Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Black line I have a Toshiba REGZA 42 inch screen that is displaying a vertical black line in the center on the the TV it is on every channel.
  • 10 more comments
  • Anonymous Sep 15, 2008
    Mine is off to the right.
    Mine appears on the right side of the screen
  • Anonymous Oct 01, 2008
    Same problem.  Line is on the right.
  • Anonymous Oct 12, 2008
    I only have it hook up to a hi-def, reciever using a HDMI cable. Where my black like is, it looks like the line is where the 4:3 outline should be, but -like I said, I only watch Hi-Def channels, and Blueray, and PS3 with it. Will the firmware update help?
  • Anonymous Jan 02, 2009
    Toshiba REGZA 47HL167. Same problem.
  • Anonymous Jan 05, 2009
    on the righe side
  • dcameto Jan 11, 2009
    I have the same problem ,a black line at the centre of the screen
    Any solution for this problem?
  • Anonymous Jan 13, 2009
    I have the same problem. Verticle black line in the center of the screen. Is there a solution?
  • joz1 Jan 22, 2009
    I also have a vertical line where the 4:3 would normally end.  The lines used to disappear after 30 minutes or so as the TV warmed up, but now one pink vertical line on the left will not go away.  :-(
    This seems to be a known problem.  Any way to fix this without a major $$$ back to Toshiba?
    Any help is appreciated.  Thank you!
  • pgne1 Feb 14, 2009
    I have the same problem. thin dark vertical line right in the middle of the screen. very annoying. any solutions anyone?
  • jonno_416 Feb 22, 2009
    I have the Toshiba Regza 52XF550U and I just noticed a thin black vertical line on the right side of the screen with rows of horizontal black lines all the way down the vertical black line to the far right on the picture...  So pissed...
  • Anonymous Mar 24, 2014
    Toshiba 42 inch cracked screen , shattered from center out
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Posted on Mar 13, 2009
  • 386 Answers
I have a "Home-fix" for you, you should watch this you tube video on how to repair a symptom such as yours even though it is a sanyo tv the fix is pretty much the same for your television and may save you oodles of money!
http://www.youtube.com/watch?v=purk_SyiT44
Good Luck!
Rich Lilja
Posted on Dec 29, 2013
I have the same problem. Very thin black line to the right of my screen though.
Posted on Sep 10, 2008
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
42 inch toshiba\r\n tv screen
Dark picture. I adjusted brightness, but it keeps getting dark. It has vertical lines that can be seen in grey areas on the screen.
Dec 08, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Jan 19, 2010 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vertical black line down centre of screen
I have same problem. Toshiba 42' hl196 purchased 4/07 line appeared 1 year and 9 months researched on Toshiba thread. Bad LCD screen. Repair cost more than tv-have to replace lcd screen. I didn't get the extended warranty. If still under warranty get hold of toshiba. Lot of people having same problem. Should get aclass action lawsuit started selling defective LCD screens. Kathy in Cleveland,OH
Dec 15, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Weird lines on Toshiba REGZA
its in warranty ship it, the problem is actually not common but it is a problem it is related to the processor on the main board, and um don't trust salesmen to tell you about repair issues. They really don't have a clue. if you need a tv for to weeks then rent one for two weeks they are not that expensive to rent
Aug 23, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
1,668 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
