I own a Vox DA5, an amplifier for my electric guitar. it does not work anymore. when i plug it and hit the switch, nothing happens. i opened it and tested the voltage and everything seems to be fine. HALP!!
SOURCE: Can't load photos to computer
Also if the computer's file management system successfully allowed you to retrieve the pictures, then the whole computer and camera systems are working. Perhaps you could then reload the camera's software. Sometimes camera software drivers get corrupted. Your camera manufacturer probably has a site to download the latest software with enhancements and fixes.
Posted on May 04, 2007
SOURCE: guitar/amplifier 'buzz'
I have two amps .i need to know how to set the knobs on them. to get the best sound out of them .i have a crate and a drive elite.i am a beginner. they are both bass amps. so PLEASE HELP ME
Posted on Dec 27, 2007
Benimur
  • 6966 Answers
SOURCE: Cobra PR4100-2 WXVP with VOX
Hi Dave,
On some other models/brands, you need to use an external mic/spkr such as a headset for the VOX to operate. This may or may not also work for your model. Perhaps you can try getting hold of a headset that will fit your model and see if it works.
If you are already using a headset:
1. If it is a compatible model, then something is wrong electronically with your unit and you will need the services of a qualified communications technician;
2. if it is a generic or some other brand/model, then the pins, jacks, plugs or connectors may not be wired to be compatible with your Cobras. You need to get Cobra compatible ones.
Hope this be of some help/idea. pls post back how things turnes ouot or should you need additional information.
Good luck and kind regards.
Posted on Dec 31, 2007
  • 8 Answers
SOURCE: WHIRLPOOL DRYER WON'T START
Do you have power to dryer?
Posted on Mar 27, 2008
  • 13433 Answers
SOURCE: Hit start button and nothing happens
read this page
http://www.repairclinic.com/0088_9_1.asp
Posted on Jul 28, 2008
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Apr 12, 2014 | VOX Amplification Vox VT40+ Valvetronix...
Vox vt40+
that is because it is two different output channels. eventually you will blow the speaker or your amp. It wasn't designed to handle the impedance of an external speaker through the stereo
headphone jack. Are you sure that your speaker is hooked up or plugged in?
Mar 30, 2014 | VOX Amplification Vox VT40+ Valvetronix...
Vox valvetronic amplifier static crackle
Check the speaker for a loose dustcap or separated spider.
Nov 20, 2013 | Audio Players & Recorders
My da5 does not work on battery power
Not to suggest you are an amateur; I'm sure you are not. Nor do I suggest that I am, but if the amp works fine on AC, then the problem must lie in either the polarity of the C-cell batteries (put in wrong) or the contact points are dirty. That's all I got, Jack. . .
JB
Sep 16, 2013 | VOX Da5 5w Battery Powered Digital...
No funciona al amplificador de potencia, si el resto
Could you please translate into our site language. Thanks
Dec 26, 2011 | VOX DA5 Digital Modeling Portable Electric...
Lately, the sound/signal fades to nothing a few seconds after I begin using. I've changed batteries so thats not the issue. Dunno if its time to chuck it or now, about a year old.
The fact that signal fades is indicative of something with a time delay. The question is where the delay is. If your guitar has a preamp and this device due to wear or contamination on the plug breaks the battery connection within the guitar, the problem could be a worn jack in the guitar that MAY work with your normal cable but not this Amplug due to slight size differences. Other problems could be corrosion on the battery connections in the Amplug. Sometimes headphone cables go bad so try those in another audio source and make sure they are solid. Sometimes these thing have real weak switches and the intial actio of turning it on momentarily connects the batterry, charging the internal filter capacitors which then bleed off... so try working the switch and see if it pops back on..
Jan 29, 2011 | Bass Vox Ap-bs Amplug Bass Headphone...
Where can i get the hi-input plug jensen 600w amplifier? amplifier made by audio-vox, model jpa460, 10 prong socket
You will have to call Jensen. They normally don't come with amps anymore as most users prefer the RCA input for better clarity and sound quality.
Aug 11, 2009 | Jensen 100W x 4 Amplifier KA5 Car Audio...
Feedback overpowers amp output...I have fixed my guitars, fixed and replaced chords, tried other amps, tried other guitars, and nothing seems to fix the problem...If there a way to switch polarity on this...
Hi there. If there is still feedback with nothing plugged into the amp, the problem is internal to the amp. Probably worn input jack or intermittent connector internal. Try thumping on amp with nothing hooked up. (guitar)
Thanks
Paul
Jul 03, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Guitar/amplifier 'buzz'
Dec 27, 2007 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
80 people viewed this question
 Grubhead
Grubhead
