Question about ION Audio iTTUSB Turntable
ION TTUSB05 I have a iMAC 7,1 Intel Core 2 Duo. The ION Model I have is a TTUSB05...I know this is just a click away from being perfect. I can get to Step 5: export to iTunes, and then there comes the Warning: "...ez Unable to connect to iTunes. Please make sure iTunes has no popup windows open, then hit OK"... I do believe that I have any open, what am I doing wrong? Thanks, Rene
  • 6,487 Answers
Just restart your computer , then open the itunes and its should continue the process that time, if still the same a updated itunes should do the tricj for you...
Hope that helps........
Posted on Sep 10, 2008
  • ION Audio Master
  • 13,433 Answers
I would suggest checking if there is a updated version of itunes available for you.
http://www.apple.com/itunes/download/
Atleast try reinstalling the program.
Let me know how that goes, and also are you using another program with the turntable?
  • Ekse Sep 10, 2008
    I noticed that you rated the other thead where I answered you as fixya, if the problem is solved I would appriciate it if you accepted my solution (not sure what it says on your side but to that direction)
    Thanks,
    Ekse
Replace hard drive
http://www.ifixit.com/Guide/Installing+iMac+Intel+24-Inch+EMC+2111+Hard+Drive+Replacement/5211/1 This guide is for your model.
Oct 11, 2012 | Apple iMac 24"/2.33Ghz Intel Core 2...
Imac os intel core 2 duo inverter
Pop in your OS X DVD and run a repair install or an archive and install.
Apr 17, 2012 | Apple iMac G5 Desktop
My motherboard model is D101GGC Is this support CORE 2 DUO E4600 processor
This motherboard model will not support Core 2 Duo E4600.
It will support only.
1.Intel Pentium D Processor.
2.Intel Pentium 4 Processor.
3.Intel Celeron D Processor.
Thanks for using FixYa.
Jun 03, 2011 | Intel D101GGC Motherboard
MA878LL iMac 24" core 2 duo 2.4 do not turn on,
Checking the power supply isn't the easiest thing to do, it involves pulling apart the entire machine.
You can try resetting the SMC, unplugging all power, hold the power button for 5 seconds, replace power, then attempt to turn on.
if it still won't turn on, and assuming you didn't get AppleCare or it is expired (past 3 years) it might be worth taking in to an Authorized Apple Repair Facility and see if they will check it out for free. If it is under warranty, most definitely take it in or call 1-800-APL-CARE
If neither of those are an option, Power Supply http://www.ifixit.com/Apple-Parts/iMac-Intel-24-Inch-2-4-2-8-GHz-or-3-06-EMC-No-2211-GHz-Power-Supply/IF169-002
a tear down from iFixit for the 20" model, it is most likely very similar for your model as well http://www.ifixit.com/Guide/Repair/Installing-iMac-Intel-20-Inch-EMC-2133-and-2210-Power-Supply/1006/1
Hopefully that helps. Good Luck
Feb 23, 2011 | Apple MA878LL iMac with 24" Screen Desktop...
My iMac g4 just got a 1pixal coloured line then 12 hrs later 4 more lines appeared now another 12 or so hours it has grayed out a third of the display. some tech said only way to fix was buy a new one it...
If your iMac is an Intel Core 2 Duo running Leopard, it's certainly not a G4.
From the symptoms described, you have either a bad LCD panel or a bad LVDS cable. Either way, what the tech told you is wrong. They can both be replaced. Whether it is cost-effective or not is for you to decide.
Jan 28, 2010 | Apple iMac G4 Desktop
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Jul 09, 2009 | Apple iMac 17" MA199LLA Desktop
EPSON 1800 PROBLEMS WITH NEW IMAC
While you may have installed it, the generic driver may be selected. Here are all the steps to get you back up.
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Aug 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
ION Audio iTTUSB Turntable Logo
312 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
