Question about HP Scanjet 5590 Flatbed Scanner
HP Director missing from desktop
Installed software per manual. Scanner works with buttons on front of machine, but no HP Director appears on desktop or in ALL Programs listing.
  • 3 Answers
It may happen if you have version 7.0 of Internet Explorer.
Install the below patch on your system it will make the HP Director to work.
http://h30318.www3.hp.com/pub/softlib/software8/COL17377/oj-46104-1/CIT207355-HPCOM-PATCH-v8.exe
I hope it will work.
Posted on Oct 09, 2008
Sir, I have hp scanjet 2400 scanner. I formatted my system. Unfortunately I missed the installation CD. However I installed it from downloaded/installation CD (from my friend). The HP Director and HP...
The drivers of the scanner is not correct one, you need to un-install it and download drivers from HP web site by clicking HERE and then re-install drivers along with software.
Hope this will solve your issue. good luck
Mar 03, 2011 | HP ScanJet 2400 Flatbed Scanner
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
2-Without navigating to another open window, press Alt and Space bar at the same time.
The Shortcut menu displays near the top-left corner of the computer.
Figure 1: Shortcut menu
If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
3-Select Minimize from the Shortcut menu.
HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen).
If HP Director does not minimize, click Minimize again until it does.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
My scanner is not working. Can't open HP director on my laptop. I tried to reinstall CD that came with it, but " more recent version installed" Printer and copier work fine.
Here are some diagnostics.
1. Go to control Panel and then to scanners & camera.
2. look for your scanner there.
3. if you find your scanner there try to scan from the wizard and you will be able to scan you docs.
To Reinstall the Hp Director....
1. first uninstall the HP director software using the removal utility located in your cd...
The uninstaller on the Internet is newer and works better than the one on the CD-ROM. Use this method only if the Internet version is not available. Follow the steps below to use the CD-ROM version only if you cannot get the regular uninstall to work correctly and cannot access the Internet:
  1. Leave the USB cable disconnected from the all-in-one.
  2. Insert the all-in-one CD-ROM into the computer. Cancel or close any installation windows that appear.
  3. Right-click the Start button, and then click Explore . This will open Windows Explorer.
  4. In the pane on the left, locate the CD-ROM drive letter that contains the all-in-one CD-ROM.
  5. There are two different versions of the software for some of these models. Use the file path that pertains to your version of the all-in-one software.
    • Early versions of the HP Officejet 6100 and PSC 2100 and 2200 series: Double-click the file hposcr01.exe , located in the Drivers\Uninst\language (ENU for English, ESN for Spanish, FRA for French, or PTB for Portuguese) folder of the CD-ROM.
    • The newer software version: Double-click the file Cleanall.bat , which is located in the Util\CCC\Cleanup folder of the CD-ROM.
    ONCE THE SOFTWARE IS COMPLETELY REMOVED.RESTART THE PC AND TRY TO INSTALL THE HP DIRECTOR SOFTWARE FROM THE CD.
Let me know for any further help....
http://www.ikarmatech.com
Sep 08, 2009 | HP PSC 2410 All-In-One InkJet Printer
HP DIRECTOR NOT WORKING
the director will appear to not be working if the scanner is not installed and recognized by Windows. A scanner icon will appear on the desktop if it is recognized by Windows.
One likely reason it isn't being recognized is the power supply isn't putting out enough current, 1.25A, to force the correct signal level through the USB port. If the power supply is old, not plugged directly into the wall, or a substitute with the wrong current rating, the scanner will not send enough power through the USB port.
Jun 09, 2009 | HP ScanJet 2400 Flatbed Scanner
HP Director is missing
Follow the link I am providing, select your operating system, and the software should be listed under the "Driver" section. If this doesn't fix your problem, do you have Internet Explorer 7 installed?
Link to Software
Jun 06, 2009 | HP Compaq Presario SR1720NX (EL435AA) PC...
Can't find tool box to check ink level - HP 6310 using Vista 2007
doesnt matter most printers have a feature of their own to check ink levels.
press the setup button on the printer and scroll down(with the arrow buttons) till you get tools press ok and now scroll through until you get ink level and select it by pressing the ok button,walla you should have your ink levels in front of you.
