Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Distorted screen my screen started displaying a "wavy" image. what would cause this?
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
distorted screen - bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on May 07, 2010
Where can I find a guide for my enzer TV ?
There are many types of distortion. Each with its own cause. Please describe the type of distortion. Are there vertical lines? Are the images wavy? Are they off-color? Are they blurry? A better description will yeild a better response.
Dec 16, 2014 | Televison & Video
System freezes-Video display=multi-staggered image(not legible)
It's either a loose connection from the motherboard to the video-display, or a partially-broken video-display, or the video-adapter in your motherboard.
Connect an external monitor -- if it looks OK when the internal LCD is "wavy", then your computer is fine.
But, since your say "happens to both screens", the most-likely problem is the video-adapter, which usually means that you will have to get COMPAQ to replace the motherboard.
May 26, 2010 | Computers & Internet
Wavy distortion on screen
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Apr 09, 2010 | Canon PowerShot S400 / IXUS 400 Digital...
Image is distorted. Like the guide is in a wavy
Its sounds like the convergence is out of alignment. Instructions on how to adjust it is in the manual. If you don't have the manual you can find it on the sony support site.
Mar 01, 2010 | Sony KP-53HS30 53" Rear Projection...
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Double images
Convergence amps bad call a tech make sure he does'nt use generic parts A Toshiba service center should know what to do around 300.00
Apr 12, 2009 | Toshiba 50H82 50" Rear Projection...
Wavy Video output from Marantz sr5600 Receiver
are you using component inputs s video rbg or hdmi?
Jan 31, 2009 | Marantz VP15S1 Television
Hitachi 53UDX10B PICTURE DISTORTION
projection screens are prone to screen burn ,this is caused by the same image being displayed for a long time ie nick jr image in the corner,also check ther are no magnets close to the tv as this will cause distortion,ie speakers etc,hope this helps
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Wavy picture except when displaying a 1080p image
Elsewhere! Bad hyper board =bad caps on board need replacement = find a different tech who has heard of this repair or
have him research fixya / Toshiba/ 42H81 / hyper board ......T.
Oct 14, 2007 | Toshiba 42H81 42" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
