Question about Whirlpool LER4634J Electric Dryer
WON'T COME ON AT ALL.
WHIRLPOOL DRYER LER3624EQ1 BREAKER OK 244V.GETTING POWER TO THE UNIT AND TO MOST EVERYTHING INSIDE.I 'VE JUMPERED THE DOOR SWITCH NOTHING.WHILE DOOR SWITCH BYPASSED I STARTED BYPASSING THE OVER LOADS ON THE HEAT ELEMENT SIDE THEN ON THE FAN SIDE STILL NOTHING.GETTING VOLTAGE TO ALL THESE.I EVEN CUT OUT THE WHITE FUSE AND RAN STRAIT WIRE TO BYPASS TO THE TIMER.NOW I OHMED MOST EVERYTHING EVERTHING MADE MY METER BUZZ.GOT NO VOLTAGE ON WHITE FUSE THING TO TIMER.NOW IF I TOOK THIS OUT AND STRAIGHT WIRED AND THAT WAS IT, IT SHOULD WORK ??? THINKING MAYBE MOTOR OR TIMER.ANY WAY TO CHECK THESE.I TOOK MOTOR SWITCH APART AND CLEANED THE CONTACTS.WHEN OHM THE MOTOR ACROSS ALL WIRES METER BUZZES,THE TO OUTSIDE RED WIRES BUZZ WHEN SWITCHED TO RUN. ANY IDEAS ??? GAS AND MATCHES BUY NEW ONE?? THANKS FOR ANY HELP ROBERT.
  • Anonymous Mar 19, 2014
    we have checked all the things that we can think to check and now we are looking at the timer. I cannot find a diagram of what the contacts are supposed to look like and how they are supposed to contact.
    Genius:
  • 1,122 Answers
You have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Posted on Oct 02, 2008
Ler3624eq1 whirlpool makes clunking noise
May have a bad bearing go to Repairclinic.com and watch their video on dryers
Dec 13, 2013 | Dryers
Dryer won't restart breakers ok door switch funtional but when i press srart button just buzzes......... suggestions?
Reach inside and try to turn the drum. If it is stiff you could have a bad roller or support bearing depending on your model. I have all kinds of dryer manuals HERE
and Here
Jul 07, 2012 | Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Whirlpool electric dryer LER5620KQ1. won't heat up timer does not advance
Same problem with my Whirlpool Dryer: Model LER4634EZ2 which stopped heating. I checked the coils that was "OK" then I checked the fuse that was "OK" I replaced the Thermal Fuse and High Limit Thermostat then after starting the dryer the heat came on ... problem solved NO.... the dryer just kept running and running until I opened the dryer door. Not going to put 70 or so $$$ into this 10 year old dryer which up until 12/15/2011 worked fine.
Dec 08, 2011 | Whirlpool LER5636P Electric Dryer
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
Dead. As if unplugged. Checked breakers et al.
1.Check dryer door switch.
2.Hold dryer door switch and listen.
3.Place a jumper wire between the switch prongs.
Mar 05, 2010 | Whirlpool LEB6200 Electric Dryer
Electric dryer doesn't heat.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
Jan 15, 2010 | Dryers
No power to selector panel
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Can't remove motor from Whirlpool dryer (LER3624EQ1)
no set screw,,,put the motor back,,,put the motor clip back on...lock it back down...ok now take a wrench and put it on the end of the motor where the belt goes,,if your by your sef,,prop the wrench againt the inner cabnit wall,,,than turn the blower wheel its hard but it will come off you..just lock that motor shaft down,,grip pliers..wracket,,,please use glovers to turn blower wheel..housing is very sharp..onthejob
Jan 24, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
356 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
