First, you must not use the front usb ports on your cpu. You must plug your zune device in the back usb port. You must then download the LATEST Zune software. Install it and restart your computer. If done correctly, your Zune device will begin to charge and start working correctly. Have fun with your device
The Zune website has the Zune software which must be downloaded for your computer to communicate with your Zune.
And when you connect your Zune to your computer it should begin charging (as I'm assuming this is a new device).
If you have already installed the software I would assume the low battery was slowing the communication between your Zune and your computer.
If you Zune is fully charged and the software is fully installed try plugging the USB cable into a different port. Sometimes the Zune and the connector USB isn't automatically sensed on certain ports and certain moments.
i had this problem too, i would plug the zune into the computer trough usb cord, and have your zune home page come up automatically if it doesnt click the zune software shortcut. Go to top corner and go to settings, after that go to device and syce options. finally you need to press erase all content and your zune will be clean and rebooted up. when i did this my zune turned on and was back to normal, the only thing that sucked was that it took so long for me to figure this out and i had to syce everything back on my zune agian
e mail me if you have anymore questions at [email protected]
i can also help you with many other microsoft problems
microsoft is aware and looking for a solution. this happened to every 30g owner. here is the website for the right forum... http://forums.zune.net/403986/ShowPost.aspx check the zune site for updates
Try this.... Reset Zune: Press and hold the back button while pressing up on the control pad. Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps
ALL YOUR BASE BELONG TO US - is a video that must have been loaded on the Zune previously.
if all else fails...
If you connected the ZUNE to your computer before installing the software the computer may have installed it as a different device.
Go to Control Panel - then System - Device Manager. Plug in ZUNE player and see if any new devices show as being connected. BE CAREFUL IN DEVICE MANAGER THOUGH, IF YOU UNINSTALL THE WRONG ITEM, IT COULD MESS YOUR COMPUTER UP.
well? This sounds like you have the wrong cord. It is too short and so it gets power every now and then and then after doing this for a wile it gets over heated. The power going into the Zune is changing so fast that it is causing the plug to burn-up inside itself!
I wound try to call about a warranty and then if that doesn't help then get a new cord!!!
