Question about Lowrance GlobalMap 3300C GPS Receiver
Gps hi i am having problems with my lowrance 3300c seems to be working perfectly apart fromlights flashing and alarms going off not all the time but frequently also switching itself on
  • 1,800 Answers
Upgrade it firmware usnig the download support are in the main page of ur product u will find it there!!
Posted on Sep 10, 2008
Unit turns on by itself
I have two Lowrance X 125 that I don't get any Power to.
Feb 07, 2010 | Lowrance GlobalMap 3300C GPS Receiver
I am receiviong a message " GPS Module Not Responding"
most cause by ant not working or bad cable or corrotion in connectors
Nov 09, 2009 | Lowrance GlobalMap 3300C GPS Receiver
I can not get my unit out of demo mode
Have you tried doing a hard boot to the unit?
Jul 17, 2009 | Lowrance GlobalMap 3300C GPS Receiver
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
Need to know the connector brand and the functions on each pin
Because Lowrance doesn't publish the pin connections, neither in their user guide, neither on a convenient website - this is really a breakpoint for me - I checked GPS connector suppliers and I found different plugs, type and connection codes in Europe, where information comes with the unit as a EU - norm
Feb 18, 2009 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance 3300c still playing up
John, my 330c was doing the same thing until I found a short in a totally separate system. It was a speaker for the stereo. As soon as I fixed it, the flashing problem went away.
Jan 08, 2009 | Lowrance GlobalMap 3300C GPS Receiver
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance 500c touchscreen
My iway 500c kinda had the same problem. At first while driving, the screen would go from 3d to always north to always up and be switching screens 3 to 4 times a second. It would finally go back to normal. After about a month of this the touch screen would work intermittently. It finally quit working completely on a trip to Texas. When I got home I called Lowrance and the said they would replace it for $350. I already spent over $600 for it. I took the thing apart and found the grounding screw to the touch screen was really loose. I tightened it and now its working again for now. I am not happy with Lowrance support.
Clane
Sep 05, 2007 | Lowrance Iway 500c GPS Receiver
Lowrance GlobalMap 3300C GPS Receiver Logo
229 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
