Question about Cyberhome CH-DVR1500 DVD Recorder
Froze at "Reading"
I turn my dvd player on, it displays it's normal "cyberhome" display then it starts "reading" but there is no disc in the tray to read. It freezes here and I can't do anything, not even open the tray door. I just reset it in the back and turn it off. I deeply appreciate any help you can give me. Thank you so much in advance.
  • Lynda Balmer Apr 02, 2006
    Thanks Sillygirl, but unfortunately, I can't get the door to open in order to do an upgrade...neither by remote or just pressing the button on the dvd player itself. Same goes for even shutting it off...can't do it by remote nor the power button. I have to turn it off by the ac switch in the back of the player. But thank you so much for trying :)
    oh and sorry, no I didn't just get it...I got it 2 Christmas' ago...stopped working a year and a month later...has be completely baffled. lol...again thanks so much
  • 513 Answers
If you are lucky to have a normality relapse, maybe after resting the DVD recorder for a while, you could try 2 firmware updates found here - http://support.cyberhome.com/support_web.nsf/All_Docs/?SearchView&Query=(DVR%201500)%20AND%20(Downloads%20and%20Updates)&Start=1&Count=10 But theres a 99% chance that you're stuck in the initial setup mode(have you just puirchased it?) - if you wish to skip this setup press- > enter > return > enter - on the remote panel, make sure to press every button only once. If you wish to go through with setting up the date/time etc, then follown the instructions in this addendum to the manual: ftp://209.237.61.78/cyberhome/1500/manual/1500_add.pdf Good luck
Posted on Mar 27, 2006
  • 2 more comments
  • yoav kleinfeld
    yoav kleinfeld Mar 27, 2006
    sorry about the broken link, lets try again - http://support.cyberhome.com/support_web...
  • yoav kleinfeld
    third time a charm -http://support.cyberhome.com/support_web...
  • yoav kleinfeld
    yoav kleinfeld Apr 25, 2006
    It could be usefull to try the initial setup mode routine again anyway(see what i wrote up there), it might have jogged back to it somehow.
    If I hear of a known manual way to open the tray I'll let you know, but in the meantime you can unscrew the screws, and open it up to look for obstructions.
  • yoav kleinfeld
    yoav kleinfeld May 04, 2006
    Got it!
    "1. Unplug the player.
    2. Flip the unit upside down. You should see a slot that has an arrow that says emergency hole.
    3. Get a knife or key and put it all the way in the hole and slide towards the direction of the arrow.
    4. The disc tray should open half an inch. Open the disc tray and retrieve your disc.
    5. Flip the unit right side up and plug the unit back in. The disc tray should automatically close. "
    But you should read the following thread as a word of caution -http://www.fixya.com/problems-solutions/...
    Good luck
Its says wrong region!
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
May 01, 2011 | Cyberhome DVD320 DVD Player
I have a Cyberhome CH DVD 300 (region 1), I want to change the region on this player. I learned I need for first: 1.- Turn On the DVD player 2.- The tray needs to be closed and empty 3.- Press the Menu...
  3. Press MENU, 1, 9
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
Dec 07, 2010 | Cyberhome CH-DVD 300 DVD Player
How can I stop a dvd player from reading non-stop with no disc in player---player is not on lock but refuses to open.
Power off, then disconnect from the wall plug.This resets the dvd. after five ninutes, reconnect the power and start the combo. Should have 'load' on the display, then open the tray of the dvd.When you close the tray, it will try to 'read' a dvd again.
Aug 16, 2010 | Philips Magnavox DVD/VCR Dual Player
MY CYBERHOME DVD PLAYER IS READING INSERT DISC AT ALL TIMES AND WILL NOT PLAY ANT DISC. HOW TO RESET CYBERHOME 300 DVD PLYER?
I am sure problem on Laser,may be it does not read any disk.So all times it say insert disk.You can better opportunity replace this damage laser.
Aug 10, 2010 | Cyberhome CH-DVD 300 DVD Player
It won't read disc. After loading, it reads No Disc
Sounds like a read error fault , possibly a laser malfunction sometimes dirt on the lens will cause this try a good CD cleaner if this is no good I suggest a free engineers estimate at least you can then ask again on here how to fix it . My honnest guess is either a duff laser or software corruption . I have known seating of the tray to cause this also not returning fully back into machine , usually caused by children and alien matter ? shall we say such as choclate or M&MS kids shove stuff everywhere ? bless them lol
hope this helps Regards Vortash
May 10, 2009 | Cyberhome CH-DVD 300 DVD Player
My cyberhome CH-LDV-1010A dvd player does not go pass reading.
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Cyberhome CH-LDV1010A Portable DVD Player
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
116 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