Now about the hp solution centre/hp director icon on your desktop (if you have installed the software).
Click on settings and click on printer toolbox and now check your estimated ink levels it will show the ink levels of the printer cartridges.
May 26, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP Scanner 3570C-can not scan my slides
According to the manual, you should always scan from the HP scanning software to scan slides using Scanjet transparent material adapter. There is no button that you can set for default slide scanning properties. This is shown on page 8 of the manual for the 3500 series scanners. The manual is available here: https://www.manualslib.com/manual/72847/Hp-Scanjet-2300c-Series.html?page=13#manual .
Since the scanner works with pictures, make sure that the TMA adapter is plugged into the back of the scanner. Next open the software, HP Photo & Imaging Director. In most versions of Windows, press Start and look for the HP programs heading. Expand this to find the executable file. Alternatively, find the icon on the desktop or find the software in the file explorer (Program Files/HP/ on 32-bit versions, Program Files (x86)/HP) and then the appropriate sub-folder. Now try to scan the slides when they are loading in the adapter.
I hope this helps. Please add a comment with your OS if you are still having problems. Some newer OS versions may have installed generic drivers for the ScanJet 3570C. The generic driver might not communicate with the TMA properly.)
Jul 12, 2017 | HP ScanJet 3570cv Flatbed Scanner
Can't open Hp director
I read ur problem.This problem with HP director occurs if you are running Internet version (7.0).If u have difficulties knowing your Internet version, pls do the things mentioned below.
1.Open internet explorer->click help->then click on "about internet explorer".---There you will see the version of your browser.
SOLUTION.
If see an hour glass appearing and disappearing without displaying the HP director window after clicking on HP director, You got the following solutions.
Solution 1.
1.Double click HP director icon.
2.Then Press Alt + space key together.
Result:YOU will see a small pop menu appearing on the desktop screen.
3.Click on "minimize" on that pop up screen.
Result:Now u will see a tab on the taskbar.
4.Right click the tab(hp director),then click restore...Now you will see your HP director window.
Note: Above solution should be performed while trying to open HP director.(ie) You should try this every time if u want to open HP director.To go for full time resolution,then try solution 2.
SOLUTION 2:
1.Open "www.HP.com"
2.Select "software and driver downloads"
3.Type your product name in the "for product text box",then hit enter.{(eg) if u type 7410 for office 7410,then u have to select the exact model in the next window}
4.Select the operating system.(if u dont see a option to select operating sys, there u will see "software and driver downloads"
5.In the next page, you will see a list call "Updates" you have to download a update which says "
Critical update to resolve an issue with HP Director after installing Internet Explorer "
6.After downloading the update, run the file and thentry to open HP director it will open the director window.
This will work.I assure u total problem resolution
Regards
Chittaranjan
Dec 25, 2008 | HP Scanjet 3570 Flatbed Scanner
HP Director won't open. I am on XP and IE7
HP Director has a flaw and is not compatible with IE7
I have a psc 1100 and I had to update my software from HP
CHECK THIS OUT
Go to HP, this link, type in your printer model #.
It still may fail to show...if it does not show HP recommends this
work around.
Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
  1. From desktop, double-click the HP Director icon to load the program into the memory. HP Director will not open at this step. Do not click anything else on the screen until Step 2 is completed.
  2. Press the Alt key and the Space bar together, and then select Minimize from the menu that appears at the upper left corner of the window. If necessary, click it again until HP Director minimizes. HP Director software displays as an item on the task bar (the row of open software programs that appears at the bottom of the desktop screen).
  3. Click HP Director on the task bar. The software opens and displays normally.
  4. Repeat Steps 1 through 3 every time you use HP Director.
    NOTE: The HP Director window might appear larger than normal, but the software is functional.
Cause In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software on products introduced after 2004, is compatible with Internet Explorer 7 and does not exhibit this issue.
Apr 30, 2008 | Computers & Internet
HP PSC 1315
If the patch or the updates did not work on the link I sent you try this Workaround: Open HP Director each time you use it If the update to HP Director is not available, or if you have installed the update and the HP Director window still fails to open, try this workaround.
Mar 17, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP Scanjet 5590 Flatbed Scanner Logo
648 people viewed this question
Seeker5211
Seeker5211
