Question about Pioneer Televison & Video
Focus problem on pioneer RVD-XG10 projection unit
I need user manual for a sherwood RVD-9090RDS
I have the user manual for sherwood RVD-9090RDS with me. As it is pdf file i can't sent the same through the Fixya. If you can provide your email id then i will sent the same to you email address.
Sep 11, 2011 | Sherwood RVD-8090R Receiver
Tv turns on but after about 30 min a popping sound is heard and it loses picture
main power source could be high due to a voltage regulator circuit malfunction or hv unit, focus devider starting to leak. Might be a good idea to have a qualified tech take a look at it, those hv components can get expenssive.
Jan 09, 2010 | Pioneer PRO-510HD 53" Rear Projection...
Can anyone help with programming a pioneer remote to work with toshiba vcr/dvd combo unit? thanks!!
Its Not Happening pioneer is for thier product only/as well as toshiba. Go to dollar store $5.00 rca hand unit will program up to 4 different things will have codes for pioneer and toshiba.
Sep 24, 2009 | Pioneer PRO-610 58" Rear Projection...
Focus not sharp
Yes, you can adjust the focus of the CRTs without causing other issues if you exercise some care in the process. There are two types of focus adjustments in your TV, electrical and optical. The electrical focus is more likely to change over time than the optical focus. That's because the optical focus is mechanical and would likely only need adjusting in the event of a CRT replacement. The electrical focus controls are located behind the front speaker grill and the front access panel. Pioneer TVs will either have pop-on/off connectors where all you need do is grab and pull, or it may have a few philips screws securing the grill. The screws are generally hidden behind the plastic molding strips just above the grill assy. (they are snap on/ pull off) There will be a small, black control assembly located behind the access panel. There will be 3 focus controls and 3 screen controls. The screen controls adjust the intensity of each CRTs brightness.
Feb 16, 2009 | Pioneer Televison & Video
My pioneer sd-m1407 has a poor picture
Start out resolder all poor connections on power supply board all pinns on FBT see what happens after you do this! Also clean mirror and top of tubes lenses .
Feb 16, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Red shadow?
call a tech and have them converge the tv.its either that or the focus
Jan 02, 2009 | Pioneer PRO-119 60" Rear Projection...
Have you attempted to adjust the brightness setting?
Jul 26, 2008 | Pioneer PRO-520HD 53" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Pioneer 510-HD
EchoKaos may not have resoldered his PS board, which most units in that line need. This will most likely solve the problem. A virtually complete resolder is needed on that board, not just the obviously problem areas.
If not -
If the hor lines are upward and curved slightly and a couple of inches apart, then the blue Screen trimpot on the focus block is most likely turned up too high. When turned down the lines will disappear.
This mucks with your grayscale, but then it's trashed anyway by now, and after reducing it, you will have to do a new grayscale on your set, or have one done by ISF. Or a tech who knows how to set the Screen controls, since ISF does not teach that.
Mr Bob
Nov 17, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
