Question about Sanyo SR-4910M Compact Refrigerator
Sanyo Mini Fridge
When I was defrosting our mini fridge I punctured a small hole in the ice tray and there was a small leak! Is there any way to fix on my own or do I have to take it to a repair man! Nay ideas as to cost?
  • 1 more comment
  • Thearhea Sep 25, 2008
    Same problem, when we were cleaning the freezer of our mini fridge, the tray sprayed something for a few seconds. We think we broke a freon line. Is there any way to fix that? What do I do? How can I add more freon?
  • Lindsey Black Jan 02, 2009
    same thing happened to me
  • kmd15 Dec 11, 2009
    I WAS CLEANING THE FREEZER OF MY MINI FRIDGE AND I PUNCTURED A HOLE WHILE TRYING TO TAKE OUT ALL THE DEFROST INSIDE OF IT HOW DO I FIX IT
Nope the evap line is aluminum and can't be soldered onto the suction line sorry
Posted on Apr 18, 2011
Inside the fridge on back wall ice will build up then it begins leaking and forms a puddle in the fridge. How do I fix it?
There is a hose from the evaporator coil in the freezer tray to the bottom condensation tray, check this for obstruction.
Sep 01, 2017 | Refrigerators
There is a leak under the deli tray of my RFG297AARS how do I fix it?
might just be due to condensation
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Feb 20, 2015 | Refrigerators
Igloo mini fridges
The question is: Are you seeing water inside the fridge where it shouldn't be? Are there water stains in the try? Some of these have no tube, the water just drips from a small hole above the tray.
Jan 05, 2018 | Igloo FR834A Stainless Steel 3.2 Cu Ft...
I was defrosting a mini magic chef refrigerator i didn't puncture anything that i can see..but now it won't freeze
It sounds like the proverbial ice pick defrost. The evaporator tubing is so delicate that you could have scratched it enough to cause a small hole. the other possibility is the compressor just stopped pumping. Mini friges are notorious for poor compressors.
Jul 27, 2014 | Refrigerators
Water flowing into refrigerator. Ice build up behind freezer back wall. Will clearing ice from drains suffice or do I need a new heater? Foam drains to fridge are open. There is a small hole under...
hello again,
part 2 of the answer,the metal pan is the drain in the center of it is where the drain is blocked,the foam vents are the vents where the air from the freezer flows into the fresh food compartment,GENTLYclear that small hole so as not to puncture the tubing in the coil above it,or you will loose all the refrigerant(freon) an dthe ref, will be dead
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Water from defrosting leaks into the bottom of the freezer and freezes into a solid sheet of ice, which I chip out every 1 to 2 weeks. Kenmore bottom freezer refrigerator Model 795.65002400.
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Good luck and hope this helps
Aug 01, 2010 | Kenmore 65212 Bottom Freezer Refrigerator
Sanyo mini refridgerator won't get cold
This sounds to me like your fridge might be in defrost mode. There should be a switch up toward the top of the fridge near the cold setting. It's not always very visible, but feel around for a little round hole. There should be a small, plastic rod sticking out. Push it back in. (If it's out.) If this is the problem, you should hear the compressor turn on and the fridge should start cooling off again. If you still have the owners manual, it'll probably point you to its exact location.
I hope this helps! :)
Jul 23, 2010 | Sanyo Refrigerators
Sanyo SR-4910M Compact Refrigerator Logo
1,556 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
