Question about Hobart A200 Stand Mixer
Sound like bearings
I have a Hobart A200T and it works well on the first gear but when I switch to 2or 3 rd gear it sounds like the bearings are dry any help would be appeciated
  • 49 Answers
Ist check your agitator shaft for looseness. the shaft you put the beater on. wiggle side to side. if tight no play. If in first its quiet but you can here a grumble under load but second gets louder. and third even louder. If the shaft is tight. your gears down there are warn. you can take that all off with the two nuts underneath. and check the grease on the gears but even with new grease on them it most likely stay loud. grease it with hobart grease from your loacal hobart for the A-200 planitary not the transmision they also fve grease for Trans. if you can take the noise run it that way if not decide which arm & leg you want to give hobart for new gears.
Posted on Sep 30, 2008
I've broken the agitator shaft pin on my Hobart A200T. I can find replacement pins online, but the local Hobart tech. is MIA. How do you remove the pin? How do you secure the replacement in the...
Drive it out with a punch and hammer. It's best to take the planetary off the machine so you can support the shaft. If not it puts a lot of unnecessary stress on the bearings and other parts.
Jul 08, 2011 | Hobart A200 Stand Mixer
A200T Slips in low and medium speed
Planetary gears worn from, #1 changing speeds while unit running, #2 over loading the bowl. batter & icing max 75% bowl capacity, Dough max 65% bowl capacity
Jul 17, 2009 | Hobart A200 Stand Mixer
I need the manual for the Hobart 20 Quart Mixer A200T
Hobart doesn't release their service manuals to the general public,however i'm a hobart tech and repair these mixer's often.If you need any help let me know.
Mar 05, 2009 | Hobart A200 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
I have a Hobart a200t industrial mixer which isn't running properly. When turned on, it just hums, and the gears don't move. I have been searching online and cannot find a free troubleshooting guide. I...
Hi, it is hard to determine exactly what the problem is without seeing it, however, that mixer usually uses a capacitor to help start the motor, and a switch, or relay, that are in the back of the unit. You probably will not find any troubleshooting guide, Hobart does not give up information easily. You can take it to an electric motor repair shop, and they will easily be able to tell which of those is the problem, and will be reasonable in price. Your other option is to contact Hobart locally for service assistance. Maybe one of the other Hobart techs here can help you out more.
A200T mixer
On the bottom of the planitary the part where you put the beater. there is two nuts. one lookes like a Acorn nut and a thin one above it. By the book the top thin one should be finger tight. Not wrench tight. you need a thin wall 3/4" wrench you hold the thin nut with iot and tighten up the bottom acorn up to the thin one and they lack against each other so not to come losse .on some mixers this thin nut tightend down will mess with older parts and bind the centersahft parts.
Aug 14, 2008 | Hobart A200 Stand Mixer
A200t ist gear
This is a lousy diagram for your purpose ...
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Page 14. The spring goes on the right with the hump against the roller.
Mike
Apr 27, 2008 | Hobart A200 Stand Mixer
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
Apr 04, 2008 | Hobart A200 Stand Mixer
Hobsrt Mixer problem
Its ok to by pass the timer.You can bypass it and the switch will work.Let me get my service manual and ill post back on how to do it.
Feb 20, 2008 | Hobart A200 Stand Mixer
Hobart A200T General Info / Back cover plate gasket
I'm a service tech for hobart,I'll type your serial number into our database and see what it brings up.The changes that have been made---older units use a mechanical start switch on the motor,the new units use an electronic start switch.the old units center shaft and gears have changed.the older units dont have bowl guards and the new units do.(this is a cage that goes around the bowl).The gasket that your talking about is just that--a thin paper.The paper wears and you get that symptom you describe and its normal.I'll get back to you.
Hobart A200 Stand Mixer Logo
206 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
