Thermador PRG304US Gas Kitchen Range Logo
Posted on Sep 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oven light burned out and the cover won't come off
The oven light burned out, but I can't remove the cover (to allow me to change the bulb). I have tried turning it as well as pulling it. I finally called Thermador today, and they told me it has to be changed by a technician. What?! It's going to cost me $99 to change a light bulb?
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 331 Answers
  • Posted on Sep 10, 2008
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
331
Questions
Helped
108316
Points
863
Come on .................
it may just be that the screws have been put in tightly
ask someone else nearby.......who has the knack to open thse
you will find some one
no need to pay 99 dollars for this......
Anonymous
Level 3:
Master:
  • Master 726 Answers
Anonymous
Master
Level 3:
Master:
Answers
726
Questions
5
Helped
257069
Points
1674
I had a look at the model it looks bult in from inside the oven has to have a special tool to undo it he has to take of a few covers also but he should do it cheaper then 99 he is ripping u off call around more people first see what they say
1helpful
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
1helpful
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
6helpful
Light Bulb Burned Out
The outside cover usually has to be removed to change the bulb. SImply unplug the oven and remove the screws on the back holding the cover on, and slide the cover to the rear. Replacement bulbs are often challenging to find.
How do i change the bulbs on a jvm1870sk03 microwave
That's covered on pages 35 & 36 of the owner's manual here.
your GE supplier.
or pull the plug. *
to open.
Oven Light
GE supplier.
or pull the plug.
cover off.
cover.
power to the oven.
* If your control board was damaged (lights won't come on, won't go off, fan or turntable not working right) after a cooktop light bulb blew or was inserted or removed while power was on, see here.
1helpful
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
4helpful
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 • Ovens
    1helpful
    Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
    From the owner's manual:
    On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
    On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
    20-watt halogen bulb (WB36X10213), available from your GE supplier.
    To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
    Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
    Be sure the bulb(s) to be replaced are cool before removing.
    After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
    Oven Light
    Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
    GE supplier.
    To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
    Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
    On some models, the light cover is located in the center of the top opening.
    Remove the screw that secures the light cover and lift the cover off.
    On some models, the light cover is located at the left of the top opening.
    Lift the cover off.
    Pinch the clips that hold the light socket in place and lift the socket out.
    Remove the bulb from the light socket by pulling straight out.
    Replace with the same size and type bulb, then replace the light socket and cover.
    Light bulb burned out in microwave oven
    Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
    It won't hurt to run the microwave without a bulb.
    Burned out bulb
    you may have to rmove it from the back part of the oven. there should be access screws to allow you to change the bulb from the back
    LG LRE30451SW range
    The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
    Top Thermador Kitchen Ranges Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Sean Wright
    Sean Wright
    Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
