Question about Intel Motherboard
Motherboardecs fsb800 i don't know where the power led , hdd , reset sw ,and power sw conecction goes as in this board is new for me and con't see any where to say where they go. the other problem is when i conect all wires to motherboard fan start but monitor says check the video conection .please can you help me
  • 981 Answers
No.  You need to look at the model of your board properly and look up that manual online if you don't have it with you; at least look at other boards by the same maker!  Better connect a muted speaker though, because once you do connect it it will beep out a BIOS beep code for you to look up.
   Seriously, if it's in pieces for other reason than that it's broken, what do you expect of people?
Posted on Sep 10, 2008
ABOUT THE CONNECTION DIAGRAM OF power sw,HDD led,reset sw,
Does the computer power up when you press the power button? Does it boot successfully?
The things you are talking about are just led lights and really don't effect anything other than just being indicators, so tinker with them until you get it right.
The main thing is that you have the main power from the power supply int the socket on the board, the cables and powers that go to the back of your Hard Drive, etc. are in the correct place.
If you look closely at the things you are talking about there are labels that tell what goes where near the prongs or pins. The Power indicater might be something like PWR. Reset might be RST and the Hard Drive might be HDD. Just play around with them, because they are just indicators. If you system is not booting it's not because of them.
May 16, 2012 | Computers & Internet
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
Mar 28, 2011 | Computers & Internet
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
Need prescott 800 ddr 400 sound card drivers
ITALIANO
Sceda madre ASROCK Prescott 800, FSB 800/DDR400 Dual Channel
Comme deve ataca PANEL1
POWER SW o o
RESET SW o o
HDD LED o o
POWER LED o o o
Grazie
Nov 18, 2010 | Asrock P4I45E-R3 P4 845E FSB800 DDR400...
How do i plug in power button in on mother board? Lost my manual so I can't find the model #. I was just switching my mother board and all other hardware to new case and my power button (or switch or...
> power led,
Runs to the LED (Light Emitting Diode) labelled "power" on the front of your computer-case
> H.D.D led,
Runs to the front-panel LED that lights-up whenever the Hard Disk Drive is being used.
> reset sw,
Runs to the "reset" button on the front panel.
> speaker
Runs to the internal speaker
> s/b sw
Very briefly touch a metal-tip screwdriver between these 2 pins.
If the computer powers-on, you've found the "power" connector.
Nov 06, 2009 | Intel Motherboard
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Configuration
Hi
The wires that read +5 -d +d and ground those are USB connectors each usb connector will have 4 wires, +5 -d +d and ground so that goes to usb pins.
The sw must be power switch
The HDD led is the load light
Reset is the reset button
Power led is the front power light
SPK is the speaker / beeper.
Can you tell me the brand and model of the motherboard? They are documented in the user manual. but generally in the bottom right corner of the motherboard you have the connectors for the leds and buttons, its all written into the motherboard with small white text. but I can get clear instructions from the user manual for you.
You can look for the motherboard details between the expansion slots and between the cpu and memory.
Thanks,
Ekse
Feb 03, 2009 | Intel SVM266A VIAP4M266A (SYNTAX SVM266A...
P4VMM2 motherboard
You can download the manual from here (Europe) or here (US).
Sep 17, 2008 | EliteGroup P4VMM2 Motherboard
Intel Motherboard Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
