Question about Fisher and Paykel Washing Machines
Hi, My washing machine washes for 10minutes and then beaps until I turn it off. It is full off water and i can't drain it. It's a Smart Pride Drive 5.5. Thank you. Tara
Mine was doing that but it's not any more. I think it may have been too heavy/packed. Have you tried packing the washing in more losely and not filling it quite up to the top?
Posted on Nov 20, 2008
Cold water not pulling into Fisher & Paykel 5.5kg Smart Drive Pride.
Either the cold water inlet solenoid has failed or there is a fault with the electronic control module, Unfortunately the only way to find out is to replace the cold water solenoid and see if it works, if it doesn't then the electronic control board is faulty.
Mar 16, 2017 | Fisher Washing Machines
Hello I have a Fisher and paykel 7.5g smart drive excellence washing machine it doesn't spin and I can smell something burning.thanku Kelly
Has it drained the water out. It will not spin until completely empty. If it is not draining then Iwould say the burning smell is the drain pump overheating. Do not try to run it like that as the drain pump will short out the main control board eventually. Bail the water out by hand, tip the machine back against the wall and check the pump on the front right side of bowl. Replace the pump.
Jan 04, 2017 | Fisher and Paykel Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Hi I have a fisher and pykel fresh smart drive 9 and its filled up with water but wont drain,ive tried advancing the cycle but all I get is a humming noise.please help
The humming noise is due to the drain pump being jammed due to clogging of dirt. All you need is to remove the drain pump and do a full clean up. You can also try to tap on the drain pump while it is humming as it will release the dirt and wash off.
Sep 07, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washing machine
It could be a faulty lid switch in the blue display board.
The smaller one of the two has the lid switch in it.
Sep 12, 2012 | Fisher and Paykel Washing Machines
I have a Frigidaire Pride Smart Drive top loader washing machine and I would like to give the bowl and inside where the powder goes in, a jolly good clean. How do I go about this? I'm worried that...
hi i have a fridgedair pride 5.5 wen i turn my washing machine on theirs know water going into the machine the water keeps going stop go stop go how can i fix the problem every thing else is fine.
May 26, 2011 | Fisher and Paykel Washing Machines
Fault code 37,what does indicate.
Hi just read your posting.This error code is called PUMP BLOCK ERROR.Now please look under the machine for me to the front right.You should see a red or black fan,This is your pump.Now turn the fan clockwise and anticlockwise a few times to loosen it up if it is jammed.The fan should turn freely.Now put the machine back on its feet and select a spin cycle.The machine should start to drain.Please reply to tell me how you got on or if it still does not drain or if you have the other type of pump.Good luck
Jul 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Aug 05, 2008 | Washing Machines
Washing Machines Logo
111 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
