Question about HP Pavilion dv9000z Notebook
Got disconnected somehow
Both modules are removed. will i be charged double for disconnecting? lost connection and had to log back in.
  • HP Master
  • 13,433 Answers
Hey I sent you a comment into the chat session and also a answer into the other question you sent me.
Posted on Sep 10, 2008
Where is the body control mod. on a 2000 excursion?
Generic Electronic Module (GEM)-Generic Electronic/Central Timer (GEM/CTM) Removal
NOTE: The GEM must be reconfigured upon replacement. Refer to the scan tool help screen on the Ford Service Function (FSF) card to program tire size and axle ratio.
  1. CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.Disconnect the battery ground cable. For additional information, refer to Section 414-01.
  1. CAUTION: Use care when removing the instrument panel steering column cover (044F08) or damage to the cover locating tab may occur.Remove the instrument panel steering column cover.
    1. Unlock the retainers.
    1. Remove the instrument panel steering column cover.
  1. Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
    1. Loosen the bolts.
    1. Disconnect the bulkhead connectors.
  1. Position the instrument panel fuse junction panel aside.
    1. Remove the nuts.
    1. Remove the bolts.
  1. Remove the generic electronic module/central timer module (GEM/CTM).
    1. Disconnect the electrical connectors.
    1. Remove the screws.
    1. Remove the GEM/CTM.
  1. To install, reverse the removal procedure.
I believe ford calls it a gem module.
Jan 23, 2018 | Cars & Trucks
Removed radio from 1995 celica and now the turn signals do not work
Start with checking you automotive fuses to see if fuses going to the turn signals were blown by accident. Also check to see that wires that plug into your fuse block or power distribution block were not inadvertently pulled out. One of the signal light wires might have been pulled out. Also check to see that your flasher module was not pulled out of it holder. The flasher module is also sometimes called the blinker module. It controls the rate of blinking. If disconnected, your lights won't blink. Somehow you have lost 12 volt power because you have likely disconnected a wire when pulling your radio.
Nov 05, 2014 | 1995 Toyota Celica
How to replace the heater core in a 1998 gmc Yukon.
Heater Core Removal & Installation To Remove:
  1. Disconnect the negative battery cable.
  2. Drain the coolant from the engine.
  3. Recover the refrigerant.
  4. Remove the glove compartment.
  5. Remove the floor air outlet.
  6. If equipped with a diesel engine, remove the powertrain control module.
  7. Remove the kick panel trim.
  8. Remove the blower motor.
  9. Remove the steering column.
  10. Tilt back the instrument panel assembly.
  11. Remove the coolant recovery reservoir from the engine compartment.
  12. Disconnect the heater hoses and the evaporator tube.
  13. Remove the accumulator.
  14. Remove the fasteners and the HVAC module assembly.
  15. Remove the cover plate on the bottom of the HVAC module.
  16. Remove the heater core and seal from the HVAC module.
To Install:
  1. Install the heater core and seal.
  2. Install the cover plate on the bottom of the evaporator case to the HVAC module.
  3. Install the HVAC module in the vehicle.
  4. Install the accumulator.
  5. Connect the evaporator tube and heater hoses.
  6. Install the coolant recovery reservoir.
  7. Install the instrument panel.
  8. Install the steering column.
  9. Install the blower motor and cover.
  10. Install the kick panel trim.
  11. Install the powertrain control module and tray.
  12. Install the floor air outlet.
  13. Add coolant to the cooling system.
  14. Connect the negative battery cable.
  15. Evacuate and charge the A/C system.
  16. Check the system for leaks.
Nov 06, 2010 | 1998 GMC Yukon
Locate lcm module 98 lincolin wont stay on
LCM is usually under dash above driver's feet.
They are $400. Gino on ebay fixes them a lot cheaper. Just search for lighting control module and you will find him.
SECTION 419-10: Multi-Function Electronic Control Modules 1998 Town Car Workshop Manual
REMOVAL AND INSTALLATION Module -Lighting Control (LCM) Removal
  1. swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Prior to removal of module, it is necessary to upload module configuration information to New Generation STAR (NGS) Tester. This information needs to be downloaded into the new module once installed.
    swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
  1. Remove the LH instrument panel lower insulator.
    1. Remove the pin-type retainers.
    1. Disconnect the courtesy lamp.
    1. Remove the LH instrument panel insulator.
  1. Position the LCM aside.
    1. Release the locking tab.
  1. Remove the LCM.
    1. Remove the LCM.
Installation
  1. swg~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the new module is installed, it is necessary to download the module configuration information from New Generation STAR (NGS) Tester into the new module.
    NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns it adaptive strategy. The vehicle may need to be drive 16 km (10 miles) or more to relearn the strategy.
Oct 30, 2010 | 1998 Lincoln Town Car
How to remove fascia around audio unit in 2001 hyundai elantra
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect the negative battery cable and wait 90 seconds for the SRS memory battery to drain.
    CAUTION
    After disconnecting the negative battery cable, wait for at least 30 seconds for the SRS module to deplete its stored energy.
  3. Remove or disconnect the following:
  4. Remove the SRS module and the steering wheel:
    • Steering wheel-to-SRS module nuts
    • SRS module from the steering wheel and disconnect the electrical connector
    • Steering wheel-to-steering column nut
    • Steering wheel from the steering column
  5. Remove or disconnect the following:
    • Multi-function switch assembly
    • Front and rear console assemblies
    • Lower left side crash pad
    • Instrument panel
      Instrument panel assembly-Accent
      Instrument panel screw locations-Accent
      Click to Enlarge
To install:
  • Instrument panel
  1. Install the SRS module and the steering wheel by installing or connecting the following:
    • Steering wheel to the steering column
    • Steering wheel-to-steering column nut and torque to 30-37 ft. lbs. (40-50 Nm)
    • SRS module to the steering wheel and connect the electrical connector
  2. Install or connect the following:
    • Suction and discharge hoses to the evaporator assembly
    • Heater hoses with the vacuum hose to the heater housing
  3. Refill the cooling system.
  5. Evacuate, charge and leak test the air conditioning system refrigerant.
  6. Operate the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Oct 29, 2010 | 2001 Hyundai Elantra
Change evaporator 1996 cheve truck 1500 350
  17. Remove the case cover from the HVAC module.
  18. Remove the evaporator core.
To Install:
NOTE: If a new evaporator is being installed, add 3 fl oz (90 ml) of refrigerant oil to the new evaporator.
  1. Install the evaporator core.
  2. Install the case cover.
  3. Install the heater core and the seal.
  4. Install the cover plate on the bottom of the evaporator case to the HVAC module.
  5. Install the HVAC module in the vehicle.
  6. Install the accumulator.
  7. Connect the evaporator tube and heater hoses.
  8. Install the coolant recovery reservoir.
  9. Install the instrument panel.
  10. Install the steering column.
  11. Install the blower motor and cover.
  12. Install the kick panel trim.
  13. Install the powertrain control module and tray.
  14. Install the floor air outlet.
  15. Add coolant to the cooling system.
  16. Connect the negative battery cable.
  17. Evacuate and charge the A/C system.
  18. Check the system for leaks.
Aug 14, 2010 | 1996 Chevrolet C1500
How do you change fuel pump on a 04 dodge intrepid?
hope this helps...
Pump Module—Left Side
  1. Release the fuel pressure.
  2. Disconnect negative battery cable.
    NOTE The fuel level of the vehicle must be below 5/8 of a tank before you remove the module lock-rings. If it is above that you can spill fuel in the vehicle.
  3. Drain partial fuel from fuel tank through the filler tube. Use a hard nylon tube, with a 30° cut on the end, to push the check valve open to drain fuel from tank.
  4. Remove the rear lower seat cushion.
  5. Push seat back and up to remove seat cushion.
  6. Fold back the foam pad covering access cover for modules.
  7. Disconnect the electrical connector from left side module.
  8. Mark the module orientation.
  9. Use special tool 9340 to remove left side module lock ring.
  10. Drain fuel from left side of fuel tank. Lift module up enough to push hose into tank and drain. Do not spill fuel in interior of vehicle.
  11. Disconnect the electrical connector for the left side fuel level card from bottom of the module top.
  12. Disconnect the electrical connector for the right side fuel level sending card.
  13. Lift module top half off and tip lower half on its side to drain remaining fuel from the reservoir.
  14. Remove wire from module.
  15. Use a screwdriver to separate the locking tabs on the level sending card.
  16. Lift level sending card straight up and out of module.
  17. Disconnect the electrical wiring from module.
  18. Remove level sending card.
To install:
  1. Install level sending card, make sure that the locking tabs are locked on the card.
  2. Route wires in the proper location.
  3. Install module top to module bottom.
  4. Connect the electrical connectors for right side fuel level sending card, left side module card and fuel pump.
  5. Install module and align marks on the module for proper orientation.
  6. Install module lock-ring.
  7. Use special tool #9340 to tighten left side module lock ring.
  8. Connect the electrical connector to left side module and install plastic access cover.
  9. Fold the foam pad covering access cover for modules back into place.
  10. Install rear lower seat cushion
  11. Rear lower seat cushion installed.
  12. Fill fuel tank.
  13. Connect negative battery cable.
  14. Fill fuel tank. Use the scan tool to pressurize the fuel system. Check for
Jan 28, 2010 | 2004 Dodge Intrepid
I need to change the headlamp bulb.
