Question about Sony STR-DE845 Receiver
Sony STR-DE845 center channel cut out, receiver clicks
My center channel has stopped working. There is no output to the center speaker no matter what position switches are in. The speaker itself worked well when tested from one of the stereo outputs. The receiver makes clicking noises occasionally. There is no fault displayed on the front panel. The entire system has been used as currently set up for several years mow. I'm not proficient at repairs but have a friend who is. If I give him the right place to look, he could repair. Any suggestions?
  • 4 more comments
  • Tomos Jan 07, 2008
    Hi. My Sony STRDE875 exhibits the exact same problem. I took apart the amp and re soldered the 5 relays mentioned and also the main board speaker connection. After re assembling, the center channel worked again briefly then failed. Did you find the solution for yours?
    Thanks.
  • Anonymous Jun 17, 2008
    I HAVE THIS UNIT, BUT ONE OF MY REAR SURROUND SPEAKERS ISN'T WORKING. I HAVE A HUMMING SOUND. ANY SUGGESTIONS HOW TO FIX IT. THANKS
  • Anonymous Aug 11, 2008
    pretty amazing. My father in law has a sony and the center went out. My brothers followed not long after, Then mine went few months later. All three are sony receivers. All bought within a year from each other.Must be a big problem. And its funny how its always the center channel. Maybe because this gets the most use. Ill try the solder fix hope it works.
  • randog61 Oct 10, 2008
    I'm finding the 1-676-999-11 part impossible to find. Sony must have sold everyone of them.(imagine that) I'm going to try the repair method but if any one finds any of those parts please leave a note where to get them. Signed, Quiet in Living Room
  • Anonymous Dec 17, 2008
    I have the same problem as others where the sound changes and or fades out and I get the clicking. I notice that most complaints are fairly recent, and my reciever has been acting up every time I turn it on. This make me wonder if it has to do with the switch over from analog signal to the digital.
    Is it possible that from a outside source that our receivers are pulling the digital signal through the antenna and when someone makes changes it affect our receiver's. ?
  • Anonymous Mar 27, 2014
    if i hold the switch at an angle all the speakers work if i switch it to a+b the center speaker wont work it seems it wants to switch it self
    Problem Solver:
  • 5 Answers
I have fixed 3 shorts on my de845. 2 have been caused by cracked solder joints. they were speaker cutout problems...yours most likely is the center channel relay on the main board. take the thing apart. you need to get to the back of the main board and re-flo those solder joints. get your geeky pc buddy and do it together(buy him a sixer). its really not that hard...just a bunch of screws. disconnect everything from the main board including the front plate. be careful with the ribbon cable...mine is hurting at this point. not meant to be removed so many times. put it in straight. my leads bent, but was able to straighten them. there are 5 relays together, one for each channel. they are white cubes and prb a little smaller than the tip of your finger. its the 4 leads on each of these that you want to take a soldering iron to . i'm not sure which ones the center channel so do them all in that area. it may be hard for you to tell which leads they are so just go overboard and at least get everything in the vacinity. i did all component leads because who's to say another's not ready to go bad. you've gone this far. touch the heated up tip to all the leads at the very end of the barb. you can reflow the solder without actually touching it. the metal lead will get hot enough. hold it until the solder liquifies, then let it cool. do this on a flat surface. my other fix once was a re-seating at the speaker switch a,b,a+b on the front plate. there are 2 boards plugged together there. i bent the leads slightly so they seated in more tightly. if your left or right front goes out, sometimes thats an easy fix...try b if you're using a, or the opposite. don't forget the speaker cables. if you're using both zones then you prb already figured out you need to re-flo! test and cross your fingers. good luck.
Posted on Jul 27, 2007
  • Ryan Rossignol Jul 27, 2007
    forgot to check the contact me for more questions box. hope you didn't throw that thing out!
Balls
Posted on Dec 20, 2007
I found the speaker switch solder joints had cracked.  First I did the lead bending as suggested above, but that only worked for a short while.  "my other fix once was a re-seating at the speaker switch a,b,a+b on the front plate. there are 2 boards plugged together there. i bent the leads slightly so they seated in more tightly."
