Question about Toshiba TLP 261 Multimedia Projector
Camera Problem with Toshiba TLP 261
When the projector input is set to the camera, there is no clear image. The light works. The camera will not focus at all. I can place my hand under the camera and you can notice movement when moving it back and forth, but you can not distinguish what the image is whatsoever.
    Champion:
  • 277 Answers
Hi Document camera image is blurry: -The lens is dirty - Clean the lens with a blower or lens cleaner -The picture is out of focus - Focus the picture by turning the focus ring -The light is not on - Turn on the light check user manual for more details: http://www.fixya.com/BrowseManual.aspx?mnlid=5662&prdid=147420&__PAGED_=1 good luck
Posted on Mar 27, 2006
UPSIDE DOWN IMAGE TLP261 LCD
You need to get into the menu, there is an invert image option as the projector can be mounted upright or upside down depending on the mounting of the projector
Mar 08, 2012 | Toshiba TLP 261 Multimedia Projector
I have a toshiba tlp 770 projector. The image is not sharp and i bought it on ebay. How do I make the image sharper?
first, reset the settings to factory default. if you are using it with a computer, make sure it matches resolution. native for the projector is 1024x768, but maxes at 1600x1200. and the input is analog, not digital. if you are doing video, make sure you are on the correct video input. it does do hdtv, but not 480p or 480i. if none of this helps and the focus does not work, check case for signs of damage. maybe the previous owner dropped it and damaged something internal. last possibility: clean it out using compressed air. take the top off if necessary. since it is an lcd projector, dust and dirt build up on lenses and light filters causing them to burn. remove the lamp and look at the fly-eye lens inside the lamp housing. if you can see the one behind it, check for burn marks. there may be parts that need replacing.
Aug 15, 2009 | Toshiba TLP-770, TLP771 Replacement...
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Toshiba TLP 261
What do you mean by red filter? There is no red filter in this unit.
Apr 08, 2008 | Toshiba TLP 261 Multimedia Projector
Document camera
Please check with connection of camera cable. And check the input checking. This camera has single pcb board. So check with your nearest service center.
Jan 22, 2008 | Toshiba TLP 261 Multimedia Projector
Out of focus...
http://www.projectorcentral.com/pdf/projector_manual_1798.pdf.
please read manual above.
Oct 25, 2007 | Toshiba TLP 261 Multimedia Projector
Projection Problem with Toshiba TLP 261
If its only in the lower left corner sounds as somethings blocking the lamp from the lcd These sets dont use a degussing coil so we know its not a magnetic problem Check and see if something crawed inside the set and is blocking a bit of the lcd?? ar could be dirt or dust too??
Mar 28, 2006 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP 261 Multimedia Projector Logo
106 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
