Pioneer SD-P55A3-K 55" Rear Projection Television Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pioneer 47 inch big screen, was getting dim but would flicker back to normal, now there is just no picture at all but has sound
Anonymous
Level 2:
Sergeant:
  • Expert 181 Answers
  • Posted on Aug 29, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
181
Questions
Helped
18479
Points
520
Sounds like you got a bad connection, that has finally come off.
Moving those big things can cause that.
Open the back and check.
And call an expert.
If ya in VB, I'll do it.
PLEASE RATE THIS ANSWER
Tv turns on and screen flickers on for a second and then turns off, whats the issue?
Sounds like Back - light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS].In such cases, the power supply board might need replacement.To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself.If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board.If this is the case, you have to replace the main board.
How do I fix an LG 47LG50 Television which powers on but has only a dim blue screen and no sound?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
My TV has sound but very dim picture. If you shine a light on screen you can see picture
The back light is out. This could also be the power source to the back light. IF you want it repaired. Don't call a service person to come out and look at the set. They charge ALOT for that. Take it into a shop. NOTE don't transport it flat. The screen will crack.
Lg tv gray screen main menu screen flickers
tats something in the board its self youll have to take that to a tv repair man
1helpful
2answers
I have a 46 inch lcd samsung flat screen. the picture will flicker.
when it flickers is it lines that go up and down or across the screen or is it flickering bewteen lighter and darker?
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
1helpful
BLANK SCREEN
mainboard damaged.
replace the mainboard and that should solve your problem.
I have a 47 inch panasonic rear projection crt big screen, it is hooked ot dish network satt. it has no picture or sound...The dish guide comes up and video games work fine...
you problem is with your dish box. unplug the power cable and wait 2 minutes. plug back in an hopefully resetting will have solved. if not, contact dish for a new box
Vizio GV47L FHDTV10A
sounds like a lamp failure.
No picture on flat screen new, with cable
IF THIS IS A LCD---TURN ON, AS NORMAL AND HAVE A SIGNAL INPUT,,CABLE ,SATELLITE CONNECTED TO THE ANTENNA INPUT .MAKE SURE YOU HEAR SOUND.. HOLD A LIGHT (THE BRIGHTER THE BETTER) IN FRONT OF THE THE SCREEN ('BOUT 3 INCHES)--IF YOU SEE A DIM PICTURE---BAD SCREEN AND THATS BIG BUCKS---IF STILL NO PICTURE--CIRCUIT BOARDS AND USUALLY THATS BIG BUCKS!! GOOD LUCK
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
