Question about Audiovox D1708 Portable DVD Player
No picture my husband is on a trip with my son and the DVD player suddenly will not show video...he can get the audio. Any ideas? I purchased 3 months ago for Christmas. Of course beyond warranty!!!
  • Michael Bellisle
    Michael Bellisle Feb 18, 2008
    I have same unit an Audiovox D1798 7" dvd player that has audio but no picture..I checked your post here, but i have no button on the back as shown in the post.. Could it be somewhere else? I really would like to use this unit again for viewing my collection of DVD's.
    thanks for any help, Mike
  • tylermay45 Feb 27, 2008
    After using my audiovox portable dvd player three times the screen went black. I can see a slight movements and hear audio so I know the movie is playing. What do I do?
YEPPI! It works! Thanks for helping me fix this problem!
Mary in WV
Posted on Dec 26, 2007
Thank you!! I have been trying to figure this out FOREVER!!! It worked immediately!!
Posted on Feb 09, 2008
That was exactly it!!!! Thank you!
Posted on Dec 24, 2007
There is a button located on the back of the DVD player and where the screen closes. My button was stuck in the down position (should be up when screen is open). I used a small, pointed object to release the button and the picture came right back! Hope this helps! -Kris
Posted on Oct 08, 2007
When i turn my dvd player on the screen just flashes and cuts off.
Posted on Apr 23, 2007
    Champion:
  • 277 Answers
Hi - make sure the CD is a DVD movie! - try Connecting to a TV or another monitor http://www.fixya.com/BrowseManual.aspx?mnlid=16&prdid=237876&__PAGED_=28 if the movie is showen on the other t.v and the player isnt then that's exactly the reason way the warranty is 90 days only good luck
Posted on Mar 27, 2006
The DVD will go in but the picture is black and yo can hear but the picture out
Usually DVD players have audio and picture "out" connections to go to your TV. Verify that your cables are connected. If it has worked in the past and suddenly started, disconnect then reconnect the cables at both the DVD player and TV end. Cables do not usually go bad but unfortunately DVD players are considered disposable and are not usually repaired any more. If you have multiple video/audio connections on the back of your TV (like Video 1 & Video 2) switch the cables from one to the other. Be sure to keep your cable sets together and don't do something like video output to video 1 and audio output to audio 2. If that works for you then you may have connectors on the back of your TV going out. Hope this helps you.
Nov 07, 2017 | Televison & Video
My DVD Player ( ONIDA DFX-7100) is now unable to play any VCDs. I have tried many VCDs which were earlier working fine but now they won'tplay. The player keeps displaying the ''loading'' message and after...
Have you changed programs that you use to burn VCDs?
(Perhaps the program was updated?)
Perhaps trying a different program to make the VCD will work for you.
Also; when is the last time you cleaned the DVD player lens?
Mar 25, 2011 | Audio Players & Recorders
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
Sudden loss of picture, sound comes though ok
It sounds like the exact same problem that my son recently created. The only solution I've determined is to reset the player to it's default settings. Although it took a little while (since the video display was not present), I finally found the right combination of buttons to push on the remote and now the problem is fixed. Insert a disk, then push the following buttons: Stop, Stop, System/Menu, >, >, >, v, v, v, v, v, >, OK
After the above sequence of buttons, the main player screen should reappear on the tv.
Croce23
Jan 04, 2009 | Philips DVD727 DVD Player
Snowy screen playing dvd's
1.Check audio/video RCA jack cables
2.check S-video(if you use S-video cables)
3.check with another dvd player to get normal picture on your tv system. if picture is normal in this process. then problem with your old dvd player.
4.if same problem occurs in other dvd player. then problem with your television. external audio/video processing circuits
5.if the tv is ok. then the problem with your old Dvd player audio.video converting circuits
6. if can be rectified by authorised service engineers
7.Contact service engineer. as there is no recitification process from user part
Dec 15, 2007 | Hitachi 43FDX01B TV
No Audio/Video output with DVDs
lost dvd picture and menu screen through denon av2307 composite conection
Aug 26, 2007 | Denon DVD-3910 DVD Player
All of a sudden quit working
most portable dvd players arent meant to stay plugged in for long periods of time because they overcharge the batteries or cause damage to the players power supply regardless of how expensive they are .
However you can get a dvd player unit that is mounted in an overhead console (from a car stereo outlet that will last go to this site to see examples: www.mobilevideo4less.com/suv-systems.html - 40k
Mar 17, 2007 | kawasaki PVS-10921 Portable DVD Player
Sound lags picture
This can some times be caused by VBR audio encoded files as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solved the problem.
Although this is usually with DivX (AVI) files that have been re-authored to DVD-Video I suggest that you convert all audio to CBR to avoid any such errors.
this conversion process it a bit of a long way around I know, but it does work!
1) Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
2) Ignore the error warning that the video contains vbr audio.
3) Extract audio as mp3 ("demux" in VdubMod or "save as wav", then rename to mp3 in VdubMP3).
4) Convert audio to wav with CDex
5) Open original video in VirtualDub, choose "direct stream copy" for video and "Wav audio" with "Full audio processing" with cbr mp3 compression (and interleaving with appropriate delay if out of sync) for audio.
You could also use several other methods including AVIDemux which uses VDub Mod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this doex not solve a progressive lag but can be used to reauthor a fixed error.
Feb 12, 2007 | Philips DivX DVD Player
Dvd no picture just sound
When you say No picture?? s the Picture all black Like theres no video? Try checking the video input on the tv or the cables from the player. If the inputs and cables are bad then theres a poroblem in the video processor in the dvd player and the only way to vix that would be to get a schematic diagram and a scope and trace out the video and see where it disapears. Good Luck
Apr 13, 2006 | Pioneer DV-360-S DVD Player
Audiovox D1708 Portable DVD Player Logo
106 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
