Question about Aiwa Audio Players & Recorders
How do I get a casette tape out of the #2 side of the player? It will not open?
  • 3 more comments
  • YUKON JOE Sep 10, 2008
    HOW DO I GET A CASSETTE TAPE OUT OF DOOR 2 ON THE PLAYER? IT IS STUCK AND WILL NOT OPEN.
    HOW DO I GET A CASSETTE TAPE OUT OF MY PLAYER?
    MODEL NSX-MA845.
    tRIED THE COMMENTS OF TRYING TO RELEASE DOOR, BUT UNABLE TO GET A FEELER GAGE INTO SYSTEM TO DIS INGAGE PINS. THEY ARE LOCATED TO FAR IN THE CABINET. ANY OTHER CHOICES?
    model # is nsx-ma845 six or seven years old.
    stero,cd,2 tape decks with surround sound. I'm having problems removeing tape out of deck 2. nothing has worked so far,any futher suggestions?
    thats not an answerr to possible break the door. the tape is unimportant in this case, but the stero tape deck is.
    Genius:
  • 2,035 Answers
You get it removed from a local audio service center for very small price,or First you need get the service manual for this player remove the player front screen and then remove cassette .,Please click on this link
http://www.stereomanuals.com/man/rep/aiwa/aiwa019.htm to get a service manual...
Good luck...
Posted on Sep 10, 2008
  • 3,037 Answers
If this isn't under warranty, then start by unscrewing the screws holding on the outer panel, most of them will be located at the back of the system. Make sure you have the power off before attempting any work. Once you have the outer panel off, you should be able to find the screws and parts that hold the cassette in and start disassembling them and should be able to free the tape. If you run into any problems let me know.
    President:
  • 1,952 Answers
Use for solved your problem,clink link
http://home.wanadoo.nl/syntigroep/manuals.htm
  • mohammed marika thambi
    mohammed marika thambi Sep 10, 2008
    Operating Our Cassette
    Player
    Background
    Our cassette player, known as a C-1, plays recordings at commercial
    speed and half commercial speed. NLS/BPH distributes its talking books
    on standard audio cassettes designed to play at half commercial speed
    and using four tracks. The NLS configuration can pack up to six hours
    of reading time onto one cassette. The C-1 side- and speed-selector
    switches enable readers to play cassettes created with the standard,
    commercial configuration as well as the NLS talking-book configuration.
    The C-1 player is shipped with a fully charged, rechargeable
    nickel-cadmium battery that will operate the player for about six hours
    after being fully charged. Simply plug the player into a standard
    household outlet to recharge it. Remember, you can always call your
    library about using the NLS/BPH player.
    Using the Standard Cassette Player
    You can operate the C-1 on its battery, or you can take the power cord from
    the recessed area in the back of the player and plug it into an electrical outlet.
    Here is a typical sequence for reading an NLS cassette talking book.
    1. Open the tape compartment door by pressing the eject key, far right and
      marked with a raised square.
    2. Insert the cassette, label side up, with the tape edge facing out. Seat
      the cassette by pushing it back until it clicks. Press the compartment door
      down until it clicks.
    3. Press and lock down the play key (green with a raised circle) to start
      the player. Adjust the volume slide switch (nearest the front edge of the
      player).
    4. Stop the player at any point by pressing the red key with a raised "x",
      first on the left.
    5. To review the cassette soundtrack, press rewind, the key between play and
      stop with the raised less-than sign, or arrow head pointing left.
    6. To advance the cassette soundtrack, press fast forward, the key between
      play and eject with the raised greater-than sign, or arrow head pointing
      right.
    7. To remove a cassette from the player, make sure it is stopped. Press the
      eject key, far right with a raised square. The tape compartment door will
      snap up, and the tape will pop free of its seated position. To play the
      next side, turn the tape over (print/braille label down), reinsert, seat
      in the door, and press the door shut. Then press the start key. After reading
      sides 1 and 2, rock the side selector switch to the right to listen to sides
      3 and 4.
