Question about ASUS Computers & Internet
Nothing appears on screen
When I turned on the power, the computer does not start or boot-up. But the power indicator lits..Please help me with my problem..
  • 67 Answers
Does it have any boot-codes(beeps)? Could be a lot of reason why it is not booting.
Posted on Sep 16, 2008
Hello, My ibook g4 won't start up I turned it on and the chime goes as normal but the screen appears with the apple logos normal and the swirly loading sign but stays like that for hours and doesn't go to...
probably the software is courrepted.boot the system with installation disk and then check the disk with diskutility.repair the disk permission and check.if still the issue persist.reformate the drive and install freshly
Feb 09, 2010 | Apple Titanium G4 and 8413i Book series AC...
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
My monitor no turn off automatic when computer shutdown
have you tasted it with another PC ? if its behaving the same then its hardware problem the monitor s microprocesor could be damaged .
replace the monitor
good luck
Jul 10, 2009 | IBM POWER SUPPLY 120W 25P4966 Power Supply
Plugged computer back in after move and won't start. green light in mb on.
Actually, there is nothing you can do with the hard drive. If its shorting out the power supply when its pugged in then it is defective. However, most hard drives carry a 3 year warranty from the manufacture. If the drive is younger then 3 years old, I would call the manufacture and get it repaired or replace. Hope this helps . . .
May 16, 2009 | Antec EarthWatts EA380 380-Watt Power...
Just Plain stopped working
I'll assume you've already checked the obvious possibility that the outlet the computer is plugged into is not working.
Here's a diagram of the main power plug from the supply:
With a short wire (like a bent paperclip), short the green wire PS_ON to the ground pin on either side of it (in the same row, not directly across in the plug!!). The power supply should start up if it's working properly. If the supply doesn't come on, replace it. If it does, then you'll need to replace the main board.
That's the way electronic components usually fail. The initial surge when you turn something on causes a part that was ready to fail to go bad, the same way a light bulb usually burns out when you turn the light on, and not while it's already lit. So the computer was working fine, then the next time you turn it on....pffft!
Mar 30, 2009 | Ultra 500Watt ATX Power Supply with 2-80mm...
Computer won't start
The power supply is fried partially, or the motherboard went poof.
Dec 19, 2008 | Antec TruePower 2.0 550W 24/20pin nVidia...
Comp wont start up
The hard disk may have died. Check the BIOS and check the hard disk setting, if it appears OK then boot up with a DOS floppy startup boot disk, and select boot up without CD-ROM support, then type fdisk, answer Y to large disk support, select 4 to Display partition information.
If you see all your disk partition the most likely your hard disk is OK.
Most likely you operating system is damaged/corrupted and you will need to reinstall your operating system and drivers for all your devices.
Nov 28, 2008 | Powmax 400 Watt ATX Switching Power Supply...
Surepower 430w power supply - fried my motherboard need help
Power supply went bad (6.5v on the 5v rail) and fried my motherboard. I read where Mad Dog, Inc was terrible at returns and replacements and the BBB rated them as one of the worst. I threw up my hands and just ordered a new one from a different Mfg.
Aug 01, 2008 | Mad Dog Multimedia Computers & Internet
URGENT HELP... i have broken my computer by OVERCLOCKING it...please help
First of all, it seems unlikely that you have actually broken anything.
Please look carefully at the options in the main setup menu (BIOS) after you press the DEL key... There sshould be an option to "loade defalut settings" or "load optimised settings"
If so select this option and F10 to save/exit and allow it to boot
Jun 29, 2008 | Computers & Internet
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
