Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Add'l info Thanks so much for the reply. The brass hose that came out of the wall had a crack in it and they removed the crack by making the hose shorter (cutting a piece off the hose that contained the crack) making it shorter.   They then connected the brass hose from the refrigerator to the now shorter piece coming out of the wall (it actually goes through a hole in the side of the cabinet).   diagram: wall joint    |======x================|   frig  |    |     ^                 ^                     |         |          |                  |                     -----------   brass brass hose hose The brass hose from the frig is connected to the bottom right corner of the frig (if you are facing the back of the frig).  The leak is right under where the brass hose is connected to the frig. (on the bottom right corner). Hoe this helps, thanks again Ginko! Richard Garneau
  • 3 more comments
  • Richard Garneau Sep 11, 2008
    The leak is not coming out of the hose and it is not condensation.  I'll try and draw this for you:
      Frig
        v
    |              |     |     |    |  cabinet
    |            o|-----|     x   |
    x = The connection between the brass hose coming out of the hole in the side of the cabinet and the brass hose going into the refrigerator.
    o= Connection on bottom of frig.  As soon as I turn the little spigot under the sink on (which turns the water on for the brass tube that comes out of the cabinet), the water puddles under the corner where the hose connects to the refrigerator.  Like this Looking down at the refrigerator:
                      |ppppppp
                    o|pppppp
    ------------------ pppppp
    o = back corner where hose is connected to refrigerator.
    p = where the puddle forms
    It is very clear that it is not a simple leak and that something where the hose connects to the refrigerator is defective so the water is simply running right out.  It has absolutely nothing to do with the crack that was in the hose or the connection that the maintenance folks put on here. (connecting the 2 hoses together.  There is nothing leaking at all, simply water pouring out just behind where it connects to the refrigerator.
    Thanks,
    Richard
    Guess the drawing isn't working so well....sorry.
    The bottom line is that it is not condensation, it is not the connection that the maintenance folks installed to connect the two brass hoses together.  Something where the brass hose connects to the refrigerator is defective.  When I turn on the water, it simply forms a puddle under the frig. It appear that just after the hose connects to the frig (on the inside) the water is going right through.
    This is not easy to explain so please bear with me.  I wish I had a schematic drawing for the frig because I could probably figure out what part is defective.
    Thanks Ginko.
    Richard
    Clearly you are not reading my responses, I detailed that it is NOT the hose and that it is NOT a leak and the job on the hose is NOT the problem.  We are making no progress here because you are NOT reading my responses.  I detailed in my last response that it is coming from behind where the hose is connected to the refrigerator and NOT the hose.
    We are obviously making no progress and I am not further ahead then when I started with FixYa.
    I was hoping to avoid having to pay for a refrigerator repairman, but clearly that is not an option.
    Sorry for the snippy email, but I find it very frustrating when I take the time to write detailed responses and you don't read them.  The same thing always happens with emails (not to you, in general).
    Richard
  • Richard Garneau Sep 12, 2008
    The word movie in your message is a Hyperlink to a video on the Nokia Intenet Tablet, thought you would be interested in that
    Well, after all that I am sure you don't want to talk to me anymore, but I figured I would give you a heads up on where I am at with this stupid frig.  I pulled off the cardboard backing on the bottom of the back of the refrigerator and stuffed a towel under where the brass hose connects to the back of the refrigerator.  I turned the small spigot under the sink to the hose on and it appears that the light blue plastic piece under where the hose connects has a leak and as soon as I turn the tap on, the water starts coming out the bottom.  I'm not much further ahead than I was at the beginning because my first message stated that it is leaking just under where the hose connects to the frig.  It is pretty hard getting that piece out to look at it or to replace it (it's a pretty tight fit with hoses connected in a few places and I know if I unplug it I will forget how to put it back together, so I guess a visit by an appliance repair person is inevitable (yuch!).
    I am not trying to be a **** here, I am just a little confused on how FixYa works.  You say that this is a free ask-me section and that the only people paid are the experts who answered my original post. The first contact that I had after my original post was yours.  Clearly I am coming across to you as a complete *** and for that I apologize (I am not trying to be rude here, just honest).  I did a search on Google and came across FixYa.  When I paid the $10.00, it was presented in a way that led me to believe that I would get to a solution to my problem and that if I did not, I would get my money back. Seems to me that FixYa is out to make a buck and not representing itself honestly.
