Question about Maytag Washing Machines
My Maytag Atlantis MAV6200AWW is making a loud roaring noise during spin cycle...any clues as to where to start???
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
SOURCE: grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Posted on Dec 29, 2008
appldoctom
  • 311 Answers
SOURCE: Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Posted on Jan 03, 2009
  • 17 Answers
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Posted on Oct 24, 2009
  • 12 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Posted on Nov 17, 2009
Maytag Top Load Washer MVWB850YW making loud noise in spin cycle.
If it's a roaring noise, the tub bearing is probably wearing out. Spin the tub a little with your hand, if you hear a little of the roar, that's it.
Nov 26, 2013 | Maytag Bravos Series MVWB850YW 28"...
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Spin cycle
  Did it make this noise just when it stopped spinning.  Just for a couple seconds?  If so,  it's only brake noise and not a concern.  If it does this all during spin you probably have a bad tub bearing.  Is it a roaring noise?  This is what the bearing will sound like.
Oct 28, 2007 | Maytag PAV2300 Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
