Question about RCA P52955 52" Rear Projection Television
Channels change by themselves ??? please help
I had this problem once before and i had it serviced i think they changed the main board but not sure and now its starting again and ide like to try to fix myself. i am experienced in electronics and am not afraid of alittle soldering. well the problem is simple. when i plug the power in and leave the tv on for about an hour it will start changing channels by itself. i checked and it is not the remote control. please help.
  • anthony ramirez Apr 01, 2006
    thanks i apreciate the help big time.
CHANGE ALL THE PANEL BUTTONS IT ALL.
Posted on Mar 30, 2007
    President:
  • 3,130 Answers
Its mosy likly the remote control sensor inside the set. had the sam problem a couple of times already. I'll post the part # when I can find it
Posted on Mar 31, 2006
SOURCE:
I PURCHASED A SAMSUNG MODEL HLN43W REAR PROJECTION TV FROM CIRCUIT CITY ON 05/22/04 WITH A TWO YEAR PROTECTION PLAN. AFTER 6 MONTHS FROM DATE OF PURCHASE THE CHANNELS STARTED CHANGING ABOUT EVERY SECOND...
the circut board beneath the power /volume/and channel up -down has carbon switches the carbon switches are corrupted and that board needs to be replaced
Apr 02, 2008 | Televison & Video
Toshiba LCD TV 37AV502U wont change channels buttons on side unresponsive
Hi Michael,
The buttons themselves might be defective but it is very unlikely that all of them would become defective at the same time.
I would suggest to open the TV and check for any loose connections between the main board and the buttons board assembly.
Let me know if you need further assistance.
Mar 07, 2017 | Toshiba Televison & Video
How do I fix not switching from standby red light to on green light?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 15, 2015 | Televison & Video
Crashed syma s33 had to replace both rotor shafts and tail motor now it will only scoot along thee floor?
I think that once you change a main part then the way these birds are made you have to change the board, battery gutt it out.
Mar 12, 2014 | Syma s33 3 channel rc helicopter 2.4ghz...
Dc92 00240a
please go to the manufactures website and ask for a service manual and follow the guide to help you but I would stay away from the electrical circuits if you are not familiar with the ins and outs of theses electrical circuits as the AC mains circuits are lethal to the everyday person without electrical knowledge eric
Dec 20, 2017 | Washing Machines
47LG50 channels change themselves
Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 09, 2011 | LG 47LG50 47 in. LCD HDTV
I can't change the volume or channel using the tv control.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 02, 2017 | Proscan 32LC30S60 LCD TV
Changing channels
A common issue with this model is the control key board (the key input board that has the buttons on the cabinet of the TV).
This board can cause a lot of issue ,from changing channels by itself,to intermittent shut off, also sources cannot be switched or they switch by themselves.
The less common issues would be the remote eye or the main board.
If you give the full model number and the product code from your TV, I can give you the part numbers.
Apr 01, 2010 | LG 22LG30 22 in. LCD HDTV
None of the buttons on teh buttons on the television or the remote will work. I cannot change inputs, volume, channel or control the dvd player.
Unfortunately, both the local controls and the remote are controlling an integrated circuit on the main board that does the actual work. I think you can expect to have the main board replaced or exchanged and this won't be cheap if available at all. I think this company is related to the infamous 'Ilo' that was once sold by Mall-wart. They were bankrupt but the leftovers may still be available.
Oct 19, 2009 | Initial HDTV-322 32 in. LCD Television
RCA P52955 52" Rear Projection Television Logo
89 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
