This does not help. Head light is accessed from front wheel well. Where do I go from there?This does not help. Head light is accessed from front wheel well. Where do I go from there?
So when the car is off and you have your headlights switched on both the low beam setting and high beam setting work normally. But once you start your car your low beam headlights work but when you switch to your high beams the right headlight shuts off? I don't know how that'd be possible since the controls for your high beam and low beams aren't connected to whether the engine is running I'd suggest changing your headlight bulbs
Apr 1, 2010 - 13 posts - 6 authors
My passenger side low beam headlight recently went off on me. ... I've changed the bulb again, and changed the fuse just in case, but .... My driver side headlight wire got loose so when i hit a bump at night if would flicker. ... When you notice one side not working (Low or High beam) it could be the module.
Headlight replacement
Jan 22, 2009 Low beams don't work but High's do
Mar 20, 2005 More results from www.nissanclub.com
A loose ground wire to the headlight will keep it dim,Or a headlight adjustment will bring the headlight up.If you can have your headlight turned on a garage door or something at night,and then watch as you change your headlights from low beam to high beam which ones are higher.the last thing to verify is that your high beam headlights are not the plastic lens type that turn dull which cuts the light power.
How to Shift my headlight beam from position. from I replace my headlight it's spatting directly on the ground..What can i do to change it from position
Just what I found out.Thanks
