Question about Acer AL2017 20" LCD Monitor
Acer AL 2017 Monitor
I saw you had the problem with the screen going black after a few seconds. Did you ever solve the problem?
  • used2bmom Mar 14, 2009
    Monitor goes black before I can even manage to click on an icon. Does this over and over, sometimes, until I can be fast enough to click on something. Other times, it will continue even when I do manage to be fast enough.
    Brigadier General:
  • 5,158 Answers
I just repaired one.... will likely require that you replace 3 X 220 uf 25 volt capactiros and 2 X 1000 uf 25 volt capacitors. can't miss them the tops are swelled up. but the monitor appears to work now... not bad for 5 bucks worth of parts.
Posted on Apr 08, 2009
Just fixed one myself. Here's a video and writeup of what was involved: http://www.fettesps.com/acer-al2017-repair/
Posted on Feb 28, 2011
My acer monitor model 2017, after all connection, the screen stay black. Is it something we can repair or I should change monitor.
Posted on Jan 09, 2010
How to solve acer monitor sleeping issue?
Press left mouse key and wait 10-15 seconds. Black screen and orange light is caused by computer going to sleep. Adjust your power mode.
Apr 30, 2014 | Computers & Internet
GOOD DAY,I HAVE AN ACER AL 2017 LCD MONITOR,I'VE HAD IT FOR 18MNTHS,AND NOW WHEN I SWITCH IT ON THE ACER SIGN ARE DISPLAYED IN A FLASH AND GONE,LEAVING A BLACK SCREEN,THE LIGHT IN FRONT STAYS GREEN.I'VE...
First place to check will be the bad caps with bulgign top in the power supply section, post back what you see inside so we can guid eyou further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 20, 2010 | Computers & Internet
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
ACER AL 2017 goes dark after half second of image.
I had the same problem with the same monitor. You could see the image, but extremely faintly. In my case, the problem ended up being the inverter board (Delta DAC-12M033), which I found refurbished on Ebay for $45.00. Takes about 30 minutes and about 15 screws to replace, if you are handy in that department. Just my $0.02 worth. Hope that helps!
Oct 02, 2009 | Acer AL2017 20" LCD Monitor
No signal issue
Sounds like you could have a capicitor problem, which is fairly inexpensive to have fixed - before going down that route - If you only connect up the suspect monitor to your PC and disable dual screen using the cables (power and signal) from the one that is working - does the same thing happen? if so then it's definately the monitior and most likely a capicitor.
Aug 23, 2009 | Acer AL2017 20" LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Acer AL1914 black screen, green light
it sounds like a deleted driver? try getting the driver for the monitor, did you loose the Operating system at some point, if so try a system restore to a date when the computer was working properlly prior to the malfunction. It sounds like it restored you to a time before the driver for that monitor was installed.
Feb 16, 2009 | Acer AL1914B Black 19 in LCD Monitor
ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Oct 12, 2008 | Acer AL1714CB (Black) 17" LCD Monitor
Acer AL2017 20" LCD Monitor Logo
1,015 people viewed this question
Brian Sullivan
Brian Sullivan