    Tips
    Switches and Buttons
    Speed, volume, tone and side-selector switches are on the right of the player.
    Begin at the top of these controls, in the middle of the player as you face
    it, and you will find the following:
    Variable Speed Control
    Used to slow down or speed up the reading of the book. The voice
    of the narrator becomes distorted as the playback speed is changed.
    Speed
    A different sort of speed switch is just under the variable
    speed control. This is the speed switch that is used to match the speed of the
    player with the recording speed on the cassette. It is a rocker switch. Press,
    or rock it down, to the left (15/16) for our talking books. Press, or rock it
    down, to the right for commercial cassettes.
    Side-Selector Switch
    Another rocker switch, the side-selector switch enables readers
    to listen to both commercial and talking-book cassettes. Here are the things
    you should know about talking-book cassettes before you use the side-selector
    switch:
    • Talking-book cassettes will appear to be oddly numbered because of the
      four-side (or, four-track) system. The first side of the first cassette
      will be 1. The first side of the next cassette will be 5. Then, 9 and so
      on.
    • Turn the cassette over after each side.
    • When starting with side 1, push the side selector switch down to the left,
      marked 1-2. Do not change the switch to listen to side
      2.
      Push the side-selector switch down to the right for sides 3 and
      4. It is important to be methodical about the use of the side switch, or
      you may find yourself skipping whole segments of the book.
    • As guidance, the narrator will provide instructions at the end of each
      side.
    Tone Control
    This slider switch raises (to the right) or lowers (to the left)
    the pitch of the narrator's voice.
    Volume control
    The volume control is also a slider. Louder to the right, softer
    to the left.
    Battery Maintenance
    To maintain battery life, the player should be played frequently unplugged,
    on battery. After several hours, up to six or until the battery fails, plug
    the player back into an electrical outlet to charge the battery. The player
    will operate, plugged in, while the battery recharges.
    Do not remove the battery. As a nickel-cadmium product,
    it is toxic if not disposed of properly. If you suspect the player will not
    work because of battery problems, call the library serving you. They will arrange
    for a replacement player.
    President:
  • 624 Answers
Take the top off of the deck, as you look at the #2 deck from in front of it you will need to work with the right side. After the top is off, look at the deck where there are 2 flywheels. The flywheels are the wheels with the belt around them and they are the big one's right next to each other. Most tape decks have 2 flywheels, if it has auto-reverse it will have 2 flywheels. You will need to rotate the flywheel on the right side of the deck (when looking at it from the front). While rotating the flywheel (counter-clockwise if looking from the front, clock-wise if looking from the back) you need to manipulate the solenoid. The solenoid has a metal plunger coming out of it and that is what you need to either press in or pull out just a little. That will engage the head unit with the gears and while rotating the flywheel you will notice that it is engaging from the feel of it. Keep rotating the flywheel and each time you notice it engage the head assembly try to push the eject button. If it doesn't open the first time, manipulate the solenoid again. Sometimes it may take 3 or 4 times, sometimes it only takes one time, it just depends on what part of the cycle the gears are when you start. Each time you manipulate the solenoid it goes to another function of the tape deck. You need it to be in the position it would be in if there is no tape in the unit. You should do this with the power cord un-plugged for your own safety. You do not want to shock yourself.
If you get it in the proper postion and the door only opens a small amount and the tape is still stuck, you probably have tape from the cassette wrapped around the capstan and will be much more difficult to remove without damaging the head assembly. If you find yourself in this position, stop there and let me know. I will give you further instructions so you do not damage the head assembly or the capstan, but the tape would pretty much be history.
I hope this helps, and if so, please rate this solution.