  1. Disconnect and isolate the battery negative cable.
  2. Remove screws attaching headlamp module to upper crossmember.
  3. Remove headlamp module from vehicle.
  4. Disconnect wire connector from back of headlamp.
  5. Remove bulb from headlamp unit.
INSTALLATION
CAUTION: Do not touch the glass of halogen bulbs with fingers or other possibly oily surface, reduced bulb life will result.
  1. Connect wire connectors to the back of headlamp module.
  2. Place headlamp module in position.
  3. Install screws attaching headlamp module to upper crossmember.
  4. Connect battery negative cable.
Mar 21, 2009 | 2003 Dodge SRT-4
How do you remove or replace the passenger airbag on a 99 contour , Is it a whole dash unit? What holds the drivers bag in the steering wheel? I assumed it was a tork but not sure. Where is the control...
Please rate as fixya if this helps.
the air bag control module is under the console.
  1. Disconnect the battery ground cable.
    1. Wait one minute.
  2. Remove the center console. For additional information, refer to Section 501-12 .
  2. Wait one minute.
  3. NOTE: Contour shown, SVT similar.
    Remove the rear floor console screws.
    1. Move seat fully forward.
  1. Fully apply the parking brake.
  1. Detach the shift indicator selector bezel.
  1. Detach the shift bezel from the selector housing.
    1. Remove three bolts.
    1. Detach shift bezel from the console.
  1. NOTE: The rear floor console must be raised to disengage the front retaining clips.
    Raise and remove the rear floor console.
  1. Remove the four front floor console retaining screws.
  1. Detach the front floor console.
    1. Set the gearshift lever into position 1.
      Partially remove the front floor console.
  1. Disconnect the cigar lighter electrical connections and remove the front center console
  1. Disconnect the air bag control module electrical connectors.
    1. Depress the locking tang.
    1. Slide the locking bar back.
    • Disconnect the connector.
  1. NOTE: The air bag control control module is grounded by the retaining bolts.
    Remove the air bag control module.
    • Remove the three bolts.
driver air bag module
  1. Disconnect the battery cables.
  1. Rotate the steering wheel 90 degrees to access and remove the Torx screw. Rotate the steering wheel 180 degrees to access and remove the Torx screws.
  1. Remove the driver air bag module.
    • Disconnect the electrical connector.
    • Remove the air bag module.
  1. Disconnect the battery cables. For additional information, refer to Section 414-01 .
  1. Open the glove compartment, press the sides inward and lower the glove compartment to the floor.
  1. Remove the passenger air vent duct.
    1. Disconnect the duct from the heater box housing.
    1. Disconnect the duct from the instrument panel register and remove.
  1. Disconnect the passenger air bag module electrical connector.
  1. Remove the two retaining bolts securing the rear of the passenger air bag module to the cross-vehicle beam.
  1. sxp~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Support the passenger air bag module when removing the retaining nuts.
    Remove the two nuts from the front of the passenger air bag module.
  1. Remove the passenger air bag module.
    • Lower the front edge of the passenger air bag module, roll the passenger air bag module around the cross-vehicle beam lowering it into the passenger footwell.
Mar 15, 2009 | 1999 Ford Contour
I need installation directions for installation of a gem module
here it is but you must have it configured.
Generic Electronic Module (GEM) —Generic Electronic/Central Timer (GEM/CTM) Removal
  1. syo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  2. syo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the instrument panel steering column cover (044F08) or damage to the cover locating tab may occur.
  3. Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
  4. Position the instrument panel fuse junction panel aside.
  5. Remove the nuts.
  6. Remove the bolts.
  7. Remove the generic electronic module/central timer module (GEM/CTM).
Feb 20, 2009 | 2000 Ford F250 Super Duty Crew Cabs
HP Pavilion dv9000z Notebook Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
