Installing Envision AOC 2219S-1 monitor on Compaq F700. Display appears when computer boots up then goes to a small display saying Out Of Range. Monitor is brand new.
Benimur
  • 6966 Answers
SOURCE: hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Posted on Apr 28, 2007
techniwiz
  • 275 Answers
SOURCE: Monitor goes blank after seeing XP during boot up.
did u replace the video card with the same kind of model ? i guess yes ... when system starts hit the f8 key and than go in to safe mode ... mouse wont work so use arrow on the keyboard .. and in the safe mode just log in to admin account if available or login to ur account and see if that still happens .. and if it doesnt ... remove the drivers for the graphic card from add and remove programs and restart the system and go in the normal mode and than install the drivers again ... and if the display disappears in the safe mode or u have install a different graphic card than ... reseat the memory cards and that should resolve the issue .... if that doesnt work out when the system starts hit f1 and stay on the BIOS screen for 30 mins if the system doesnt loose display than u need to reinstall OS ... that will surely work out ... the resolutions given above if u follow them correctly u will have a working system in no time
Posted on Feb 07, 2009
Vivektj
  • 55 Answers
SOURCE: computer only displays vertical lines and pink background.
Most likely an issue with the Video Card or Video driver.
* Boot to safe mode by tapping F8 while starting up the computer. Selected safe mode with the keyboard and hit enter. Login to your user account. You should see the words “Safe Mode” on all four corners,
* Open device manager – Right click “My Computer” – Select “Manage” – Selected device manager from the left. Under display driver, you should see your vide card listed. Right click on it and select “Disable”.
Now restart your computer and if this resolves the issue, then the vide card may be at fault. You could also try updating the video driver.
Do let me know if you get this far.
Posted on Mar 02, 2009
  • 415 Answers
SOURCE: Computer not communicating a signal to monitor
You can fix that by getting a new graphics card
I'm assuming you have a T3830 emachine.
here's the link to replace video card
http://downloads.emachines.com/userguides/8511279_eM_NG3_chassis_HW_ref_en.pdf
Mark
Posted on Apr 09, 2009
chinmay_lp
  • 271 Answers
SOURCE: attention out of range is displayed on ibm 2 74 monitor
To resolve this behavior, either change the refresh rate, or change the video adapter settings.
To change the refresh rate:
  1. Restart the computer, and while it is restarting, press F8 until the Startup menu appears. Press 3, and then press ENTER to start the computer in Safe mode.
  2. Right-click the desktop, click Properties, and then click Settings.
  3. Click Advanced, click Adapter, and then click Adapter Default from the Refresh Rate list.
  4. Click OK, click OK again, and then click Yes to restart the computer in Normal mode.
You can set the colors and screen area to your preferences under Display Properties.
To change the video adapter settings:
  3. Click Advanced, click Adapter, and then click Change.
  4. Click Next, and then click Display a list of all the drivers in a specific location, so you can select the driver you want.
  5. Click Next, click Show all hardware, and then click Standard display types under Manufacturers.
  6. Click Standard Display Adapter (VGA), and then click Next.
  7. Click Yes, click Next, click Finish, and then click Yes to restart the computer.
  8. After the computer starts, right-click the desktop, click Properties, and then click Settings.
  9. Click 256 colors, click Apply, and then restart the computer.
  10. After the computer starts, click Start, point to Settings, click Control Panel, and then double-click System.
  11. Click Device Manager, click View devices by type, and then click Display adapters.
  12. Click Standard Display Adapter (VGA), click Remove, and then click OK.
  13. Install all updated monitor drivers.
Posted on Apr 13, 2009
How can i change AOC monitor to wide screen, menu bar does not highlight. I have three monitors and the one on display port is wide screen by itself.
go into the computer , control panel find the appearance and personalization section ans change the aspect ration of the screen there. don't forget to apply and save(ok) before leaving
Feb 13, 2015 | AOC Computers & Internet
My aoc monitor does not display properly it has a line whats the solution on this?
If I recently purchased the 'Envision' monitor from Radio Shack or another retailer, I would return or exchange it for another one.
The screen is damaged, most likely.
Nov 12, 2010 | AOC Computers & Internet
Get a message that says out off range while the green L.E.D. light flashes. then the monitor goes off. any Ideas??
Yes, your computer's video resolution is set too high, an easy way to fix this is by booting your computer in safe mode. you can put your computer in safe mode by pressing f8 continuously while it is booting up. Then you go to control panel>display and change the resolution and pressing apply.
Jun 16, 2010 | Compaq MV 520 Monitor
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
In the middle of my screen a blue box is showing and in it this reads OUT OF RANGE H. FREQUENCY 68.7 KHz V. FREQUENCY 85.0Hz What does this mean and how can I fix it this was a gift...
That message appears when the Windoze display settings exceed the monitor capabilities. If you will boot into windoze safe mode (F8 at boot) and correct the display settings, the message should clear at the next boot. Afterwards you can right click on the desktop and access the display settings to make final adjustments.
In your case, the refresh rate (V Frequency) should not exceed 70 Hz
Nov 23, 2009 | Envision H22W 22" Monitor
Bought new aoc monitor and plugged in and all I get a floating screen safer saying "input not support".
Your display resolution is set to something outside the range your AOC supports.
Start Windows in VGA mode (pick that option from the startup menu you get when you press F8 after the manufacturer's logo comes when you turn the computer on). Then set the display mode to 16-bit color and 800X600 resolution. This will allow Windows to start up next time with settings just about every monitor can handle.
Once WIndows is up and running, make sure you change your display settings to something the monitor can handle. Specs are in the manual or on the manufacturer's website, but resolution of 1024X768 should be another safe choice. You should also think about installing any driver software supplied with the monitor.
Dec 08, 2008 | Computers & Internet
"Not support Out of range"
You have to boot your PC in safe mode using press F8 key.
after that you decrease the resolution in the display setting section.
It will help you.
Nov 29, 2008 | AOC CT720G 17" CRT Monitor
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
361 people viewed this question
David Payne
David Payne