Resoldering the 5-pin connector to the board fixed it; about a year now.
Posted on Sep 08, 2008
    Scholar:
  • 124 Answers
2 quick things to check: 1. make sure that if the unit uses pre-out / main-in jumpers that they ARE present. 2. Check that the Tape 2 monitor is not engaged
Posted on Mar 27, 2006
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Hello. I have an Ultra Linear Amp - UL724 model. I am wiring it up to play in 2 channel mode - in stereo. I can only get one channel to work - the left... I swap the rca cords, still only the left side...
YOUR METHOD OF TROUBLESHOOTING USING THE PROCESS OF ELIMINATION IS RIGHT ON AND PERFECT. IT INDICATES A BAD AMPLIFIER CHANNEL. I KNOW THIS SOUNDS ODD, AS YOU HAVE TWO OF THESE NOW. IT IS RARE, BUT I HAVE SEEN INPUT CONFIGURATION SWITCHES WIRED BACKWARDS, SO THE ONLY THING LEFT TO DO IS TO HOOK UP THE BAD CHANNEL TO ONE SPEAKER ONLY, BY ITSELF. THEN TAKE ONE RCA ONLY AND PLUG IT INTO ONE RCA INPUT AT A TIME. THEN MOVE THE INPUT SWITCHES AND REPEAT THIS PROCEDURE UNTIL YOU HAVE TRIED ALL SWITCH COMBINATIONS AND ALL INPUT JACKS. WHAT YOU ARE TRYING TO DO AT THIS POINT IS TO DETERMINE IF THERE IS ANY RCA JACK WITH ANY SWITCH POSITION, THAT WILL ALLOW YOU TO GET OUTPUT FROM THAT CHANNEL. IF AFTER THIS TEST, YOU STILL HAVE NO OUTPUT, THEN NO MATTER HOW ODD, IT WOULD INDICATE THAT YOU DO IN FACT HAVE A SECOND DEFECTIVE AMPLIFIER. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 07, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
Centre Channel speaker has stopped working
connect any speaker instead of center speaker if you get the same result you will have a problem in amp itself if the problem fixed change center speaker with a new one
Apr 11, 2009 | Audio Players & Recorders
Centre speaker
The controls I would check are speaker set-up and configuration for a multi-channel sound, be sure to enable center channel YES/NO option and trim center channel level output.
Feb 15, 2009 | Kenwood VR-406 Receiver
Center Channel not working on pioneer vsx-d608
Be sure the sound source has a center channel output ie. not a 2 channel source only, try the test tone setup for 5 or 6 channel balance, if no sound from the center channel still then it is looking like maybe the center channel is blown.
Jan 28, 2009 | Pioneer VSX-D608 Receiver
Center channel speaker output problem
Check for the speaker separately for proper working? If needed change the speaker and check it ok.
Jan 07, 2009 | Audio Players & Recorders
Center channel sound output
Its not working correctly I have a few different types of center channels and they all have equal sound no matter how many speakers are in them. Connection in speaker box is bad or you may have a blown speaker
Dec 31, 2008 | Pioneer VSX-455 Receiver
Center speaker channel
This sounds like a bad connection inside the receiver. A 5 minute fix with a soldering iron and about 30 minutes to get to it.
If you can solder you should be able to fix this yourself.
Dan
May 23, 2008 | Yamaha Digital Sound Projector YSP-800S -...
Center speaker not working
Yes Mark, You have a problem with a componet with that center channel. If your not a tech, dont have a schematic, or dont have any training in troubleshooting solid state electronics, unhook everythuing and take it into a repair senter for an estimate, as unless you know how to chech the parts you can cause more damage to the unit as it takes one slip and boom, all gone. Good Luck
Jul 28, 2006 | Sony STR-DE575 Receiver
Sony STR-DE845 Receiver Logo
2,984 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
