Question about Ricoh Aficio 450e Laser Printer
Error message Each time I turn the printer on, the wrench icon comes on and gives me a SC 541-00 message. printer does not go any further
  • ariel santos
    ariel santos May 11, 2010
    what is your brnad and model number?
  • 162 Answers
SC541: Fusing Thermistor Open
Fusing thermistor defective or out of position
Poor thermistor terminal connection
Poor connection in socle of fusing.
Posted on Sep 25, 2009
4 Suggested Answers
  • 398 Answers
SOURCE: SC 541
Take the fuser out and clean under the thermistors, and reset the code by entering test mode ( turn off printer hold down online and escape as you turn on printer selece 2 engine go to sp5-810 and reset this.
-Carl, please let me know if this helps.
Posted on Jun 25, 2009
drichards
  • 87 Answers
SOURCE: Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Posted on Apr 01, 2008
SOURCE: error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Posted on Nov 10, 2008
Getting a red ''wrench'' symbol, spits out blank page when making copy, error message to turn off/on main switch which we have done, but doesn't clear the error. The red ''wrench'' symbol keeps coming...
Press "clear/stop" and "8" at the same time. An error code will be displayed as long as these two buttons are held down. What is the error code? Let me know, please.
Sep 01, 2009 | Lanier Office Equipment & Supplies
Error message of Sc 725 Ricoh copier
Description:
Finisher stack feed-out motor error
Symptom:
The stack feed-out belt HP sensor does not activate within a certain time after
the stack feed-out motor turned on.
Possible Cause:
Stack feed-out HP sensor defective
Stack feed-out motor overload
Stack feed-out motor defective
Aug 25, 2009 | Office Equipment & Supplies
Wrench icon 350e
The HDD control board does not generate any response when the IPU sends a
read/write signal to the MSU.
• Software defective
• Poor connection between BICU and MSU
• HDD defective.
Try reset the software; press the keys numeral and point simultaneously by but of 10 seconds, the machine is extinguished and returned to ignite. If it does not react to this it can be damaged the hard disk changes it.
Jul 27, 2009 | Ricoh Aficio 350e Printer
My Ricoh Afficio 2232C doesn't print and it gives me this message: "Functional problems within your computer. Turn operation on then off. If the error appears again, call service. SC 440-01."Several times...
A 440-1 is a black drum motor lock. The waste toner in the black pcu is backed up, more then likley. It is not easy to fix. You could replace the black pcu but it will happen again. The usual problem is oil in the main waste toner system. It clumps up the toner and clogs the part where all the waste toner comes together for entry into the waste toner bottle.
May 26, 2009 | Ricoh Aficio CL7200 Laser Printer
Error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Feb 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Error message sc 172 on ricoh aficio color 2103
You'll need a tech on site for this one, but it may be difficult to source parts if required for this old box. One of the following situations has occured:
• Poor connection of CCD
harness
• Dirty optics
• Defective lamp regulator
• Defective main scanner IPU board
• Defective CCD
Ricoh AP2600 printer gives an error message of SC322
1st Laser synchronization error signal error. The 1st Laser that turns on inside of the printer can't synchronize properly to print out documents which is why this message comes up and nothing is printing. Probably is going to need to be replaced but a qualified service tech is going to need to look at it further.
Feb 10, 2009 | Ricoh Aficio AP2600 Laser Printer
SPANNER SYMBOL ON MESSAGE PANEL
What SC code is the machine giving? Watch the LCD display and the machine will give an SC Code. Let us know this and we may be help to further.
Mar 10, 2008 | Ricoh Aficio 1018 Printer
207 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