Dave
  • Dave DeGain
    Dave DeGain Sep 10, 2008
    Is this a bookshelf stereo with the tape decks on the bottom? If so, the flywheel you need to turn is the closest one to the outer edge of the unit, on the right side while facing it. Turn the flywheel with your finger and manipulate the solenoid with a small screwdriver or your finger it you can reach it. It only need to be moved a very small amount. If you force it open you risk breaking the head assembly and the capstan.
  • 344 Answers
Pry that ****** open with a Med size flat head screw driver!!! That'll sure do it good. Can't guarntee that the door wont break, but you'll get your tape back!!
  • Wes Sydenstricker
    Wes Sydenstricker Sep 10, 2008
    Your original question was "How do I get a casette tape out of the #2 side of the player? It will not open?" I told you how to open it. I should get the "FixYa" rating!!!
    Brigadier General:
  • 3,614 Answers
To remove tape, insert proper tool under cassette door and carefully spread brass or plastic slotted door brackets just enough to release it from two opposing pins on the cassette holder. Hinge door away from camcorder and remove it completely at the pivot point.
  • micromaster
    micromaster Sep 10, 2008
    hope this initial info helps you..
    kindly rate my solution here.
    -or just let me know if you need more assistance.
    regards
    micro
  • micromaster
    try using the handle end of a butter
    knife to gently push down on the cassette to see if it would release.
  • 4,472 Answers
Have you taken the case off the player? You will need to take it apart.
Thanks,
Lee
  • Lee A.
    Lee A. Sep 10, 2008
    In that case your best bet is to have a professional service it if you care about the unit that much. My recommendation would be replacement. Tapes are for the most part obsolete. If you need any further assistance finding a repair facility or any other questions on the issue let me know.
    Thanks,
    Lee
    Sergeant:
  • 241 Answers
Hello Have you tried to open it with a tool or the button inside may me sticking I would look at the Spring this could be off the tape door
  • 15 more comments
  • Jayson Brollini
    Jayson Brollini Sep 10, 2008
    the sping is small but is attached to thae lever that hold it into place .Tou may also want to look at the button on the 2 tape deck if that is push in
  • Jayson Brollini
    the tape may have came unwound from the spool/tape so if you can look through the tape deck window see if it looks ok
  • Jayson Brollini
    If my suggestion were helpful YUKON JOE
    please "rate" my solutions
    thank you and please post for more help
  • Jayson Brollini
    Yes ok if you can see my other posting Go ahead and inplug it from the wall or if the back of the reeciver it needs to be all shut down wait a minute and plug it backinto the wall . This should eject it
    Also try and hold down the eject button and while you plug it back in the wallthis may help too
  • Jayson Brollini
    If the tape still does not eject use a small thin screwdriver and hold the tape deck door try to wedge the flat head i an becareful not to use to much forc. You are only try to trip the lever to activate the Sping
  • Jayson Brollini
    Check your remote the eject tape button is located on there sometimes
    Make sure that all the buttons on the TAPE play rew. etc or not pushed in
  • Jayson Brollini
    If you are still having truobles
    just leave a comment
    Thank you ;)
  • Jayson Brollini
    do you have the owners manual (what language)
  • Jayson Brollini
    i have uploaded the manual so the Awia show that you may have the tape deck #1 pushed on LOCKED unlock it
  • Jayson Brollini
    The tape deck is on pause see if the solve it
  • Jayson Brollini
    There are no other reason if the Awia will not eject I looked
    and the portable stereo has the push tabe style buttons
    it may possible that the are sticking or the tape as started
    to come onwound. The best advise would be TRY to turn the
    reciever upside down and see if this helps Eject or if you can pry open
  • Jayson Brollini
    if no other solutions work just take the 6 screws out and lift the top of (shell) this will let you get at the Lever.
