Question about HP Office Equipment & Supplies
I have downloaded my software for my hp officejet 5510v all-in-one and my scanner part will not work. I have 3 in one--print--does o.k., fax does good some times, will not scan---please help
  • mr15789marg Sep 10, 2008
    after downloading my software again it begain to scan but after it scan it would not let me go to --next--the error was--an unspecified error occured while your pictures were being copied-----0x 0x821001 was the error #
  • HP Master
  • 19,396 Answers
Reinstall software with USB unplugged
Posted on Sep 10, 2008
  • Ginko
    Ginko Sep 10, 2008
    • Unplug printer USB.
    • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
    • Download driver from website and run the file.
    • Follow driver installation wizard.
    • Plug back printer when prompted from installation wizard.
  • HP Master
  • 6,487 Answers
Make sure the scanner software is installed properly, check it under device manager, Right click on Mycomputer icon>Properties>Hardware tab>Device manager then look for the scanner probably its not install properly there, if you see the scanner with a exclamation mark right click on it then click on update driver and manually browse for the driver of the scanner and that should fix this problem...
Hope that helps.......
  • Mark Gil
    Mark Gil Sep 10, 2008
    UNplug the unit for about 2 hours and try to scan again , but if still doesn't work there can be a prblem with some of the scaner parts of this unit and may need some part replacemenet and repair...
  • HP Master
  • 13,433 Answers
Is the scanner installed correctly? Full feature software is that what you have installed?
try starting mspaint and test scanning
start -> run -> type in mspaint click ok
Then file and from scanner or camera, follow instructions to scan,
  • Ekse Sep 10, 2008
    if you can't scan, the scanner is either not installed correctly or something else is wrong.
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
HP J3680 Officejet shows scanner error, will not copy or fax
typically this is a software problem. Please check to make sure you have the correct and most up to date driver installed
Jul 21, 2010 | HP J3680 Officejet All In One Printer
HP Officejet J5780: Cannot scan, copy, or fax from my computer.
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Nov 12, 2009 | HP Officejet J5780 All-In-One InkJet...
Faxing, printing and receivng faxes.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr2
Aug 19, 2009 | HP Officejet 5610 All-In-One InkJet...
How do I get my HP Officejet 6210 all in one to scann?
Usually all the drivers are always installed when you first install the drivers. But may be the drivers are corrupted. Try to reinstall the device by removing and uninstalling and then reinstall. It should help you.
if you like my advice please feel free to rate me thanks.
Mar 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Jan 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
24 people viewed this question
Seeker5211
Seeker5211
