Question about Mitsubishi WD-62525 62" Rear Projection HDTV
NO POWER TO LAMP FAN
If i put power to the lamp and exhaust fans they both work but wont work when turning on the set. There is a fan on the top left of silver box on back of set that work when turning on the set. Can someone tell me what supplies power to the lamp fan?
  • mvick Sep 10, 2008
    does anyone know witch fuse or fuses on the power board run the fans?
  • Mitsubishi Master
  • 8,617 Answers
The problem is the capacitors on the power PWB have failed. You can get the V26 Power pwb repair kit at the following link which contains the replacement capacitors and instructions. Heres the link its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Posted on Sep 26, 2008
I have a toshiba 52 hm 95 that's 6 years old. The
If the fan was bad it would take a bit more than 10 minutes for the lamp to be destroyed as the set monitors the temp of the lamp constantly.
I would actually suspect if a genric lamp you got two bad ones OR the Lamp ballast that fires the lamp is bad, ballast is most likely the issue.
Dec 20, 2012 | Televison & Video
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Fan issue with hd-52g787 52 inch
The lamp is protected if fan does not work it has a thermal fuse that will cut power to lamp etc.
One of the real issues is the fans intake air from front of set and exhaust it out rear---sets and fans get coated with fine dust and cause problems including in some cases set shutting off.
Apr 29, 2012 | JVC HD-52G787 52" Projection Television
WD-62531 fan
If the fans aren't operating then the set shouldn't stay on or even turn on. If its the main lamp exhaust fan then you are looking for part number 299P288010. They are relatively easy to replace as they only have a 3 pin connector that will plug into the main board or the power supply. Verify its that fan and as always if you replace it yourself make sure the set is unplugged. Once replaced the back will have to be re-installed or the set will not work as it has a safety switch that detects when the lamp door is off and on.
Jun 29, 2010 | Mitsubishi WD-62531 Projection Television
Replaed lamp and it won't power up. fan is on but
Please check lamp door that seems not fixed / seated properly. Lamp door / cover push a safety switch that is not being pressed and causing no power up of TV.
Jun 26, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Lamp wont stay on. fan continues to work after lamp goes out. When power is turned on light comes on and fan starts working. with in a second or so the lamp turns off but fan continues to run.
Most likely you need to replace the lamp. It is possible the your lamp ballast is failing as it scales back to low-voltage DC drive, but more often than not this problem is traced to the lamp needing to be replaced.
Mar 29, 2009 | Office Equipment & Supplies
Tv does not power on
This is a bad fan. There are 4 fans in the tv. Any one of them can cause this. Here are the part numbers:
Lamp Fan FAN-LAMP 299P282010
DMD Fan FAN-DMD 299P283010
Ballast Fan FAN-BALLAST 299P278020
Exhaust Fan FAN-EXHAUST 299P103050
Aug 05, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-52725 FAN?
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
33 = Air filter cover is open.
44 = DVI cable between FMT and Engine disconnected
Dec 24, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