    Thanks,
    Richard
You may not be getting paid for it, but I paid $10.00.
It is presented in such a way that FixYa could very well lead to a solution so I guess I was thinking that I would avoid the huge expense of someone coming to do it.
Sorry to be a bit of a **** here, I am just concerned that I paid $10.00 and it appears that it was for not. If FixYa members are paying and you are not getting paid, someone is taking advantage of you to make a buck. Something is wrong with this picture.
Richard
Posted on Sep 11, 2008
  • GE Master
  • 19,396 Answers
From description looks like the leak in where the shorted hose had been connected, or the pipe has another leak.
Wrap the hose with a cloth, on the side where it goes inside the cabinet, so that you find out if the leak is coming from the inside or from the outside part.
Ensure that it is not coondensation.
Posted on Sep 10, 2008
  • 2 more comments
  • Ginko
    Ginko Sep 11, 2008
    Hi, sorry, I am not always online,
    If you put model number here you can find exploded view for most fridges.
    Your problem is just a leak all you have to do is finding the bad joint and sealing it.
    A suggestion, if the job on the hose had been done recently, and it is the same hose leaking, you can tell the repairman that the job was not done properly.
    Since it is same hose there is good chances that the repair job, by moving and pulling the hose to fix it into the fridge, had probably caused the new leaks, and he knows this.
    Ask them a reduced fee or free repair job on the leaking hose.
  • Ginko
    Ginko Sep 11, 2008
    Listen, I am not getting payed for this, this is my free troubleshooting area, and I am answering many people with different problems at the same time, then do not get upset.
    Second, you also rated me negatively already, and I should not be answering you at all, I am not even doing this for the glory right now.
    Regardin the fridge, there are two reasons why a fridge leaks water:
    Condensation : in this case you need to check the evaporator fan, and the defrost system, often you fix condensation problems performing a thorough defrost.
    Broken pipe/hose or leaking joint : replace the hose or pipe or fix it, this is not necessarily an user level operation. You need to track down the leak yourself by removing fridge panel and following the lines, once you are sure it is not condensation
    Regarding Fixya, this is not a substitute for a service call in to repairman.
    Here you communicate with a technician that is at the opposite side of the globe, this can give you technical indications, if you have no DIY knowledge and experience, or if the problem is complex, you will still need to call in a technician.
    Check if water is coming from the drain hose, in this case check tha fan and do a complete defrost overnight.
  • Ginko
    Ginko Sep 11, 2008
    I am not getting payed because this is a free ask me question, the experts involved in your original post will be paid. I am not complaining because I don't get paid, I answer free questions because I like this, and sometimes I get paid a little amount for premium questions. This is an hobby that sometimes is also rewarding with nice little money.
    The main conceptual problem is that you keep thinking you paid $10 to get fridge fixed by a technician.
    On fixya you pay to talk to somebody that can indicate you the right direction to fix your item. I cannot be there to physically find the leaks, and put a rubber joint or a strip on it, but I can give you direction on how to do it.
    You keep complaining about the $10 and you haven't even done the defrost, or inspected the hose using a cloth as suggested, to find the leak.
    If you have some troubleshooting skills and you did some similar job on a large appliance before, you can do it yourself, with a little help from a technician.
    Check the panel at the bottom of the fridge and the drain hose in there, often fridge liquid is coming from there.
    Defrost the fridge and dry it iside. if you get the problem again then it is the lower panel. If your fridge have water supply lines, icemaker etc. that are the only parts that can leak check them out after you ensure it is not from lower fridge panel.
    Condensation at the back of the fridge can be often confused with a leak , ensure it is not condensation.
    About leaks from bottom of the fridge see this movie:
    How to Fix a Leaking Refrigerator
    Read also here:
    How to Repair a Leaking Refrigerator
    Regarding the $10, sincerely, I am an electronic engineer, I like also fixing cars and large appliance in my spare times, and spending my time here when no customer is coming.
    I am not a book keeper and I do not care about the coins.
    Regards
  • Ginko
    Ginko Sep 12, 2008
    Hi mate.
    Don't take it too seriously, this is just a kind of a game, I was just trying to explain you that the little help you can get online usually cannot replace the repairman job.
    This is just a bit more of what a traditional handbook can offer, stating to many opinions it is still better than standard phone customer service offered by many brands.
    If I was also in your premium post ( I lose track of them), then you should have kept asking question into the pay for solution.
