Question about Sharp 27C-240 27" TV
TV turns of automatically
My TV turns off automatically after just a few seconds. If I unplug and replug it in, it re-sets and I can turn it on again. This worked for several months but now it never stays on for more than a few seconds.
    Scholar:
  • 124 Answers
Could be noumerous things: 1. check power supply, too high or too low voultage may cause TV to shut down. measure it to detarmine if power supply is faulty. 2. check convergence board. If either of these 2 fuses on the convergence panel are open then replace the STK output devices PLUS check for any resistors in that circuit that may have overheated and changed value. Use actual fuse values, putting in a larger fuse, even to try and diagnose problem, will cause more severe damage. 3. Check for bad solder connects on the PC board in the area of the power cord and related components. good luck
Posted on Mar 27, 2006
TV shuts off a few seconds after turning on. I have to unplug and replug to get it to turn on again. mus repeat a number of times til it stays on.Is this a big deal? Is it worth repairing?
It sounds like bad connections in the high voltage transformer and the horizontal driver transformer on the main board, if the tv is more than 10 years old you are further off putting your money towards a new set.
Apr 22, 2011 | Zenith Televison & Video
Hi my son got a 19inch emerson tv for his 2nd birthday and now anytime it gets plugged in it flashes different colors and the buttons does't work and the only way to turn it off is to unplug it!! can this...
Press the the cursor key up followed by down and power the TV off with the remote or the TV itself. Please use the original remote for this. Unplug the TV for a few seconds...replug and power the TV on. The second thing to try...press the cursor key left followed by the right key. Power the the TV off with the remote or the TV itself. Unplug for a few seconds...replug and power up the TV. Some of these TVs left the factory in the service mode. The fix is pretty simple. Thanks asking and show a few hands of support!
Feb 14, 2011 | Emerson LC195EM9 19 in. LCD TV
Philips 26PF5521d LCD TV turns on screen lights for a few seconds then turns off leaving green led flashing Any help apreciated
Tries unplug,replug the tv back like an hour later.Now,the tv is resetting itself back to the factory setting.The tv now,should work again.Not,than the power supply board is the cause.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Oct 27, 2010 | Dynex DX-LCD37 TV
I have the protron 3750 the power light is red when i turned the power on the light turned green for a few second then turned red again and nothing happened. can you help?
Tries unplug,replug the tv like an hour later,the tv,now will reset itself back to the factory setting,tv should work now.Not,than the power supply board is having problems,not giving wright voltages to the tv anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Protron PLTV-37 37 in. LCD Television
Sharp 46 aquos model LC46E77UN tv turned off power button just flashes on and off tried unplugging and waited an hour and replugged same conclusion power light just flashes
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Oct 01, 2009 | Sharp Televison & Video
TV set doesn't change channels or turns off.
UNPLUG THE SET FOR A MINUTE AND REPLUG AND TURN ON SEE IF THE UNIT RESETS. IF PROBLEM PERSISTS HAVE IT SERVICED. THE BUS MESSAGE IS TELLING US THAT THE COMMUNICATION BETWEEN SEVERAL IC' IS MISSING.
30 YR SERVICER
APGONZO
Jan 12, 2009 | Televison & Video
AKAI LCT2785TA TV does not turn on
look closely at the electrolytic capacitors in the power supply. If you see any with the tops bulging out, replace them. Especially the 1000mfd caps labeled EC9, EC10, EC18, EC19, EC20
Jun 21, 2008 | Televison & Video
LCD Tv turns off automatically within few seconds
It is a software problem sony was fixing for free untill 03/01/08
You can unplug your set from the outlet for 30 seconds and it will work fine untill several hours of use acrue again. Found this out on the sony website. hope it helps.
Jan 13, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Sep 11, 2006 | Panasonic CT-32G11 32" TV
Sharp 27C-240 27" TV Logo
1,086 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
