Question about Motorola Mobility E51 MD7161-3 Quad Cordless Phone
Shows A on the screen-Only answers with prerecorded message
Have an A onscreen-what does it mean? Make it go away? Answers only in a prerecorded message of not being able to answer right now?
thanx-Jerry
  • oldtymepress Sep 13, 2008
    tried pulling batteries from units, unplugged base from power. Now have a flashing CL or A.
    bad day can't access manual-
    Genius:
  • 1,239 Answers
Hi  here is the link to solve this problem..
  1. www.avsforum.com/avs-vb/archive/index.php/t-128876-p-14.html  thank u.
Posted on Sep 13, 2008
  • 4,472 Answers
You need to turn auto answer off and set your clock. Please accept and rate whoever gave you this info first.
Good luck,
Lee
  • 1,879 Answers
A - turn the answering system off (menu -> scroll to auto answer go in & set it to off)
CL - set the clock (cause you had removed the battery)
    Genius:
  • 2,035 Answers
A is Announce only mode,
CL 􀀔 normal display Clock needs to be set...
Setting the Clock
NOTE: A flashing “CL” in the message window indicates that you must set the correct
day and time at the base unit.
1. Press the TIME button. The system announces the time and day of the week,
followed by "To set day and time, press TIME/SET."
2. Press the TIME button. The system announces the day.
3. Press the CHANGE button repeatedly until the system announces the correct day.
4. Press the TIME button to save the new setting. The system announces the setting.
5. Press the CHANGE button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6. Press the TIME button to save the new setting. The system announces the minute.
7. Press CHANGE to advance the minutes one at a time. –OR– Press and hold the
CHANGE button to advance the minutes in increments of 10.
8. Press the TIME button to save the new setting. The system announces the year.
9. Press CHANGE to advance the year one at a time. –OR– Press and hold CHANGE to
advance the years in increments of 10. When the system announces the correct
year, press TIME. The system announces the clock setting.
Good luck...
  • 6,487 Answers
You can try to turn off the answering machine , you can see it on page 50 of the user manua this is the link for the manual it will help you alot http://www.retrevo.com/support/Motorola-md7161-Telephones-manual/id/473dj399/t/2/
Hope that helps.........
    Master:
  • 763 Answers
Try to reset it or remove those batteries a couple of minutes to bring back again at the very start. hope that helps!
CHARCOIS
Riddle answers
Anything with double letters can.
Jul 29, 2014 | On-Hold Plus On Hold Plus OHP4000 Digital...
How do i record a greeting message?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/model.KX-TG1033S
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 26 of the manual for detailed instructions on how to operate the answering system on your phone.
Basically that section of the manual reads as follows:
Greeting message
When the unit answers a call, callersare greeted by a greeting message.
You can record your own greeting message or use a prerecorded greeting message.
Recording your greeting message.
You can record your own greeting message (max. 2 minutes and 30 seconds).
If you do not record a greeting message, a prerecorded greeting message is used.
1 Press the MENU button.
2 Scroll to ANSWERING DEVICE using the up and down arrow keys and then press OK.
3 Scroll to RECORD GREETING then press OK.
4 After the handset beeps, speak clearly about 20 cm (8 inches) away from the microphone.
5 To stop recording, press the OK button.
6 Then press the OFF button.
Using a prerecorded greeting message.
If you erase or do not record your own greeting message, the unit plays a prerecorded greeting message for callers and ask them to leave messages.
Playing back the greeting message.
3 Scroll to PLAY GREETING then press OK.
4 Then press OFF.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 13, 2011 | Panasonic KX-TG1033S Cordless Phone
How do I change the greeting message?
You can record your own greeting message (max. 2 minutes) that is played when the answering system answers a call. If you do not record a greeting message, a prerecorded greeting message is used. 1 {GREETING REC} 2 Within 10 seconds, press {GREETING REC} again. 3 After the base unit beeps, speak clearly about 20 cm (8 inches) away from the MIC. 4 To stop recording, press {STOP}.
Mar 08, 2011 | Panasonic KX-TG5632 Phone
How do i record my personal greeting on answer machine model ATT 1717. I am only able to get the prerecorded greeting. Thank you charlene
I hope this helps you:
Recording Your Announcement
Before using this answering system, you
should record the announcement (up to
one minute long) that callers will hear
when the system answers a call. If you
choose not to record an announcement,
the system answers with a prerecorded
announcement: "Hello. Please leave a
message after the tone."
1 Press and hold annc/skip. The system
beeps. Speak toward the microphone
normally, from about nine inches away.
While you are recording, the Message
Window displays -.
2 To stop recording, release .annc/skip
The system automatically plays back
your announcement.
To review your announcement, press
and release .annc/skip
You can get a copy of your 1717 manual at this web site:
http://www.retrevo.com/samples/AT%26T-page-2-manuals.html
Hope this helps. Good Luck, Barb
Feb 20, 2011 | AT&T 1717 Digital Answering Machine
My answering machine message is out dated and needs to be changed how do you do it?
message
message (max. 2 minutes). If you do not
1 {GREETING REC}
from the MIC.
Feb 11, 2011 | Panasonic KX-TG6021M Cordless Phone
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
are greeted by a greeting message. You
message.
message
seconds). If you do not record a
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
5 To stop recording, press {OK}.
6 {OFF}
message
messages.
Sep 11, 2009 | Panasonic KX-TG1033S Cordless Phone
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
How to change announcement ?
announcement: “Hello. Please leave a
message after the tone.”
1 Press and hold "ANNC/SKIP" . The system
Window displays —.
2 To stop recording, release "ANNC/SKIP".
your announcement.
and release "ANNC/SKIP".
Nov 10, 2008 | AT&T 1717 Digital Answering Machine
Sprint RadioShack answering machine CAT. NO.: 43-5812
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Your question is not clear enough, You can check it out in the user manual. I just guess you are asking recording your personal annoucement.
1 Press and hold "Annc/Skip". The system
Window displays —.
2 To stop recording, release "Annc/Skip".
your announcement.
and release "Annc/Skip".
Sep 02, 2008 | AT&T 1717 Digital Answering Machine
AT&T 1717 answering machine
Here is a link to your owner's manual: http://telephones.att.com/docMgt/public/art/162/1717_ATT.pdf It says: Recording Your Announcement Before using this answering system, you should record the announcement (up to one minute long) that callers will hear when the system answers a call. If you choose not to record an announcement, the system answers with a prerecorded announcement: ?Hello. Please leave a message after the tone.? 1. Press and hold ANNC/SKIP. The system beeps. Speak toward the microphone normally, from about nine inches away. While you are recording, the Message Window displays ?. 2 To stop recording, release ANNC/SKIP. The system automatically plays back your announcement. To review your announcement, press and release ANNC/SKIP.
Mar 07, 2007 | AT&T 1717 Digital Answering Machine
Motorola Mobility E51 MD7161-3 Quad Cordless Phone Logo
197 people viewed this question
Top Motorola Mobility Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
john h
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