  • Jayson Brollini
    plz rate thank you
  • Jayson Brollini
    you are going to have to take it a part simple and easy
  • Jayson Brollini
    I have looked at this model and the portable stereo is
    very small. The chances that there is a tape in it and the
    it just sounds like the tape is jammed in wrong. Forcing out
    will break the tape and the door. There should be two C-clips
    on the bottom of the door. One on each side and from there
    you are going to pop off those two Metal clips. The are holding the door on to the stereo
  • Jayson Brollini
    look at my cooments
  • Jayson Brollini
    Have you not found any comments helpful
My cassetteplayeris broke but the front panel says tape unpluged it radio won't play pluged it back in few days later tharadio came back on.going down the road it swithched from radio playing back to tape...
the cage mechanism of the cassete is dropping causing it to shut the radio off ,only solution is to remove the radio and open case then jam the cage into the no casette position with a piece of wood or a folded up cardboard ,i think this will cure the problem
Feb 15, 2011 | Car Audio & Video
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
Ipod casette adapter problem 1996 sable
buy a different tape adapter the one you have is too loose or you deck needs both wheels to turn 1 driving the other if this doessnt happen it will keep changing sides
Jan 02, 2010 | 1996 Mercury Sable
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
Sony dual casette player/recorder
Unit may have slipping drive due to defective belt or tape may have wrapped around captsan. Have serviced
Jul 28, 2008 | Sony Dual-Deck Cassette Player/Recorder...
Clicking
open the cassette holder and use a pen to push down on the carrier. So long as you don't try to use it again it should stop
Jul 09, 2008 | Sony MHC-RXD3 CD Shelf System
USING IN MY CAR
There are no adapters SPECIFIC to this unit - if your car has a casette tape player, buy a casette adapter for mp3 players
May 11, 2008 | iLO (2 GB) MP3 Player
Loud clicking
Open the cassette deck and use a pen to push down the heads. After this it probably works better to avoid using cassettes in this machine.
Feb 16, 2008 | Sony MHC-RXD3 CD Shelf System
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Put tape in new video cassette
TAKING A GOOD QUALITY TAPE FROM ONE CASETTE AND MOVE TO ANOTHER WITHOUT HARMING THE TAPE QUALITY: TAKE A NEW, GOOD CASETTE AND UNSCREW THE 5 SCREWS HOLDING THE TWO PARTS OF THE CASETTE TOGETHER. AT THIS POINT DO NOT OPEN THE CASETTE. TURN THE CASETTE UPSIDE DOWN (SO THAT THE SIDE WHERE THE SCREWS CAME OUT IS NOW SITTING DOWNWARDS ON A FLAT SURFACE) IF YOU OPEN THE CASETTE BEFORE TURNING IT UPSIDE DOWN, ALL KINDS OF SMALL PIECES WILL FALL OUT AND YOU WILL NOT KNOW WHERE THEY CAME FROM. NOW GENTLY SEPARATE THE TWO PARTS OF THE CASETTE AND PAY ATTENTION TO EXACTLY WHERE THE TAPE RUNS THROUGH VARIOUS SPINDLES, ETC. MAKE A SKETCH IF THIS WILL HELP YOU. GENTLY LIFT OUT THE TAPE AND REPLACE IT WITH THE TAPE THAT WAS IN THE BROKEN CASETTE. THIS IS ASSUMING THAT THE ONLY DAMAGE WAS TO THE CASETTE ITSELF AND NOT THE TAPE. REPLACE THE TOP PART OF THE CASETTE (WITH THE SCREW HOLDS STILL FACING DOWNWARDS). HOLDING THE TWO PIECES OF THE CASETTE TIGHTLY TOGETHER, TURN IT OVER AND REPLACE THE SCREWS. TRY NOT TO HANDLE THE TAPE ITSELF. I HAVE USED RIGHT FITTING SURGEON'S GLOVES WHILE DOING THIS, BUT REALLY DON'T KNOW IF THEY HELP, BUT THEY DO KEEP THE NATURAL OILS OF THE FINGERS OFF THE TAPE.
Feb 26, 2006 | JVC HR-J461MS VHS VCR
184 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
