There is a b+ filter cap off the flyback that supplys screen drive voltage th the crt that gets leaky and gets warm when the sets on. Also theres a resistor that feeds the voltage that gets warm and a cold solder connection appears but its dosent look like a bad solder connection so just resolder it. as a matter of fact most of those largewr resistors in this set causes all sorts of complaints soI resolder most of them just to stop any problems and a friend in the tv business still told me in one case he had an intermittant crt. and x ray protection cuircut problems.. Hope this helps GOOD LUCK
Mar 27, 2006 | Toshiba 27AF41 27" TV
Toshiba 32AF41 32" TV Logo
379 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
