I have a 2000 Audi TT, I have the bose stereo system and the message of err1 flashes on my screen. I have tried to clean the cs lens via a cleaning disc.
Isuzu Rodeo 2001 6 cd changer error 1. I have disonnected the power and it did not help. Any sugestions would be apreciated.Isuzu Rodeo 2001 6 cd changer error 1. I have disonnected the power and it did not help. Any sugestions would be apreciated.
AnonymousMar 28, 2014
The check engine lime on and it was diagnose as a P2181 code for cooling system performance. The temperature thermostat warms up right in the middle so what to do?The check engine lime on and it was diagnose as a P2181 code for cooling system performance. The temperature thermostat warms up right in the middle so what to do?
You can't post conmments that contain an email address.
why would disconnecting negative from battery be solution for reverse lights?why would disconnecting negative from battery be solution for reverse lights?
The Bose amp has probably died. The head unit does not power the speakers. It's located behind a panel in the drivers side rear quarter panel. Do a simple web search, it's well described.
I have a 2001 Audi tt and I've read a tonnnn of columns about how to use the fader.... The best answer I've gotten is that because the tt cabin is so small, the fader has no use, and is basically just there to keep uniformity in the console. As for your second problem, that isn't happening to me. The only thing I notice is that my driver's side speaker is much quieter than the right side, but that is probably from overuse by previous owners. (purchased the car in May 2010)
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
0?xxxxx: Model
1 = Lamborghini
2 = Audi A3 (8P)
3 = Audi A4 (8E)
4 = Audi A4 Cabriolet (8H)
5 = Audi A6 (4B)
6 = Audi TT (8J)
7 = Audi R8 (42)
0x?xxxx: Treble Speaker Monitoring inactive
0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
0xx?xxx: Sound Characteristic
0 = Sound Characteristic linear
1 = Audi A4 (8E)
2 = Audi A6 (4B)
3 = Audi A4 Cabriolet (8H)
4 = Audi TT (8J)
5 = Audi A3 (8P)
9 = Sound System
0xxx?xx: Telephone/Telematic
1 = Telephone not installed (Remote Feed Voltage for Microphone active)
2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
6 = Telematic US (Remote Feed Voltage for Microphone inactive)
7 = Base Plate diagnostic capable with Comfort Control
0xxxx?x: Equipment I
1 = Tuner not installed
2 = Digital-Radio installed
3 = Satellite-Radio installed
4 = Satellite and Digital-Radio installed
5 = Analog Input (AUX) installed
7 = Satellite-Radio & Analog Input (AUX) installed
0xxxxx?: Equipment II
1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
2 = TV-Tuner installed
3 = CD-Changer installed
4 = TV-Tuner and CD-Changer installed
5 = Multi-Function Steering Wheel installed
6 = TV-Tuner and Multi-Function Steering Wheel installed
7 = CD-Changer and Multi-Function Steering Wheel installed
8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference
The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution. If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
43 = Audi A3 (8P) / Audi TT (8J)
45 = Audi A4 (8E)
Channel 003: Language (Screen)
0 = German
1 = English (UK)
2 = French
3 = Italian
5 = Spanish
6 = Portuguese
7 = English (UK)
Channel 004: Back-Up Camera
0 = Back-Up Camera not installed
2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
0 = max. 0 kph or 0 mph
1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
0 = Europe/North America
1 = Australia/South America
2 = South Africa
Channel 011: Language (Speech Recognition)
0 = German
1 = English
2 = French
3 = Italian
5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control
module coding, e.g. a S3 start screen doesn't work with an A4 coding.
0 = Standard Start Screen
1 = Audi S3 Start Screen
2 = Audi S4 Start Screen
3 = Audi RS4 Start Screen
4 = Audi TT Start Screen
5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
the little dial on the side of the date and time screen, you pull it out once and the hours will start flashing and then you turn it to get the desired hour and then pull it out again to get to the minutes and so on...
if you have just replaced the batteries this procedure should work if not get back to me and we will try the next step.................
press lock or unlock button
manually lock and unlock drivers door within 30 seconds
system should now lock and unlock vehicle
