Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Picture is snowy on every channel. I hooked up my playstation and set it to the correct channel but the screen display is the same. I tried using the menu and the menu comes up just fine. The menu goes on top of the screen and is transparent so I can see the settings just fine but the picture of the stations are snowy. I have an another TV beside it and it works fine. This means that reception is not a problem. I find it wierd that the menu comes up correctly but the channel will not show up. I can see what is on the channel. It also does the horizontal line thing. The problem almost looks like if you were trying to view a cable station that you did not pay for. I use a antenna to get local stations and do not have cable.
  • brinkton91 Dec 03, 2007
    We have a satellite for 2 televisions in our house. The one television is working fine, but all you can see on the other (Zenith Inteq) is snow. I have tried unplugging for awhile, changing hookups and the audio/video from the menu. Is there anything else I can try?
What techman is trying to tell ya is plug it into the a/v inputs bypassing the tuner & if it works...no need to pay for a repair on a 6 yr old set...
Posted on Aug 17, 2007
    President:
  • 3,130 Answers
If one tv looks good and another one dosent look good or operate correctly then we know for sure that the problem is not the antenna. Now the menu comes up ok because the menu is injected after the tuner into the video curcuit from a osd or microprocessor. sounds like you could have a defective tuner or antenna block assy.
Posted on Mar 28, 2006
SOURCE:
Snowy picture on my vizio tv
I have lost two answers I have given. Sorry.
Check the input on the remote, it has to be in the correct place. When it is right. Go to set up on the remote, find picture and adjust the colour on the screen. Hope this works for you it has for me. If not restart the router and exchange box if you use that and check input again and the set up.
lastly try other channels, it can be the broadcast is not working correctly.
all the best
kolbrun
Oct 14, 2014 | LG 42LC2D 42 in. LCD HDTV
Snowy picture
The remote doesn't effect the channels, I would say you have poor signal or interference from another device nearby.
Sep 12, 2008 | Orion1934 19" TV
Sony KDL-V32XBR1 Displays only snowy picture
Here are a few more troubleshooting steps you can try when your TV picture is just snow. I see that you have already rebooted your TV, but did you turn your set-top box off and on, too?
1. Does the picture show when you play a DVD?
2. Check all of the connections between the TV, outlet and set-top box and make sure everything is secured.
3. Is your TV set to the correct channel (typically 3, but in some areas 2 or 4)?
4. Press any key on the remote to see if the correct mode lights up. (Ex: if you have cable, the cable button should light up). If it doesn't, press the correct mode's button to regain control and change channels.
5. Call your service provider and make sure it's not an overall service outage.
6. Do you have sound but no picture? If so, it could mean a backlight failure.
For more suggestions, see TV black screen or snowy screen for troubleshooting and solutions. I hope this helps!
Sep 20, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have 2 ps3 consoles one new slim model other is older model both attached to 1080p 120hz tv's one sony one sharp aquos both using top of line $300 monster cable hdmi cables. The ps3 menu screen on both...
did you try going through the settings to configure yur tv with the game console so they could work together properly.also make sure your hdmi cables are good ones.and also try to reset the contrast,brightness etc of the tv.
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
My rca has no picture the screen has a snowy picture is if it was on the wrong channel through my cable box.
More information would help. What are you running the signal into the TV with? Coax? Separate video/audio? To test the set if you have a vcr hooked up or available to hook up, input it into the tuner input and play a tape. Set the tv to either channel 3 or 4 (whichever channel the output of the vcr is set for, this can be determined by checking the menu or a switch on the back if it is an older vcr). If your TV is ok you should be able to see the tape which is playing. If not, and you still have snow you probably need a new tuner in the set. Let me know if you need more help.
hardrocko
Feb 05, 2010 | RCA P61939 61" Rear Projection Television
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 24, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
When tv is turned on with cable channels picture is snowy. when dvd or vhs tape played through tv the picture is snowy
Try using the video inputs
Nov 13, 2009 | Televison & Video
Snowy picture on VCR with only certain channels
In all likelyhood, you have a bad ground somewhere in the cable. Try other channels through the VCR. If the ground is the problem, there will be a cluster of channels that are snowy with the rest being clear. Check the cable itself and all of the connectors along it.
If the cable and connectors are good, the tuner or power supply of the VCR could be faulty and cause this as well.
Dan
Dec 24, 2008 | Sony SLV-N50 VHS VCR
Snowy screen on tv
the 3 or for setting on the vcr is on the back( a switch)
or if the cable box has a channel 3 or 4 setting on the back of the box
but otherwise the tv may need some work on the tuner or need a new tuner
Dec 01, 2008 | Philips CCC130AT 13 in. TV/VCR Combo
Blurry Sanyo TV
Well after playing around with the tv some more, I decided the problem was probably the cable jack, and tried running the video in/out cables thru the VCR to get around this, which I read generally works but in this case nothing. I had tried the tv on various settings, anytime I put the tv in "video" mode I'd get a blue screen and nothing else. Anyway I found a switch in the back of the Direct Tv box for ch. 3 & 4 settings. So I flipped it but still got a snowy picture, only this time it was on ch 4 instead of ch 3. By sheer accident I put the tv back in video mode while I had the satilites setting to ch 4, and the picture came up crystal clear. Since I didn't mess with it further, I'm not sure if it was the channel selector or the fact that hooked the tv up via the video cables, but whatever it was it did the trick.
I just KNEW this could not be a broken tv despite the fact that everhwere I read online suggested it was. I knew pictures can go out, or sound can go out....but to have BOTH go out didn't make sense to me. Anyway, glad its working! :)
Jun 15, 2008 | Televison & Video
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
290 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