    Posting an opinion here is free, you find sometimes people that is less prepared than you, but also you find real professionals, that you do not get on standard customer support line.
    Regarding how fixya works, you use rating to evaluate the support we give you:
    On free questions
    1 cube-Red: inappropriate: must be used when content is abusive or out from contest.
    2 Cubes-Yellow: Thanks For Trying, used when unhelpful
    3 Cubes - green helpful: it helped a bit but did not fixed it.
    4 cubes Fixya: well, you fixed it.
    On Premium (pay for) solutions instead you accept one of the solutions, and that solution will be rewarded with money, the rest get nothing.
    Regarding the fridge, that it is the most important here, see if you can access the leaking hose. You can try to fix it first using sealing tape. If that is not enough, in some case, depending on how the hose is broken, you can use bath tube caulking to seal the joint.
    If you see that you have to replace the hose to fix the leak, then it may be better calling a repairmen.
    If no part replacement is involved, usually the job is not too expensive.
    Now that you know in detail where the fault is, you can call the repair company, describe the problem, and ask a precise quote for the repair.
    This usually lower down the repair fee, as repairmen often give customers a quote covering expenses in excess when we do not know the problem. This should cover the tenner spent on Fixya.
    Let me know if you have any other query, I usually answer within 24 hrs.
    Regards
I see hose repair parts in house and garden stores. How exactly do they work?
Hi Colleen:
Easy as 1-2-3
1- Cut off the bad fitting
2- Slip the clamp over the hose and push the replacement fitting into the hose
3- Align the clamp and tighten it.
Back to the garden!
May 21, 2015 | Garden
Looks like water is leaking fromunderneath washer & getting floor all wet.What could be causing it? Thanks,Kathy
Hi Kathy, a number of causes could make this happen, a plugged drain hose will make it leak, so will a bad pump, a bad tub gasket seal, etc.. If possible, pull the machine away from the wall, and look underneath ,, see if there are signs of where its leaking, you should be able to do this without removing anything, Different models have different reasons for what your describing, once you check that get back to me by using the reply on this feed, and I'll try and assist you better,, if you can add the make and model number Thanks Jim
Jul 19, 2011 | Westinghouse Washing Machines
How do I remove the bottom of the vertical bar on Aquamaster 12699? I want to insert a new sliding bracket. Thanks
Piece (escutheon)agains't wall should pop away from wall and twist,need a little flat head screwdriver to pop away from wall-screw should be underneath
Jan 28, 2011 | Aqua Brass AquaBrass 12699 Aquamaster...
Side wall out of slot.How do i remove top to put sides in place?
Undo screws at the sides of the control panel. flip control panel back and remove big brass clips that hold back to housing the top does not need to come off. http://www.youtube.com/watch?v=vogysB7XOc8 reply !!!
Dec 12, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a 98 lincoln town car executive and I need to know how you change the thermostat
1. drain coolant
2. remove engine cover
3. remove the 2 bolts from water hose connection (upper rad hose connecting to)
4. remove o-ring and thermostat
5. repeat in reverse order
Feb 05, 2010 | 1998 Lincoln Continental
How to dissable a pre-existing dimmer switch
You don't want to disassemble the dimmer ... you want to remove the dimmer and replace it with a toggle switch
Get a switch at the hardware store or at the big box place. You only need a standard wall toggle switch - color to suit your taste ... gray, ivory, white, brown or red usually. Expect to pay less than $3.00 and maybe as little as 75 cents.
It is simple ...
turn off the power to the light at your circuit panel.
Remove the knob (pull it off) - remove two little screws that hold the cover plate on. There may be a nut under the knob ... remove it (leftie - loosie -- righty - tighty)
Remove the two screws that hold the dimmer in the box,
Pull the dimmer out.
loosen the screws that hold the wires onto the dimmer ... you may have wire nuts holding the wires together. if so, remove them
set the dimmer aside.
you should be working with two black wires in the wall. What ever is attached to the dimmer is the wires you will be using. It does not make any difference which colored wire goes on which brass screw - more below - except the green ... the green goes only on the ground screw.
put one wire from the wall on one brass screw
put the other wire from the wall on the other brass screw.
put the bare wire (or green wire) on the green screw on the switch frame.
arrange the wires behind the switch and screw two screws into the wall box ... make sure the switch is straight.
put the cover on -- two screws ...
turn on the power.
