Question about Sony CMT-HPX9 CD Shelf System
CD problems Cannot open CD drawer
  • brainman214 Mar 08, 2008
    I'm Having The Same Problem With My Durabrand 6 Disc Shelf System.A few Days ago when i stopped the dusc and tried restarting the player a"Not Ready" error appears in the Display and the tray won't open.I tried Pushing buttons.even putting objects to disengage the tray to open but still no luck.What Can You Suggest?
    Champion:
  • 277 Answers
Hi you push the button and it dosent work? maybe the button went bad push harder pull the button out ( if possible) and push with something small and hard you hear anything after you push? if soo then the drawer is stuck or the engine is about to die (not enough power to open the drwer) take a flat screwdriver and shove it (gently) between the carack of the drwer and try helping the drawer out maybe a plastic wheel will brake from this soo be careful in the end these system are ment to start dying after 5 years soo if this is the case sorry wont do any good have a good one
Posted on Mar 27, 2006
SOURCE:
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
Denon CD Player Drawer won't open
This problem can be due to a defect in the player mechanism or binding in the drawer travel path. You may be able to find and correct the binding problem.
Jan 29, 2015 | Denon Audio Players & Recorders
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Cd drawer keeps opening and closing
Hi, Well i had the same problem with my CD drawer.Your CD drawer has some problem. Either repair it or buy a new one.
Thanks1 Sandy
Apr 21, 2009 | Gateway GT5220 PC Desktop
My CD drawer will not open or close
I had a mini system with the same problem, out of guarantee so was either fix it myself or bin it.
I opened the unit and removed the whole cd drawer assembly from it's housing. I then, not really recommended, plugged it back in and by pressing the open/close a few times the drawer finally opened. Put it all back together and it now works fine. I think what had happened is that I use the cd player once every couple of months and combined with the lack of use is the fact that there are several smokers in the living room and basically it got jammed by a build up of nictotine or whatever.
Apr 01, 2009 | RCA 5-cd 300w Stereo System Shelf System
Player doesn't recognize most CDs - 'no disc' message appears.
Your player lens needs to be cleaned by a lens cleaner...
Feb 24, 2009 | Teac CD-P1260 CD Player
Cdr20 drawer is jammed ERROR message
Try taking the unit apart it mostlikly jamed or jumped track try re ajusting it that would prob work, another thing is to try messing with the gears that could aslo work
Oct 18, 2008 | Harman Kardon CDR20 CD Player
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Jul 24, 2008 | Audio Players & Recorders
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Sony CMT-HPX9 CD Shelf System Logo
387 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
