Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52W20 TL120 transistor
I need a part number for the TL120, I ordered the Thompsons manual and it is difficult to read and it does not match the circuit board I have. We started with only one green light and changed out the flyback. Now we have three blinks and cannot find the part number for the TL120 HELP
  • 5 more comments
  • bgbrd9 Sep 15, 2008
    No squealing sound at all and the transister in question is a little smaller than the H.O.T. that is on the heat sink. The transister is located at L-4 on the board
    It has three leads, looks just like the H.O.T. but is a little smaller
    The TL120 is just at the right corner of the middle heat sink
    circled in yellow
  • bgbrd9 Sep 16, 2008
    can you tell me where to order this board. The regulator is shorted
  • bgbrd9 Sep 17, 2008
    I'll let you know how things turn out when I get the parts Thank you
  • ladywinn
    ladywinn May 11, 2010
    Does the new flyback make a squealing noise when set trys to come on and is TL 120 mounted on heat sink behind FBT?
  • RCA Master
  • 5,138 Answers
Is the TL120 does it only have 2 leads? I will look this up when i get to my shop, also the SSB board can be defective causing no high voltage be sure to recheck all ribbion connectors second ribbon connector on fbt board if not in right set will not come on.
Posted on Sep 15, 2008
  • 2 more comments
  • ladywinn
    ladywinn Sep 15, 2008
    OK i know which part you are talking about i was going to look it up let me do some checking around and i will get back to you asap. Does part read shorted out of circuit?
  • ladywinn
    ladywinn Sep 16, 2008
    You can order the complete board for around 77.00 #258762.also TL120 is regulator for hori circuit. still dont have the part number yet working on it.
  • ladywinn
    ladywinn Sep 17, 2008
    Call UNion Electronic Distributors 1-800-648-6657 or go to web site they have the part you need TL120 part # 259871 when ordering a board make sure you have right board number for your set D52W20 it is supose to be 258762.Good Luck with the repair.this should fix your set.
  • ladywinn
    They have 1 transistor in stock 259871 st18030hi 10amp 600volts price 3.55.
Need an AR 200W 1000M7 repair manual
If it goes in to overload then the answer is that one or more of the output transistors are fried. If the amp is very old then also check the main power capacitors. They might have dried out too and are no longer holding charge.
Replacing the transistors isn't difficult. The manual won't really help you. You will need to unbolt them from the heat sink, then unsolder from the board before finding the part number from the device and ordering replacements. Transistors normally work in pairs - a push pull arrangement. There'll be a PNP and an NPN in each pair. Make sure to note which type came from the sockets on the board so they don't get mixed up on re installation.
Capacitors always have the values printed on them too. The MicroFarads (uF) - stick to the exact same value. The voltage can be upped a bit. That will actiually help. Also the temp rating. Standard caps are 85 Deg C. Better versions are 105 Deg C. Upsepc the temp if you have the opportunity. Finally, go with decent brands rather than just the cheapest. Millions of flat panel TVs fail each year because TV makers penny pinch on caps. Don't make their mistake in your amp.
Good luck
Sep 02, 2014 | Televison & Video
Where can I get an Akai SW-180 manual?
sorry no manuals, unless torrents.- as to your speakers most speaker of this design and age break down on the bass reproduction and become sloppy over time while the high end wont fatigue unless it abused by excessive current the bass diaprams cand be replace and the seakers reconned. which isn`t very costly.
personally I would match them with something like a NAD QUAD
transistor,very smooth, or tube amp. The worst match is japanese transistor. the quad uses something like n2025 quarter size trensistors and most asions uses bloks or stacks where instead of one trasistor blowing the entire channel melts down. if you read between the lines, you`ll understand my opining remark
http://www.hifiengine.com/manual_library/akai/sw-180.shtml
Aug 30, 2014 | Computers & Internet
I have kicker kx800 2 some transistors where burn out making it short out I remove them and the short stop when I hook it back up with the 2 transistors out it powers up red then turns off I found out that...
It's probably not getting power there since you have removed the transistors that supply power to it. I would replace all transistors first then see what happens. trying to run it without them may not work out as a way to trouble shoot it. I always replace all similar transistors with new matching batch numbers parts, if 1 is bad then they all must be replaced with parts that are all perfectly matching components meaning they should all be from the same batch when they were produced. You will have to request this when you place your order. Transistors will vary slightly from batch to batch, the closer they all are the better your amp will work. also check the resistors that lead into the Mosfets.
Feb 20, 2014 | Car Audio & Video
Rca rs2640
It should be marked Q401 on the printed board. It will have 3 legs you need to desolder these and then you can read the number to order a replacement. Make a note of how the transistor is fitted before you remove it. For example if it is flat on one side and that faces another part then when you put the new one back it should go in the same way, with the legs matching the holes in the pc board.
Jul 27, 2013 | Audio Players & Recorders
Does anyone have the voltage specs on a PNT-426 Power Supply. It is for my NEC PlasmaSync PX-42VM5A Monitor. My electrician has found a faulty diode but doesn't have the voltage specs on it. I have a...
I have a PX-42VM5A and my Power supply is a PNT-426 (by Sanken Electric Co. LDT). Here are my specs: INPUT: AC 100-240V; OUTPUT: (there are nine outputs) +170v 1.6A; +60v 1.6A; +5v 4.0A; +2.5v 1.9A; +3.5v 1.9A; +7v 1.0A; +12v 0.5A; +12 v 1.9A and +6v 1.2A
Jun 17, 2009 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
CONVERGENCE WILL NOT ADJUST ON SIDES
First you need to read the supply voltages to the STK's. Black things, size of 2 match books on a big heatsink. Sounds like your supply voltage is low, could be a bad STICK STK. usyually stk 130-20 or 150, etc..
Mar 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence Problem
ok first question. I assume your a tech. YOU could change geometry settings ... which ones ... i have had a similar problem before does the horizontal amplitude work... will piture go in or out, this is a ew correction problem that looks like convergence. the main cause of this is DL032,DL030, and CL032....sometimes the ew buffer tl120. you then might have to go and reconverge the set good luck
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need part #
Can you read the letters and numbers on the transistor your needing to replace? If so post the numbers and I will post a link where you can order them or their substitue.
Nov 14, 2007 | Samsung HCL4715W 47" Rear Projection...
Reads PROTECT on the display of my Onkyo TX-SV525 ???
HOWDY,         NOW YOU COULD TRY THIS ONE: POWER THE RECEIVER UP , THEN PUSH&HOLD !THE VIDEO 1 BUTTON, THEN TURN THE PIECE IN THE OFF (STANDBY MODE ) ,IT WILL SAY "CLEAR SO IT SHOULD BE BACK TO IT,S ORIGINAL FACTORY SPECIFICATION,S.
SUCCES !                              AMSTERDAMCOWBOY-HOLLAND-NOW FLORIDA! 4-EVER
Apr 28, 2007 | Onkyo TX-SV525 Receiver
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
163 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
