Mizuda 14 in tv
No volume
Hi , No I havent fixed problem as yet , but I dont have a credit card.so will just have to keep looking , Thanks anyway , Spuddy
Posted on Sep 10, 2008
There is no sound from the tv, how do I turn on sound?
About 243,000,000 results (0.42 seconds) Search Results
    10 Ways To Fix A TV That Has A Picture But No Sound ...
    removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/
    Nov 14, 2013 - If your TV has a picture but no sound coming out of the speakers, thereare a few things you can easily check. ... See below for the best solutions to fix a TVwith no sound. ... Television Has No Sound Answer 1: Make sure TV is not muted.
    There is no sound or low volume coming from the TV ...
    https://us.en.kb.sony.com/.../there-is-no-sound-or-low-volume-coming-f...
    Aug 15, 2015 - There is no sound or low volume coming from the TV speakers. Article ID: ... Make sure no headphones are connected to the TV. Verify that the ...
    Picture But No Sound TV - Bright House Networks Support
    support.brighthouse.com/.../Picture-But-No-Soun...
    Bright House NetworksIf you have picture but no sound. Press to ... Ensure that the audio and video cables are connected to the same inputs on the TV. For example, if ... My BHN App.
    No sound from my TV via HDMI when my cable box is ...
Jan 21, 2016 | Televison & Video
Increase volume
Run a cable from "Audio Out" on your TV, to "Audio In" on your stereo.
Turn up the volume on your home theater unit.
Get hearing aids
Paint a "1" in front of the "63"
Can you not hear your TV? Is the volume supposed to go above 63? Do you have it connected to any externals like a stereo, or surround sound system? Between 0 and 63, can you turn the volume up and down freely, with no problems? We need a lot more information before we can help you out with your specific problem. Let us know and we'll get you squared away!
Jan 31, 2013 | Panasonic TC-14LA1 14 in. EDTV LCD...
The difference between the inner and outer surfaces of a cylindrical pipe is 88cm sq..if the height of the cylindrical pipe is 14cm and the volume is 176cm cube. Find the inner and outer radius of the...
The surface area of the outer surface is the circumference of the outside of the pipe times its length. So, if OR is the radius of the outside of the pipe and SO is the outer surface area,
SO = 2 * pi * OR * 14
Similarly, the surface area of the outer surface is SI = 2 * pi * IR *14 (if SI is the inner surface area and IR is the radius of the inside of the pipe.
The question states that the difference between the outside surface area and the inside surface area is 88 sq. cm:
SO - SI = 88 ; substituting:
(2 * pi * OR * 14) - (2 * pi * IR * 14) = 88 ; factoring
(2 * pi * 14) (OR - IR) = 88 ;dividing both sides by 2*pi*14
(OR - IR) = 88/(2 * pi) = 88/(2 * 3.14159*14) = 1.00
So, the outside radius is 1 cm more than the inside radius.
It's not clear if the volume stated is the volume of the metal in the pipe or the volume of air inside the pipe, so I will solve it both ways:
If volume of 176cc is of the air inside, the formula for this volume is 14 * pi * IR *IR
176 = 14 * 3.14159 * IR * IR ; dividing both sides by 14 * 3.14159
176/(14 * 3.14159) = IR * IR ; doing the arithmetic
4 = IR * IR ; taking the square root of both sides
sqrt(4) = IR
IR = 2 cm
substituting back into the first equation, the OR is 1cm more than the IR, so
OR = 3 cm
If volume of 176cc is of the iron in the pipe, the formula for that volume is the difference between the volume of the outside of the pipe and the volume of the inside of the pipe, or
(14 * pi * OR * OR) - (14 * pi * IR * IR) = 176 ; factoring
(14 * pi) ((OR * OR) - (IR * IR)) = 176 ; dividing both sides by 14 * pi
((OR * OR) - (IR * IR)) = 176/(14 * 3.14159) = 4
but, since OR is 1 cm more than IR (from above), we can substitute OR = IR + 1
and OR * OR = (IR + 1) * (IR + 1) = (IR*IR) + 2*IR +1
So, ((OR * OR) - (IR * IR)) = 4 becomes
(IR*IR) + 2*IR +1 - (IR*IR) = 4 ; simplifying (IRsquared - IRsquared = 0)
2*IR + 1 = 4 ; subtract 1 from both sides
2*IR = 3 ; divide both sides by 2
IR = 3/2 ;
IR = 1.5cm
OR = 2.5cm
Jan 11, 2011 | Mathsoft StudyWorks! Mathematics Deluxe...
LG HDTV Volume bar disappeared from Display
try factory reset in main menu or press menu continuaslly until it no longer comes up then 7777 on remote
May 05, 2010 | LG 42LC2D 42 in. LCD HDTV
Is the mizuda 595 a multi zone player
All players can be muti zone all you need to do is unlock the region code menu. This can be achieved by pressing a number of keys on the remote. Now all you need to do is find the combination! Try entering the model number into google and the words "region code". Somebody will have hacked it!. When you get it enter 0 (zero) for the region.
Dec 15, 2009 | Shenzhen Mizuda Televison & Video
The sound control is set at a super low level...To be loud enough to be heard without a problem at a normal distance, the number on the sound level has to be at 90 or 92..My other tv's the same volume is a...
Have you used the remote that came with the TV to raise the volume? Often, when there is more than one remote, one of them is set too low and all you need to do is use the remote that came with the TV to raise the volume level. Good Luck!
Aug 17, 2009 | RCA 14F514T 14" TV
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
Sound form Bush TV
It could be several problems, I'll share with u a couple. All of them need a tech.[technician]
Your volume control works by adjusting the voltage\current to the speakers. The VOLUME CONTROL could be damaged\fixed at a point [even if you are raising\lowering] at high volume.Sometime the control has a crack ********\********* in such a way that the volume arm won't go past crack[see above] on HIGH volume.
The audio IC could be shorted in high volume. Sometimes the audio IC is PART of a 64 (sixty-four) pin ckt. How do u test for that if u are not a techo'
Let someone take a peek at it.
Oct 23, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
14" t.v. when i increase the Volume
I believe you have a regulation problem ,when you increase the volume the audio output IC draws more current therefore the power supply has to keep up with the increase in current,the symptom might happen if you increase the brighness to the max as well,the voltage changes need to be monitored closely to diagnose what component is not doing the work.If you are familiar with tv service this is a problem that will give you a challenge but if you are not too familiar be safe and let someone else get the headache.Let us know how it goes or if you need more information.
Nov 06, 2006 | JVC TV-20F243 20 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
