Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi tv there is a hole through the screen and i need a repair
  • 1 more comment
  • banksgirl_1 Oct 30, 2008
    SAME PROBLEM MY SON HIT THE TV W/ A SPONGE BAT AND NOW IT IS CRACKED BUT YOU CAN STILL SEE THE PICTURE. THE ONLY TIME IT BOTHERS ME IS WHEN YOU HAVE TO SET TO THE SIDE YOU NOTICE IT MORE. PLEASE HELP I NEED A PART VERY BAD!!!!
  • Anonymous Nov 03, 2008
    Have a WS 55313 Mitsubishi that mu son just threw his wii contraller through. How do I replace screen? Can you help? nathan 805-807-5288
  • Anonymous Jan 27, 2009
    need to buy a new Television screen because mine is cracked. I don't know where to buy one at?
  • 70 Answers
The screen is expensive if you buy it new, usually around 400 dollars.
try getting a secondhand one from tv repairers,this is what i did and it only cost
me 100 dollars.
Posted on Nov 14, 2008
A light horizontal line has appeared on my Samsung UN55C6500 TV. Is there a fix for this?
Horizontal lines on LCD TV,
not usually repairable
plasma may have a corroded or dirty connection on ribbon cable left side of TV looking from the rear
Apr 25, 2017 | Samsung Televison & Video
Find generic dlp lenticular screen and fresnel screen
I would find out the make of the lens, probably cannon. The Fresnel and Lenticular screens are nothing to do with the size of the picture, the lens does that bit.
Oct 01, 2017 | Televison & Video
1996 mitsubishi 40" tv has a black screen and
no pic at all usiually means the the heater element in the picture tube it self is burned out. Also there could be a problem with the internal power supply that gives electricity to the heater element. These are all thing the cunsumer cant fix. You either need to trust ONLY a certified Mitsubishi TV repair man, or replace the TV.
I know it's not great news, but if this advice helps, please give me a good rating.
Jun 30, 2011 | Mitsubishi CS-40505 TV
Dim picture
First, try adjusting your Brightness and Contrast in the Video or Picture settings menu. If this doesn't fix the problem, your LCD Back Lights may have burned out. You will need to either replace the Back Lights, or the LCD screen if they are built-in, take the TV in to a TV repair shop, send the TV back to Mitsubishi for repairs, or replace the TV with another.
Here is the link to Mitsubishi-TV Support: http://www.mitsubishi-tv.com/support.html
Feb 25, 2011 | Mitsubishi WD57831 Television
Hole in screen need new screen for mitsubishi wd-57732
alldecked506,
Go to http://www.encompass.com to get the part and use my tip at http://www.fixya.com/support/r6210638-replace_broken_projection_tv_screen for instructions on how to replace the screen.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 19, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Need replacement screen for Mits. WS-48511
The other site i am associated with has used screens for mitsubishi you just have to post the measurements of your screen top to bottom and side to side dont include the frame size as we allow 1/4 inch for fitting in the frame just need the size of the screen to the frame edge.
Mar 31, 2008 | Mitsubishi WS48511 48" Rear Projection...
Replacement Parts - Rear Proejction TV Mits. WS-48511
Visit http://www.vstore.ca for used lenticular and fresnals. They will size to fit.
Mar 31, 2008 | Televison & Video
Mitsubishi VS-45605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
