Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker does not dump - Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
  • 126 Answers
FROM WHAT I UNDERSTAND IS THAT THE UNIT IS MAKING THE ICE JUST NOT THROWING IT INTO THE HOPPER.IF THATS THE CASE ONE OF TWO THINGS COULD BE THE CAUSE.THE ELEMENT THAT LOOSINS THE ICE AT THE TIME OF DROPPING IS NOT WORKING THEREFORE THE ARM THAT TURS IS STUCK.OR THE ELEMENT IS WORKING BUT THE ARM IS NOT.BEST YOU GET A TECH TO SERVICE AND REPAIR THE ICEMAKER.GOODLUCK. MOHAMED
Posted on Sep 16, 2008
Why will the ice not dump? I replaced the ice maker because it was not turning to dump the ice after the ice was frozen. Same problem with new ice maker. Reset button causes the ice tray to turn, dump...
Your ice maker is controlled by the main board. The ice maker has a sensor that tells the board what the mold temperature is. The first step is to make sure your ice maker is turned on. There is an "on/off" setting on your control panel. Look very closely at the glass depicted. Some models show ice cubes in a glass, others have the words ice off. It's difficult to tell without looking close. If your ice is on, a Samsung qualified tech should be called to check connections, and the board.
Apr 29, 2014 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
No ice.
Pout about 2/3 cup of water into the ice maker . If it dumps but does not refill , replace the water inlet valve ( the piece the wall water line connects to behind the refrig ) . Also check the tube which fills the ice maker as it will freeze up , not letting water go into the ice maker . This is also caused by a bad water valve .
If the ice maker does not dump the water poured into it , replace the ice maker .
Also , check that the coils are clean under the front of the refrig , as this will cause slow ice production and can cause the ice maker not to dump due to too warm of temperature . Ice maker has to be 5 degrees to operate .
May 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker does not dump ice
IF THE ICEMAKER IS TURNING AND NOT DUMPING YOU NEED TO REPLACE THE ICEMAKER ***.
Jan 12, 2010 | Samsung Refrigerators
No ice Ice maker does not fill up with water
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then check the fill tube going to the ice maker , to see if it is frozen up inside . If it is , replace the water valve behind the refrig , where the wall water line connects to on the refrig . If the ice maker dumps the cubes , but does not refill with water , then the water valve is bad . If the ice maker does not dump the cubes , then replace the ice maker .
Nov 11, 2009 | Refrigerators
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Ice maker won't dump ice...seems to fill
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 17, 2009 | Refrigerators
Frigidaire not dumping the ice
Hi: Dumping the ice is the start of the ice making timer. Before you replace the ice maker... Set the freezer one setting colder. The ice maker wont make ice if the freezer is not at zero degrees F. Just because things are frozen in it dosn't mean it is at zero. This happens a lot in the summertime. After resetting the temp don't open the door every hour to see if it makes ice as you will just dump the cold air out. Listen for the ice to dump, give it 24hrs. I hope this helps, Jeff
Jun 06, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker not dumping ice
The freezer has to reach a certain temp. in order to freeze ive. You might have to wait overnight for ive-- keep the freezer closed.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
63 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