If you have more question, attach to this post.
Thanks for using fixya.com
a
Oct 26, 2009 | Electrical Supplies
Maytag Neptune gas dryer with cracked drum
Not sure what the cost of a new drum is, but yesterday I fixed one. I took a chance and bought one of these dryers with a crack for $70 on Craig's list. Not an easy job, but if your handy, know what your doing, and have the tools you can get the job done in about 3 hrs. Here's how:
Disconnect the dryer and move it to a space where you have plenty of room to work. Remove the drum belt from the motor, noting how the belt goes through the belt tentioner and motor. The drum comes out the front, once the front is removed. Be gentle and you'll have the drum out in less than 30 minutes. Be very careful with all wiring and connectors. Gently remove the felt edging at least 8 to 12 inches away from the crack. It is glued to the drum. Use some duct tape from the opposite side of the drum to hold it way from the crack. Next position the crack together as closely as you can, and hold it together with a set of vice-grips on the outermost edge. Using an ACETYLENE torch (not normal propane) and brass brazing rod with flux start near the inside/center of the drum and work your way out toward the edge. Take your time, use lots of heat, and make sure the brazing sticks. I rested my drum on a metal trash barrel so it was up in the air and I could braze it comfortably. Next find a piece of stainless steel. I used a hose clamp. Verify it's truly stainless by seeing if it sticks to a magnet. A stainless should just barely attach. Very few hose clams are truly stainless. You can also use a piece of old kitchen sink, or cut a piece off a stainless dog bowl, moulding, etc. I cut off the end on the hose clamp, and positioned the strap of the clamp on the outside of the drum, perpendicular to the crack about 1 inch in from the edge. I used a clamp to hold it in place. I then brazed each end of the hose clamp. Then remove the c-clamp, and do along the hose clamp to add strength to the area so it does not open up again. After your done, brazing, go back and take some time to really clean up the outside of the drum with a grinder. The drum rotates on rubber wheels which run along the outside of the drum. If you did this right the drum wheels will NOT pass over the hose clamp, but only pass over a small amount of brazing over the actual crack. This takes some skill to accomplish, but the brass brazing will never leave rust marks on the clothes. When I ran the dryer empty you could mildly hear a bump as the wheels passed over the brazing. However with a full load you don't even hear it at all. Got home with the dryer at 4:45, and had it done by 7:45. It may break again in 6 months some where else...but for now it works like a charm.
Feb 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Can't find thermostat on 1994 olds cutlas sierra ,how do i change
judy-make sure the car is cool and follow the upper radiator hose to the engine.the thermostat should be located under a housing @the motor. remove the clamp,pull the hose off,remove two(usually bolts and pry housing off motor careful not to scratch mating surfaces. clean mating surfaces well and apply sealant to bothsides of gasket-should come w/thermostat.make sure thermostat is pointing correct way(box should tell you)askcounter guy @auto store for correct sealant tighten bolts-add alittle premixed antifreeze(depending where the hose is @ it may leak when you pull the hose.I know this is alot of info but hey you asked..buy a chilton repair manual to help with projects like this..Good luck
Jan 20, 2009 | 1990 Oldsmobile Cutlass Ciera
Kenmore washer, elite 70 series is leaking water on floor
the hose from the drum to the pump, and from the pump to the drain, are at the front,
Movement of the drum during wash cycles, wears the short hose between drum and pump and it develops cracks, eventually a wash load of any size will finally cause one of the cracks to penetrate through the rubber, and constant drip occurs.
Its an easy fix, no more than screwdrivers needed.
the local parts guy will have the hose, even if it is labelled ge frididaire whirlpool the same hose is common to many makes and models
  • turn off water unplug washer
  • pop the endcaps off the control panel, and completely remove the phillips head screw under each endcap dec762a.jpg
  • lilft the control panel ~1inch and flip it over the back of the washer,
    (do not dislodge the water level sensing hose or we'll be back to fix it later, hinges are plastic, dont bust em)
  • remove the two brass clips under the control panel
    (note position for reinstall)
  • remove lid switch connector
  • lift entire body up ~1 inch and remove forward
  • motor pump hoses gearbox are now exposed.
examine hose from drum to pump, and from pump to cabinet rear,
replace cracked and crazed hoses.
reassemble in reverse order
Oct 12, 2008 | Kenmore 24032\24036 Top Load Washer
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
149 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
