Question about Kitchen Ranges
TAPPAN COOKING STOVE MODEL #KTM2873-37D GAS - EVERYTHING WORKS FINE EXCEPT FOR THE OVEN. THE BURNER IS NOT GETTING GAS TO IT. HAVEN'T 'TORN-INTO-IT' YET, NOT SURE IF THERE IS A GAS REGULATOR FOR JUST THE OVEN PART THAT ISN'T LETTING GAS THRU, OR WHAT????
  • 116 Answers
When you turn the oven on do you see any kind of glow inside the oven compartment? If you didn't your controller may be defective. If there is one of two possibilities: defective safety valve(GAS VALVE) or defective ignitor (glowing unit - even though it glows - still bad). The latter is the more likely of the two. When working properly about 3.2 amps needed to turn safety valve.
Regards
Posted on Sep 10, 2008
I have a 6 yr old Tappan stove, model TGF657BFW5. the burners work fine, but the oven and/or broiler take 5 to 10 minutes to light. when the oven and/or broiler do light, the flame is only about 1/8 to 1/4...
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
Nov 06, 2017 | Tappan Ovens
TAPPAN MODEL 3 TGF367CFSA, GETTING A F3 CODE, OVEN DOES NOT WORK
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
Feb 07, 2010 | Tappan TGF364AS Gas Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Aug 14, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
154 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
