Washer/dryer combo spin cycle.
My wife put a large rug in our Whirlpool thin twin washer/dryer and now the spin cycle wont engage. the motor runs, the belt operates,and the pumps work but there seems to be a gear or a relay that wont operate the tub. I have dissassembled it as far as I dare( I have removed the inner tub). Is there a skematic on the net somewhere that shows how to remove and install parts?
  • 1 more comment
  • ajohnson608 Sep 10, 2008
    Thanks Rick: I am having a little difficulty getting the outer barrel off the main shaft. Is there an easier way to get at this bearing. I am still hopeing for a diagram of this machine.
  • ajohnson608 Sep 13, 2008
    This turned out to be the simplest thing! After I completly tore the whole thing apart I discovered the tip of the safety latch onthe top door had broken off and would not actuate the spin cycle. I am honest to admit this should have been the first thing to check, but no one mentioned this.
    See my last comment
  • 76 Answers
Http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246307
Also see if the model num is the same if not re enter the num on that web page.
Good luck...
Posted on Sep 10, 2008
    Genius:
  • 3,422 Answers
HI,
Please click on the below link and check out the video.It is not exactly for your model.But it might give you some ideas:
http://www.ehow.com/video_2111176_check-washing-machine-bearings-worn.html
    Brigadier General:
  • 5,158 Answers
To give you competent and accurate advice it would require knowing the brand and model number. please provide that information ... thanks
Robert
    Master:
  • 505 Answers
You probably damage the gear or bearings from the weigh of the rug.
Thats my best option i have to offer
  • Washing Mach... Master
  • 13,433 Answers
Hey,
Have a look here,
http://www.repairclinic.com/0088_11_1.asp
your problem is on the list, also replacement parts are available from
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Let me know if you need more help
Thanks,
Ekse
    Genius:
  • 1,011 Answers
Whats the model of it
regards,
  • SALMAN NASEER Sep 10, 2008
    dear,
    is there anything stucked in the inner tub, or u can see the moving part that deals with the tub.
    regards,
    dont rate it until u satisfied
    Master:
  • 726 Answers
The clutch bearing must be gone worn out
Water not filling on washer
the inlet filter is probably clogged restricted and/or inhibited flow of water into your machine.
These things happen, and cleaning out the filter is a good first step to finding the problem.
May 11, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
