Question about Sony Playstation 3 (PS3) Console
PS3 contro panel doesn't show
I have a problem that when i turn the console ON I can't see the control panel but i still can hear the sound when i move between the options. However, when i select a game, it shows up and i can play the game just fine. When i quite the game the screen comes black again.
has anyone heard of this problem and has a solution?
Thanks in advance for your help
  • Anonymous Sep 11, 2008
    MY PS 3 HAS EVERYBODYS PROBLEM
    IT WORK FINE AT FIRST THEN IT DID'NT READ MY BLUE RAY DISC,
    AND NO LONGER READS MY GAMES. I CAN'T EVEN SEE OR HEAR MY CONTROL OPTIONS ANY MORE IT JUST SHOWS THE WAVES THEN FREEZES.
  • 23 Answers
I think your best bet for this is to call Sony. Seems like a hardware problem.
Posted on Sep 14, 2008
My problem is earlier today i was playing my ps3, the picture was showing on the t.v. ( a HDMI Cable conected it to the tv), but 30 minutes later, i tried to play my ps3, the picture was not showing up...
Sounds like your video settings are wrong. Since you were on the HDMI connection the video was outputting in HD. When you switched over to normal AV (composite) cables the video was still outputting in HD.
Simple fix: power off your PS3 (so it's in standby; red light is showing). Then turn it back on, using the power button on the console (not the PS3 controller) and hold down the power button until it beeps a second time (about 5 seconds). The video settings will reset to composite. If needed, change your video settings.
Normally I'd put down like 3 other things it could be (each worse than the last), but I'm fairly certain that this will fix it. If it doesn't, just say so and I have many a more potential fix available.
Hope it works!
Sep 24, 2011 | Sony Playstation 3 (PS3) Console
I bought my ps3 in london and now im in Paris the ps3 turns on but wont turn off and it doesn't show up on the screen and the controller keeps on beeping none stop
Easy to solve, the way to turn off the ps3 is simply hold the power button until you hear one beep, then let go. That way you wont have to go to the menu, and your controller beeps because it is low on battery try using a charger that connects to the ps3
Jul 06, 2011 | Sony Playstation 3 (PS3) Console
Cant get picture on psa3 slim hdmi or av
conect your ps3 with hdmi to TV then put your TV on hdmi by its remote controler, ps3 is still turned of. Then press switch of/on ps3 buton and hold it for 5 - 7 second cca., You will hear a double beep sound and after that you can turn your ps3 on. Then just follove the instructions.
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
Turned off incorrectly, now it won't show desktop
Dear,
you may try to use the PS3 recovery options.
The PS3 stores a copy of firmware drivers on the hard-drive and will reload any corrupt files. To access the recovery menu, do this:
  1. Make sure the PS3 is turned off
  2. Press and hold the power button on the PS3 it will power on then power off.
  3. When it's off press and hold the power button again until you hear two consecutive beeps. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
  4. It will ask for the controller to be connected via the USB cable,
  5. Turn on the controller and you will have access to the menu.
Please rate my solution ++++ if it was helpful, or feel free to ask for more information. Thank you
Peter_Rei
Aug 01, 2010 | Sony Playstation 3 (PS3) Console
Connecting sony surround sound system to tv
i had the same problem what i did was conect a optical cable from the tv to my surround sound and hit the viera link button then i was able to change from tv speakers to home theater which automatically turned on my surround system and set it on the right mode to work cool feature now i dont even need all my contro i can turn on my ps3 and surround system with my tv control
Jul 11, 2010 | Panasonic TCP50C2 50 in. TV
My ps3 will turn on but wont show a picture on the tv or give sound
Reset the video settings by turning on the ps with only the power cable plugged in, when turning on continue to hold the power button until you hear a second set of beeps then turn off the console.
Boot up the ps and plug in your av/hdmi cable and you should have picture and sound.
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
Powers on, Controller wont connect, nothing shows up
switch the hard switch off in the back of the ps3. unplug power cord... press and hold power button located on the front f the ps3 for approx 10 secs, then let it sit for a few, then hook it back up and turn the hard switch back on and try to power it back up.
I have had this happen once before but it did return to normal.
Nov 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 80 gig
Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Picture on tv isn't appearing and controller not connecting
The only easy fix i know is to turn the console off and then press the power button until you hear a second beep. Hope this helps.
Mar 15, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
