Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
TV will not switch on
After disconecting video from TV our tv did not turn on. The fuse is ok, when plugged in and switched on it does make a sound in the back like it normally does, but does not power up, no light, nothing at all. I have removed the back and given it a clean/dust but still nothing.
  • susankoster Jul 27, 2008
    When I switch the TV on, it clicks as if it is going to power up but then nothing happens. I disconnected the set and plugged it back in. I turned off the surge protector and turned it back on. The red light on the front of the set Stand by/Timer is flashing.
  • Anonymous Oct 25, 2008
    I have the same problem - I can get the set on by plugging and unplugging the set - It is taking longer and longer as time goes on. It turns on after about a half hour of plugging and unplugging.
    Scholar:
  • 124 Answers
This can be caused from numerous reasons, I will specift only the most common ones which doesn't require professional skills to deal with. The "easy" initial technical troubleshooting that can be performed, without a schematic and without a service manual, is using your DMM to make voltage readings and test components, also do a careful visual inspection and make not of any faulty or cracked solder connections around the high heat producing components and other pertinent details. Given the symptoms you reported, it should be obvious that the areas of initial troubleshooting interest in the television circuitry are the main PS, B+ regulation, and B+ distribution, standby B+ , the HV and HOT area.... also pay attention to the and flyback derived B+ circuitry and components.
Posted on Mar 27, 2006
SOURCE:
When I press power it will not turn on there is no red light it will simply not turn on
hi so the tv is totally dead, if so check the power switch if has one you may have knocked it off, if ok check the fuse in the plug if ok the fuse inside could have blown thanks
shaun
Jun 26, 2017 | Televison & Video
We have a tx-nr515 reciver and cant get sound from tv but everything else working fine?
Try plugging the TV into the AUX on the back of the receiver. If you get sound from the tv when you switch to AUX on the front of the receiver, then you know the tv is ok. You may also try connecting your CD player to the TV input on the back of the receiver, switch it to TV on the front of the receiver and if you have CD sound from the tv selector, then the receiver should be ok. Helps narrow down where the problem is. You may have to set the tv to enable its audio outputs in the TV's menu. It might not be putting out any sound until that setting is enabled.
Jul 27, 2014 | Onkyo TX-NR515 AV Receiver
Sony kv j14l1
If there is any blinks occurs to standby power LED during switch On, and the set switches off automatically?
Jun 01, 2013 | Televison & Video
TV wont switch on
Check plug for power. Make sure that plug has adaquit power. These TV's take a lot of power make sure breaker pannel is OK. Check fuse in TV. Good luck.
Dec 11, 2011 | Televison & Video
Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
Hitachi 60SBX78B No sound or Video
replace pico fuse E994 and capacitor C707. You have to disconect alot of wires and remove the screws holding the boards. you DON'T have to remove the large high voltage wires. You have to stand the board on it"s edge to unsolder the components from the back side of board. Good luck it worked fine for me. fcs0998@aol.com gene
Apr 27, 2009 | Hitachi 60SBX78B 60" Rear Projection...
My kid power off tv by power button on tv, next time i could not
switch tv on the switch can not contribute to that. unless the following goes fault
i switch getting fixed on one position(holding)
ii check power on a input of tv and input fuse
iii power supply, i have said that because if a power supply is ok, sound was going to be there.
Nov 22, 2008 | Samsung TXG2547 25" TV
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
304 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
