Question about @ Your E-Service AlertSite E-Servive Starter Kit (APAS-21B-WPP-0000) for Mac, PC
Starter problem When I start the 90 jeep Cherokee I only get a clicking sound. I drove it around making 7 to 8 stops and starts on my last start it would not start and made clicking sound. Is that the starter or ? Thanks valerie
  • 640 Answers
Sounds like the battery is dead,and if so the altenator may not be charging the battery.
Posted on Sep 10, 2008
Why wont my Jeep Grand Cherokee Limited start?
Sounds like you have a bad alternator. Not recirculating juice back to the battery.
Jun 16, 2014 | 1999 Jeep Grand Cherokee
1999 Jeep Cherokee Classic - car stalls intermittenly. Just had the CPS changed, could it be as simple as the battery cable?
Sounds like a bad ground. When it wont start run a jumper cable from the negative side of the battery to a good ground on the motor and try the body also. Rule that out first.
Dec 10, 2013 | 1999 Jeep Cherokee
95 jeep grand cherokee larado 6 cylinder, wont start
Reset the timing and check starter ot see if working. Verify fuel pump is actually pumping fuel.
Jan 21, 2013 | 1995 Jeep Grand Cherokee
Where is the idle located on a 1994 Jeep Grand Cherokee limited
It sounds like you do have a relay problem try switching relays around that have the same part number start with the starter relay when switching the make sure the key is off each time
Sep 04, 2012 | 1994 Jeep Grand Cherokee
My 1995 jeep grand cherokee Laredo won't start, or
You might not believe this, but check your battery. Some of these vehicles have cut-outs when the battery level goes below a preset amount.
I work on Ford brands and on them, a low battery level will even disconnect the Alternator circuit and mess with the starter. Some even act up when the battery slightly dips below 12 volts.
Your antitheft can make your starter cut out. And If you think about it, all of the measurements to make the engine run are based on feedback of voltage and amperage. This is how the engine management system adjusts. If your prime source of power is low, then all of the following electrical readings will be low. Some may be too low to work.
Your fuelpump will hold pressure in a closed system for hours. The fuel pressure regulator will command the fuelpump to stop working if the fuel pressure is at maximum. Without responses from the other components and after satisfactory pressure, the fuelpump will turn off.
Mar 20, 2012 | 1995 Jeep Grand Cherokee
My 1995 Jeep Grand cherokee Laredo will not start this morning. There is a relay in the glove box making clicking sounds...I have figured which one it is...could this cause my vehicle not to start? I turn...
The clicking sound is probably the relay that operates the starter motor, but the motor is not engaging. Chances are that this is one of 2 issues. Either you have a flat battery, so the relay clicks but there is not enough power to turn the starter motor or the motor its self is faulty.
An easy test for the battery is to simply open the door of the jeep look at the interior light and put on your headlights, if the interior light dims significantly and the headlights are dim, you have a flat battery!
If its the starter motor its self then begin by checking the connections on the back of the motor to make sure that they are clean and secure. While it's possible that you have a faulty relay, this is fairly unlikely and if the tests above don't give you any leads then you will need to start treating this as a starter motor failure
Jun 16, 2011 | Jeep Grand Cherokee Cars & Trucks
Had problem starting, engine stopped while driving
Have you ever cleaned the throttle valve and idle speed control valve? this is on the stall issue. the starter sounds like the contacts may be burnt in the starter solenoid, this is common on this type of Japanese starter at about this mileage, you can rebuild the starter solenoid or just replace it.
Dec 07, 2008 | 2006 Jeep Grand Cherokee
Clicking sound when trying to start 1987 jeep cherokee.
Probably is the electrical side. Start your vehicle, with the engine running disconnect the positive battery cable. If the engine dies then your alternator is the problem, if engine continues to run the battery is at fault.
Nov 21, 2008 | 1987 Jeep Cherokee
@ Your E-Service AlertSite E-Servive Starter Kit (APAS-21B-WPP-0000) for Mac, PC Logo
60 people viewed this question
Top @ Your E-Service Computers & Internet Experts
David Payne
David Payne
Are you a @ Your E-Service Computer and Internet Expert? Answer questions, earn points and help others
