Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony kv-32xbr400 hi as soon as i turn tv on , i see green screen and horizantal white lines.with in seconds screen gets brighter and tv shuts itself off. i do have this models repair manual. engin
    Scholar:
  • 124 Answers
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Posted on Mar 27, 2006
My tv wont turn on ,It seem it is going to turn on and close itself
Searching for tv turns off but will turn right back?
  • Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
Nov 26, 2012 | Sony FD Trinitron WEGA KV-29LS35 29" TV
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony trinitron kv-32xbr400 it works but the picture is almost like its out of focus it has lines running thru it
The description that you give indicates a video problem, it is a situation where the picture tube is over driven and makes the picture bloom and produces white lines on a angle, this is caused by an open resistor or a shorted video driver usually located on the back of the picture tube, "video board"
Dec 30, 2010 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
KV-32xbr400 switch problem
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it. in yor case you have 5 blinks that´s why the last is short to be possible the count..Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
May 18, 2009 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony Trinitron Colour TV Stopped showing and switch light flicker
    The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
    Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Sony wega kv-32xbr400
    My sony is doing the same thing. but mine blinks 11 times. each time it goes to turn on i hear the clicking then nothing.
    Jun 12, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    Sony kv32v15, Red screen with fine horizantal lines then shuts off
    I would suggest to measure the 200 volt B+ at the CRT socket. If that voltage is found to be low, disconnect the socket from the CRT and measure again. If the voltage reading returns to normal you may have a defective CTR.
    Also check for open or defective diode on flyback transformer for the 200 vdc source.
    I would also suggest to take all the necessary precautions since you are working in a very high voltage area.
    Good Luck.
    Jan 14, 2008 | Sony KV-27XBR45 27" TV
    Top half of screen is dead
    HEY WEGA-YOUR SET HAS A BAD VERTICAL OUT IC AND ANYTV GUY CAN REPAIR THAT FOR A REASONABLE (COMPARED TO REPLACEMENT OFSET) COST.JOE TV
    Nov 20, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
    373 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
